path: root/board/atmel
2008-05-10Fix @ -> <at> substitutionStelian Pop
When applying the AT91CAP9 patches upstream, something transformed the '@' character into the ' <at> ' sequence. The patch below restores the original form in all the places where it has been modified (the AT91CAP9 files, the AT91SAM9260 files which were copied from AT91CAP9, and a couple of other files where the ' <at> ' sequence was present). Signed-off-by: Stelian Pop <stelian@popies.net>
2008-05-10Update origin and copyright information in arch-at91sam9 header filesStelian Pop
When doing the AT91CAP9/AT91SAM9 port, a number of header files were copied from the Linux kernel sources. This patch explicitly specifies this origin for all the copied headers, and for those missing copyright information, adds it. Additionaly, the header file 'at91sam926x_mc.h' has been superceeded in the latest kernel sources by 'at91sam9_smc.h'. The copyright information has been confirmed by the AT91 Linux kernel maintainer, Andrew Victor <avictor.za@gmail.com>. Signed-off-by: Stelian Pop <stelian@popies.net>
2008-05-10Add copyright information in Atmel boards partition.cStelian Pop
When Ulf did the dataflash.c cleanup, he didn't add his copyright on the new created files. This patch fixes the problem. Signed-off-by: Stelian Pop <stelian@popies.net>
2008-04-18Clean up dataflash partitioningUlf Samuelsson
This patch removes the board dependent parts from "drivers/mtd/dataflash.c". Each board relying on this, will have the appropriate code in a new file, "partition.c" in the board directory. board Makefiles updated to use the file. The dataflash partitions are aligned on sector/page boundaries. The CONFIG_NEW_DF_PARTITION was used to create named partitions This is now the default operation, and the CONFIG variable is removed. Signed-off-by: Ulf Samuelsson <ulf@atmel.com>
2008-04-01AT91SAM9260EK: Move CONFIG_CMD_NAND to MakefileJean-Christophe PLAGNIOL-VILLARD
2008-04-01Add support for AT91SAM9260EKStelian Pop
Support for booting from internal DataFlash, external DataFlash card or NAND flash is available. Signed-off-by: Stelian Pop <stelian@popies.net>
2008-04-01AT91CAP9ADK: Move CONFIG_CMD_NAND to MakefileJean-Christophe PLAGNIOL-VILLARD
2008-04-01Port AT91CAP9 to the new headersStelian Pop
Adapt the existing AT91CAP9 code to the new headers and APIs. Signed-off-by: Stelian Pop <stelian@popies.net>
2008-02-17at91cap9adk: fix implicit declaration of function 'eth_init'Jean-Christophe PLAGNIOL-VILLARD
2008-02-15Merge branch '080202_at91rm9200dk' of git://linux-arm.org/u-boot-armdevPeter Pearse
2008-02-15Merge branch '080116_at91cap9' of git://linux-arm.org/u-boot-armdevPeter Pearse
2008-02-14Move AT91RM9200DK board support under board/atmelHaavard Skinnemoen
We already have a vendor subdir for Atmel, so we should use it. Signed-off-by: Haavard Skinnemoen <hskinnemoen <at> atmel.com>
2008-02-14AT91CAP9 support : move board files to Atmel vendor directory.Stelian Pop
AT91CAP9 support : move at91cap9adk board files to Atmel vendor directory. Signed-off-by: Stelian Pop <stelian@popies.net>
2008-02-05AVR32: Make SDRAM refresh rate configurableHaavard Skinnemoen
The existing code assumes the SDRAM row refresh period should always be 15.6 us. This is not always true, and indeed on the ATNGW100, the refresh rate should really be 7.81 us. Add a refresh_period member to struct sdram_info and initialize it properly for both ATSTK1000 and ATNGW100. Out-of-tree boards will panic() until the refresh_period member is updated properly. Big thanks to Gerhard Berghofer for pointing out this issue. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2008-02-05ATSTK1000: Fix potential flash programming bugHaavard Skinnemoen
The (now obsolete) atngw100 flash programming code was having problems programming the onboard at49bv642 chip. The atstk1000 flash programming code may have the same bug, so import fix for this problem from the AVR32 Linux BSP. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2008-01-18AVR32: ATNGW100 board supportHaavard Skinnemoen
Add support for the ATNGW100 Network Gateway reference design, including flash, ethernet and MMC support. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-10-06AVR32: Initialize bi_flash* in board_init_rHaavard Skinnemoen
The ATSTK1000-specific flash driver intializes bi_flashstart, bi_flashsize and bi_flashoffset, but other flash drivers, like the CFI driver, don't. Initialize these in board_init_r instead so that things will still be set up correctly when we switch to the CFI driver. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-07-09board/[A-Za-c]*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04board/[Ma-i]*: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2007-04-14AVR32: Enable MMC supportHaavard Skinnemoen
Set up the portmux for the MMC interface and enable the MMC driver along with support for DOS partitions, ext2 and FAT filesystems. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-04-14AVR32: Enable networkingHaavard Skinnemoen
Implement MACB initialization for AVR32 and ATSTK1000, and turn everything on, including the MACB driver. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-04-14AVR32: Use initdram() instead of board_init_memories()Haavard Skinnemoen
Conform to the "standard" interface and use initdram() instead of board_init_memories() on AVR32. This enables us to get rid of the sdram_size member of the global_data struct as well. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-04-14AVR32: Relocate u-boot to SDRAMHaavard Skinnemoen
Relocate the u-boot image into SDRAM like everyone else does. This means that we can handle much larger .data and .bss than we used to. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-04-14AVR32: Resource management rewriteHaavard Skinnemoen
Rewrite the resource management code (i.e. I/O memory, clock gating, gpio) so it doesn't depend on any global state. This is necessary because this code is heavily used before relocation to RAM, so we can't write to any global variables. As an added bonus, this makes u-boot's memory footprint a bit smaller, although some functionality has been left out; all clocks are enabled all the time, and there's no checking for gpio line conflicts. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2006-10-27Fix "ar" flags in some Makefiles to allow for silent "make -s"Wolfgang Denk
2006-10-25Finish up support for the ATSTK1000/ATSTK1002 boardsHaavard Skinnemoen
Add atstk1002_config target to Makefile and move the AVR32 section down below Blackfin so that it doesn't end up in the middle of MIPS. Drop the autogenerated linker script thing for now. Will have to revisit how to handle chips with different flash and RAM layout later. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2006-10-24Move atstk1000 files into vendor specific directory.Wolfgang Denk
Patch by Haavard Skinnemoen, 12 Sep 2006
