path: root/board/atmel
2008-11-21AT91: Use AT91_CPU_CLOCK in displaysStelian Pop
Introduce AT91_CPU_CLOCK and use it for displaying the CPU speed in the LCD driver. Also make AT91_MAIN_CLOCK and AT91_MASTER_CLOCK reflect the corresponding board clocks. Signed-off-by: Stelian Pop <stelian@popies.net>
2008-11-07AT91: Replace AT91_BASE_EMAC by the board specific values.Stelian Pop
AT91_BASE_EMAC is never used outside the board specific files, so replace its usage by the board specific AT91xxx_BASE_EMAC. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-11-07AT91: Replace (undefined) AT91_ID_US* by the board specific values.Stelian Pop
AT91_ID_US0 / AT91_ID_US1 / AT91_ID_US2 were used but never defined. Since they are never used outside the board specific files, they can be replaced by the board specific AT91xxx_ID_US0 / AT91xxx_ID_US1 / AT91xxx_ID_US2. Bug spotted by Jesus Alvarez <jalvarez@micromint.com>. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-10-27lcd: Let the board code show board-specific infoHaavard Skinnemoen
The information displayed when CONFIG_LCD_INFO is set is inherently board-specific, so it should be done by the board code. The current code dealing with this only handles two cases, and is already a horrible mess of #ifdeffery. Yes, this duplicates some code, but it also allows boards to print more board-specific information; this used to be very difficult. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2008-09-12Merge branch 'Makefile-next' of git://git.denx.de/u-boot-armWolfgang Denk
2008-09-12Fix MACH_TYPE for the AT91RM9200DK board.Claudio Scordino
Signed-off-by: Claudio Scordino <claudio@evidence.eu.com>
2008-09-02Moved initialization of Ethernet controllers on Atmel AT91 to board_eth_init()Ben Warren
Removed at91sam9_eth_initialize() from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-02Introduce netdev.h header file and remove externsBen Warren
This addresses all drivers whose initializers have already been moved to board_eth_init()/cpu_eth_init(). Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-08-20Merge branch 'next' of git://git.denx.de/u-boot-avr32Haavard Skinnemoen
Conflicts: MAINTAINERS
2008-08-13at91: Update board NAND drivers to current API.Scott Wood
2008-07-30Merge branch 'eth-cleanup' of git://git.denx.de/u-boot-avr32Haavard Skinnemoen
2008-07-24Moved initialization of AVR32 Ethernet controllers to board_eth_init()Ben Warren
Renamed initialization functions for atngw100 and atstk1000. Removed initializations for these boards from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-07-23avr32: Fix printf() format warningsHaavard Skinnemoen
2008-07-13at91: Fix to enable using Teridian MII phy (78Q21x3) with at91sam9260Anatolij Gustschin
On the at91sam9260ep development board there is an EEPROM connected to the TWI interface (PA23, PA24 Peripheral A multiplexing), so we cannot use these pins as ETX2, ETX3. This patch configures PA10, PA11 pins for ETX2, ETX3 instead of PA23, PA24 pins. Signed-off-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Manuel Sahm <Manuel.Sahm@feig.de>
2008-07-07Merge branch 'master' of git://www.denx.de/git/u-boot-at91Wolfgang Denk
2008-07-07Merge branch 'master' of git://www.denx.de/git/u-boot-avr32Wolfgang Denk
2008-07-05[AT91SAM9] Fix NAND FLASH timingsPatrice Vilchez
Fix NAND FLASH timings for at91sam9x evaluation kits. New timings are based on application note "NAND Flash Support on AT91SAM9 Microcontrollers" available at http://atmel.com/dyn/resources/prod_documents/doc6255.pdf Signed-off-by: Patrice Vilchez <patice.vilchez@atmel.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Stelian Pop <stelian@popies.net>
2008-07-05Fix boot from NOR due to incorrect reset delay.Stelian Pop
AT91 RSTC registers are battery-backuped, so their values are not reset across power cycles. One of those registers, the AT91_RSTC_MR register, is being modified by U-Boot, in the ethernet initialisation routine, to generate a 500ms user reset. Unfortunately, this value is not being restored afterwards, causing subsequent resets to also last for 500ms. This long reset sequence causes problems (at least) in the boot sequence from NOR: by the time the CPU tries to load a program from the NOR flash, the latter is still in reset and not yet available. Additionaly, this patch fixes a bug in the original code which caused the reset delay to last for 2s instead of 500ms. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-06-20avr32: Enable SPI flash support on ATNGW100Haavard Skinnemoen
The ATNGW100 has 8MB DataFlash on board. Give users access to it through the new SPI flash framework. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-06-03Merge remote branch 'u-boot-at91/for-1.3.4'Wolfgang Denk
2008-05-27avr32: Rework SDRAM initialization codeHaavard Skinnemoen
This cleans up the SDRAM initialization and related code a bit, and allows faster booting. * Add definitions for EBI and internal SRAM to asm/arch/memory-map.h * Remove memory test from sdram_init() and make caller responsible for verifying the SDRAM and determining its size. * Remove base_address member from struct sdram_config (was sdram_info) * Add data_bits member to struct sdram_config and kill CFG_SDRAM_16BIT * Add support for a common STK1000 hack: 16MB SDRAM instead of 8. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-05-27avr32: Use the same entry point for reset and exception handlingHaavard Skinnemoen
Since the reset vector is always aligned to a very large boundary, we can save a couple of KB worth of alignment padding by placing the exception vectors at the same address. Deciding which one it is is easy: If we're handling an exception, the CPU is in Exception mode. If we're starting up after reset, the CPU is in Supervisor mode. So this adds a very minimal overhead to the reset path (only executed once) and the exception handling path (normally never executed at all.) Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-05-27avr32: Clean up the HMATRIX codeHaavard Skinnemoen
Rework the HMATRIX configuration interface so that it becomes easier to configure the HMATRIX for boards with special needs, and add new parts. The HMATRIX header file has been split into a general, chip-independent part with register definitions, etc. and a chip-specific part with SFR bitfield definitions and master/slave identifiers. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-05-27avr32: Add support for the ATSTK1006 boardHaavard Skinnemoen
This is a replacement for ATSTK1002 with 64MB SDRAM and NAND flash on board. It's currently in production and will be available soon. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-05-27avr32: Get rid of the .flashprog sectionHaavard Skinnemoen
The .flashprog section was only needed back when we were running directly from flash, and it's even more useless on NGW100 since it uses the CFI flash driver which never used this workaround in the first place. Remove it on STK1000 as well, and get rid of all the associated code and annotations. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-05-24Merging Stelian Pop AT91 patchesJean-Christophe PLAGNIOL-VILLARD
Merge branch 'testing-V2' Conflicts: board/atmel/at91cap9adk/Makefile Fixing copyright board/atmel/at91sam9260ek/Makefile Fixing copyright board/atmel/at91sam9260ek/u-boot.lds Delete no more needed ld script Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10Support AT91CAP9 revC CPUsStelian Pop
The AT91CAP9 revC CPU has a few differences over the previous, revB CPU which was distributed in small quantities only (revA was an internal Atmel product only). The revC silicon needs a special initialisation sequence to switch from the internal (imprecise) RC oscillator to the external 32k clock. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10AT91SAM9RLEK: hook up the ATMEL LCD driverStelian Pop
This patch makes the necessary adaptations (PIO configurations and defines in config header file) to hook up the Atmel LCD driver to the AT91SAM9RLEK board. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10AT91SAM9263EK: hook up the ATMEL LCD driverStelian Pop
This patch makes the necessary adaptations (PIO configurations and defines in config header file) to hook up the Atmel LCD driver to the AT91SAM9263EK board. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10AT91SAM9261EK: hook up the ATMEL LCD driverStelian Pop
This patch makes the necessary adaptations (PIO configurations and defines in config header file) to hook up the Atmel LCD driver to the AT91SAM9261EK board. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10AT91CAP9ADK: hook up the ATMEL LCD driverStelian Pop
This patch makes the necessary adaptations (PIO configurations and defines in config header file) to hook up the Atmel LCD driver to the AT91CAP9ADK board. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10AT91SAM9RLEK supportStelian Pop
This patch adds support for the AT91SAM9RL chip and the AT91SAM9RLEK board. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10AT91SAM9263EK supportStelian Pop
This patch adds support for the AT91SAM9263 chip and the AT91SAM9263EK board. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10AT91SAM9261EK supportStelian Pop
This patch adds support for the AT91SAM9261 chip and the AT91SAM9261EK board. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10AT91SAM9260EK: Handle 8 or 16 bit NANDStelian Pop
The Atmel boards can handle 8 or 16 bit NAND memories. This patch makes the support configurable in the board config header file (CFG_NAND_DBW_8 or CFG_NAND_DBW_16). Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10AT91CAP9ADK: Handle 8 or 16 bit NANDStelian Pop
2008-05-10Use a common u-boot.lds file across all AT91CAP9/AT91SAM9 platformsStelian Pop
All the AT91CAP9/AT91SAM9 boards have the same linker script. The patch below avoids the duplication of u-boot.lds by putting the file in the cpu directory instead of the board one. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10Add proper copyright notices in Atmel boards MakefilesStelian Pop
The Makefiles for the AT91CAP9/AT91SAM9 boards have an incomplete copyright notice. This patch adds the missing pieces. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10Add copyright information in Atmel boards partition.cStelian Pop
When Ulf did the dataflash.c cleanup, he didn't add his copyright on the new created files. This patch fixes the problem. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10Update origin and copyright information in arch-at91sam9 header filesStelian Pop
When doing the AT91CAP9/AT91SAM9 port, a number of header files were copied from the Linux kernel sources. This patch explicitly specifies this origin for all the copied headers, and for those missing copyright information, adds it. Additionaly, the header file 'at91sam926x_mc.h' has been superceeded in the latest kernel sources by 'at91sam9_smc.h'. The copyright information has been confirmed by the AT91 Linux kernel maintainer, Andrew Victor <avictor.za@gmail.com>. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10Fix @ -> <at> substitutionStelian Pop
When applying the AT91CAP9 patches upstream, something transformed the '@' character into the ' <at> ' sequence. The patch below restores the original form in all the places where it has been modified (the AT91CAP9 files, the AT91SAM9260 files which were copied from AT91CAP9, and a couple of other files where the ' <at> ' sequence was present). Signed-off-by: Stelian Pop <stelian@popies.net>
2008-05-08Fix @ -> <at> substitutionStelian Pop
When applying the AT91CAP9 patches upstream, something transformed the '@' character into the ' <at> ' sequence. The patch below restores the original form in all the places where it has been modified (the AT91CAP9 files, the AT91SAM9260 files which were copied from AT91CAP9, and a couple of other files where the ' <at> ' sequence was present). Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
