path: root/board/atmel
2012-09-30Merge remote-tracking branch 'u-boot/master'Albert ARIBAUD
2012-09-13at91sam9x5: set default EBI I/O drive configuration.Wu, Josh
This patch configure at91sam9x5's EBI drive I/O. Without this, When SD card boot, the nand flash read/write are not stable. Which will cause kernel MTD test fail (Since mainline kernel doesn't configure the EBI register). Signed-off-by: Josh Wu <josh.wu@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-09-13avr32: add atngw100mkii boardAndreas Bießmann
This patch is derived from an older patch provided by atmel in its buildroot-avr32-v3.0.0.tar.bz2 Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no>
2012-09-01at91: 9x5: change SMC config timing that both works for PMECC & non-PMECC.Wu, Josh
Signed-off-by: Josh Wu <josh.wu@atmel.com> Tested-by: voice.shen@atmel.com Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-09-01arm:at91-boards: remove console_init_f where unnecessaryAndreas Bießmann
A lot of at91 boards have the console_init_f in board_init. This is useless cause it was called before by generic code in lib/board.c. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> cc: Jens Scharsig <esw@bus-elektronik.de> cc: Stelian Pop <stelian@popies.net> cc: Sedji Gaouaou<sedji.gaouaou@atmel.com> cc: Albin Tonnerre <albin.tonnerre@free-electrons.com> cc: Eric Benard <eric@eukrea.com> Tested-by: voice.shen@atmel.com Tested-by: voice.shen@atmel.com Acked-by: Jens Scharsig (BuS Elektronik) <esw@bus-elektronik.de> Tested-by: Jens Scharsig (BuS Elektronik) <esw@bus-elektronik.de>
2012-09-01at91sam9263ek: remove unnecessary console_init_fAndreas Bießmann
Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> cc: Stelian Pop <stelian@popies.net>
2012-09-01arm : at91sam9x5 : fix a small bug for NANDBo Shen
fix a bug: when not boot from NAND, the NAND flash can not be detected. Using this to fix it Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-09-01arm : Atmel : add at91sam9x5ek board supportBo Shen
Add at91sam9x5ek board support, this board support the following SoCs AT91SAM9G15, AT91SAM9G25, AT91SAM9G35, AT91SAM9X25, AT91SAM9X35 Using at91sam9x5ek_nandflash to configure for the board Now only supports NAND with software ECC boot up Signed-off-by: Bo Shen <voice.shen@atmel.com> [move MAINTAINERS entry to right place] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-07-07AT91SAM9*: Change kernel address in dataflash to match u-boot's sizeAlexandre Belloni
On at91sam platforms, u-boot grew larger than the allocated size in dataflash, the layout was: bootstrap 0x00000000 ubootenv 0x00004200 uboot 0x00008400 kernel 0x00042000 fs 0x00252000 u-boot with the defconfig doesn't seem to fit in 0x42000 - 0x8400 = 0x39C00 bytes anymore. Now, the layout is: bootstrap 0x00000000 ubootenv 0x00004200 uboot 0x00008400 kernel 0x00084000 fs 0x00294000 Signed-off-by: Alexandre Belloni <alexandre.belloni@piout.net> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-07-07Fix: broken boot message at serial line on AT91SAM9263-EK boardesw@bus-elektronik.de
Signed-off-by: Jens Scharsig (BuS Elektronik) <esw@bus-elektronik.de> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2011-11-29Fix Stelian's email addressStelian Pop
Change my old email address which is no longer valid. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-09-13led: remove camel casing of led identifiers globallyJason Kridner
Result of running the following command to address Wolfgang's comment about camel case: for file in `find . | grep '\.[chS]$'`; do perl -i -pe 's/(green|yellow|red|blue)_LED_(on|off)/$1_led_$2/g' $file; done Discussion: http://patchwork.ozlabs.org/patch/84988/ Signed-off-by: Jason Kridner <jkridner@beagleboard.org> Signed-off-by: Joel A Fernandes <agnel.joel@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-04ARM: remove broken "at91rm9200dk" boardWolfgang Denk
2011-09-04ARM: remove broken "at91cap9adk" boardWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stelian Pop <stelian.pop@leadtechdesign.com>
2011-09-03atmel: Update support of board AT91SAM9M10G45-EK to new styleThomas Petazzoni
Based on earlier work by Alex Waterman <awaterman@dawning.com>. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
2011-08-03AT91: Makes AT91SAM9263-EK build correctly against u-boot-atmel/masterXu, Hong
Rework for AT91SAM9263-EK, makes it build again. Based on the work for AT91SAM9260-EK. Signed-off-by: Hong Xu <hong.xu@atmel.com> Signed-off-by: Reinhard Meyer <uboot@emk-elektronik.de>
2011-08-03AT91: Board fix for AT91SAM9261-EKXu, Hong
Fix board part of AT91SAM9261-EK according to the new scheme Signed-off-by: Hong Xu <hong.xu@atmel.com> Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2011-08-03AT91: Makes AT91SAM9RL-EK build correctly against u-boot-atmel/masterXu, Hong
Rework for AT91SAM9RL-EK, makes it build again. Based on the work for AT91SAM9260-EK. V4: added changes to MAKEALL Signed-off-by: Hong Xu <hong.xu@atmel.com> Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2011-07-17Remove volatile qualifier in get_ram_size() callsAlbert ARIBAUD
Checkpatch.pl complains about the volatile qualifier in calls to get_ram_size(). Remove this qualifier in the prototype and in the calls where it is useless, and leave it only in the function body where it is needed. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2011-07-16Timer: Fix misuse of ARM *timer_masked() functions outside arch/armGraeme Russ
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2011-07-04atstk100x: switch to common cfi driverAndreas Bießmann
This patch removes the board implemenatation for flash driver which can now safely switched to the common cfi driver. Compile tested for all atstk100x boards, runtime tested on atstk1002. Signed-off-by: Andreas Bießmann <biessmann@corscience.de>
2011-07-04at91rm9200ek: use atmel_usartAndreas Bießmann
2011-06-21AT91 rework: fix at91sam(9260/9g20/9xe)ek board port to build again:Reinhard Meyer
Make ATMEL's at91sam9260/9g20/9xe-ek boards build again Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2011-06-21update arm/at91rm9200 work with rework rework110202Jens Scharsig
* convert at91rm9200ek and eb_cpux9k2 board to ATMEL_xxx name scheme * Fix: timer.c compile error io.h not found with arm/at91rm9200 * update arm920t/at91 to ATMEL_xxx name scheme * update arm920t/at91 soc lib * update at91_emac driver Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de> Tested-by: Andreas Bießmann <andreas.devel@gmail.com>
2011-05-18atstk100x: move CONFIG_SYS_TEXT_BASE to headerAndreas Bießmann
2011-05-18atngw100: move CONFIG_SYS_TEXT_BASE to headerAndreas Bießmann
2011-05-18avr32: use single linker scriptAndreas Bießmann
This patch move the atstk100x linker script to $(CPUDIR) and delete other pure copies of this file in each board directory. Signed-off-by: Andreas Bießmann <biessmann@corscience.de>
2011-05-18avr32/config.mk: simplify PLATFORM_RELFLAGSAndreas Bießmann
This patch removes PLATFORM_RELFLAGS from board specific config.mk files and define them in arch specific config.mk file. Signed-off-by: Andreas Bießmann <biessmann@corscience.de>
2011-05-18avr32: fix linkingAndreas Bießmann
This patch fixes following error: ---8<--- avr32-linux-ld: --gc-sections and -r may not be used together --->8--- Since 8aba9dceebb14144e07d19593111ee3a999c37fc all avr32 boards are broken due to linking error as seen above. Signed-off-by: Andreas Bießmann <biessmann@corscience.de>
2011-05-18avr32: fixup definitions to ATMEL_BASE_xxxAndreas Bießmann
2011-04-30Handle most LDSCRIPT setting centrallyScott Wood
Currently, some linker scripts are found by common code in config.mk. Some are found using CONFIG_SYS_LDSCRIPT, but the code for that is sometimes in arch config.mk and sometimes in board config.mk. Some are found using an arch-specific rule for looking in CPUDIR, etc. Further, the powerpc config.mk rule relied on CONFIG_NAND_SPL when it really wanted CONFIG_NAND_U_BOOT -- which covered up the fact that not all NAND_U_BOOT builds actually wanted CPUDIR/u-boot-nand.lds. Replace all of this -- except for a handful of boards that are actually selecting a linker script in a unique way -- with centralized ldscript finding. If board code specifies LDSCRIPT, that will be used. Otherwise, if CONFIG_SYS_LDSCRIPT is specified, that will be used. If neither of these are specified, then the central config.mk will check for the existence of the following, in order: $(TOPDIR)/board/$(BOARDDIR)/u-boot-nand.lds (only if CONFIG_NAND_U_BOOT) $(TOPDIR)/$(CPUDIR)/u-boot-nand.lds (only if CONFIG_NAND_U_BOOT) $(TOPDIR)/board/$(BOARDDIR)/u-boot.lds $(TOPDIR)/$(CPUDIR)/u-boot.lds Some boards (sc3, cm5200, munices) provided their own u-boot.lds that were dead code, because they were overridden by a CPUDIR u-boot.lds under the old powerpc rules. These boards' own u-boot.lds have bitrotted and no longer work -- these lds files have been removed. Signed-off-by: Scott Wood <scottwood@freescale.com> Tested-by: Graeme Russ <graeme.russ@gmail.com>
2011-03-27rename _end to __bss_end__Po-Yu Chuang
Currently, _end is used for end of BSS section. We want _end to mean end of u-boot image, so we rename _end to __bss_end__ first. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2010-12-07at91rm9200ek: add configure target for RAM bootAndreas Bießmann
This patch also removes now unnecessary config.mk in board directory and make usage of new features in boards.cfg. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2010-10-19at91rm9200ek: convert to at91Andreas Bießmann
This patch removes some functionality from at91rm9200ek board but the remaining functionality does now work with newer at91 code and arm-relocation. Currently missing features are: - dataflash booting (due to missing HW for testing) - MMC/SD-Card - first stage bootloader support is completely removed (not needed for NOR) Cause this board was (some days ago) reference for all at91rm9200 based boards this should be a good starting point to convert all remaining at91rm9200 borads to at91 code. Aside from that this is a good base to get some drivers between at91sam/at91rm/avr32 merged. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-09-03avr32: Add simple paging supportHaavard Skinnemoen
Use the MMU hardware to set up 1:1 mappings between physical and virtual addresses. This allows us to bypass the cache when accessing the flash without having to do any physical-to-virtual address mapping in the CFI driver. The virtual memory mappings are defined at compile time through a sorted array of virtual memory range objects. When a TLB miss exception happens, the exception handler does a binary search through the array until it finds a matching entry and loads it into the TLB. The u-boot image itself is covered by a fixed TLB entry which is never replaced. This makes the 'saveenv' command work again on ATNGW100 and other boards using the CFI driver, hopefully without breaking any rules. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2010-09-03avr32: Use uncached() macro to get an address for SDRAM initHaavard Skinnemoen
The paging system which is required to set up caching properties has not yet been initialized when the SDRAM is initialized. So when the map_physmem() function is converted to return the physical address unchanged, the SDRAM initialization will break on some boards. The avr32-specific uncached() macro will return an address which will always cause uncached accessed to be made. Since this happens in the board code, using avr32-specific features should be ok, and will allow the SDRAM initialization to keep working. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2010-07-12Write MAC address automatically on MACB-based boardsBen Warren
Also, remove all calls to eth_init() in boards that use MACB Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-06-30USB OHCI support for at91sam9g45 SoCSergey Matyukevich
Add USB OHCI support for at91sam9g45ekes/at91sam9m10g45ek boards. Note that according to errata from Atmel, OHCI is not operational on the first revision of at91sam9g45 chip. So this patch enables OHCI support for later revisions. Signed-off-by: Sergey Matyukevich <geomatsi@gmail.com>
2010-06-29avr32: fix linking of atstk100x and favr32 boardsAndreas Bießmann
When building some avr32 boards out of tree (e.g. O=..) the linker script could not be found. This patch references the linker script in source tree. Signed-off-by: Andreas Bießmann <biessmann@corscience.de>
2010-03-07ARM change name of defines for AT91 arm926ejsAchim Ehrlich
Configuration defines should be preceeded with CONFIG_SYS_. Renamed some at91 specific defines to conform to this naming convention: AT91_CPU_NAME to CONFIG_SYS_AT91_CPU_NAME AT91_MAIN_CLOCK to CONFIG_SYS_AT91_MAIN_CLOCK Signed-off-by: Achim Ehrlich <aehrlich@taskit.de>
2010-02-12update at91sam9263ek board to new SoC accessJens Scharsig
* convert at91sam9263ek board to use c stucture SoC access * change gpio access to at91_gpio syntax Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
2010-01-31new at91_emac network driver (NET_MULTI api)Jens Scharsig
* add's at91_emac (AT91RM9200) network driver (NET_MULTI api) * enable driver with CONFIG_DRIVER_AT91EMAC * generic PHY initialization * modify AT91RM9200 boards to use NET_MULTI driver * the drivers has been tested with LXT971 Phy and DM9161 Phy at MII and RMII interface Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-12-07at91sam9261ek.c: fix minor coding style issue.Wolfgang Denk
2009-09-01at91sam9260/afeb9260: Fix SPI initializationAlbin Tonnerre
Commit 7ebafb7ec1a0285af8380623c009576f92583b98 introduced a mistake in the spi init function call for those boards. This patch fixes this. Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com>
2009-07-12at91: Introduction of at91sam9g10 SOC.Sedji Gaouaou
AT91sam9g10 is an ARM 926ej-s SOC. It is an evolution of the at91sam9261 with a faster clock speed: 266/133MHz. Signed-off-by: Sedji Gaouaou <sedji.gaouaou@atmel.com>
2009-07-12at91: Introduction of at91sam9g45 SOC.Sedji Gaouaou
AT91sam9g45 series is an ARM 926ej-s SOC family clocked at 400/133MHz. It embeds USB high speed host and device, LCD, DDR2 RAM, and a full set of peripherals. The first board that embeds at91sam9g45 chip is the AT91SAM9G45-EKES. On the board you can find 2 USART, USB high speed, a 480*272 LG lcd, ethernet, gpio/joystick/buttons. Signed-off-by: Sedji Gaouaou <sedji.gaouaou@atmel.com>
2009-07-06at91sam9260/9263: add back up for the rst(reset controller).Sedji Gaouaou
On the boards at91sam9260ek, at91sam9263ek and afed9260, the rstc register was set to 0 after being set to 500 ms for the PHY reset. Do backup the old reset length and restore it after the MACB initialisation. Signed-off-by: Sedji Gaouaou <sedji.gaouaou@atmel.com> Signed-off-by: Stelian Pop <stelian@popies.net>
