path: root/board/atmel
2014-06-11cosmetic: atmel: replace old style struct initJeroen Hofstee
This prevents some warnings when building with clang. cc:: andreas.devel@googlemail.com Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-05-27ARM: at91sam9m10g45ek: enable mci0 supportWu, Josh
Also we enable the mmc command in configuration file. As both CONFIG_CMD_MMC and CONFIG_CMD_USB use the CONFIG_DOS_PARTITION, so remove the redundant CONFIG_DOS_PARTITION definition. Signed-off-by: Josh Wu <josh.wu@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-05-27ARM: atmel: enable SPL on sama5d3_xplained boardBo Shen
It supports boot from NAND and SD/MMC card. Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-03-10Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2014-03-09arm: atmel: sama5d3: add nand spl boot supportBo Shen
Add NAND SPL boot support with hardware PMECC. Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-03-09arm: atmel: sama5d3: add spi spl boot supportBo Shen
Add SPI SPL boot support for sama5d3xek board. Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-03-09ARM: atmel: add sama5d3 Xplained board supportBo Shen
Add sama5d3 Xplained board support which use Atmel SAMA5D36 SoC. Now it supports boot from NAND flash and SD/MMC card. Features support: - NAND flash - SD/MMC card - Two USB hosts - Ethernet (one GMAC, one EMAC) Signed-off-by: Bo Shen <voice.shen@atmel.com> [reorder boards.cfg] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-03-09at91sam9263ek: add mmc supportAndreas Henriksson
Add support for using the Atmel MCI driver on at91sam9263ek. This change is modeled after the existing at91sam9260ek support. Please note that this hooks up slot1 (MCI1) for SD. Not both. Tested with at91bootstrap and u-boot on dataflash in slot 0 and fat-formatted 8GB SDHC in slot 1 on first revision at91sam9263ek (which must use dataflash in slot0 to boot). CONFIG_ATMEL_MCI_PORTB not tested. Signed-off-by: Andreas Henriksson <andreas.henriksson@endian.se> [remove empty line] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-03-04sizes.h - consolidate for all architecturesAlexey Brodkin
Copied from Linux sources "include/linux/sizes.h" commit 413541dd66d51f791a0b169d9b9014e4f56be13c Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Tom Rini <trini@ti.com> Cc: Stefan Roese <sr@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Acked-by: Tom Rini <trini@ti.com> Acked-by: Stefan Roese <sr@denx.de> [trini: Add bcm Kona platforms to the patch] Signed-off-by: Tom Rini <trini@ti.com>
2013-12-17arm: atmel: at91sam9x5: cleanup cs configure for spiBo Shen
As the cs for spi is worked in gpio mode, so no need to configure it as peripheral and then configure to gpio. Configure it to gpio directly. Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-12-10Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: arch/arm/cpu/armv7/rmobile/Makefile doc/README.scrapyard Needed manual fix: arch/arm/cpu/armv7/omap-common/Makefile board/compulab/cm_t335/u-boot.lds
2013-12-01arm926ejs, at91: add common phy_reset functionHeiko Schocher
add common phy reset code into a common function. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Bo Shen <voice.shen@atmel.com> Cc: Jens Scharsig <esw@bus-elektronik.de> Cc: Sergey Lapin <slapin@ossfans.org> Cc: Stelian Pop <stelian@popies.net> Cc: Albin Tonnerre <albin.tonnerre@free-electrons.com> Cc: Eric Benard <eric@eukrea.com> Cc: Markus Hubig <mhubig@imko.de> Acked-by: Jens Scharsig (BuS Elektronik) <esw@bus-elektronik.de> Tested-by: Jens Scharsig (BuS Elektronik) <esw@bus-elektronik.de> Tested-by: Bo Shen <voice.shen@atmel.com> Acked-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-12-01arm: atmel: sama5d3: spl boot from fat fs SD cardBo Shen
Enable Atmel sama5d3xek boart spl boot support, which can load u-boot from SD card with FAT file system. Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-12-01arm: atmel: sama5d3: early enable PIO peripheralsBo Shen
Enable the PIO peripherals early than other peripherals. Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-11-21sama5d3xek: support larger than 4G nand flashWu, Josh
2013-11-09Merge branch 'iu-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: arch/arm/cpu/arm926ejs/mxs/Makefile board/compulab/cm_t35/Makefile board/corscience/tricorder/Makefile board/ppcag/bg0900/Makefile drivers/bootcount/Makefile include/configs/omap4_common.h include/configs/pdnb3.h Makefile conflicts are due to additions/removals of object files on the ARM branch vs KBuild introduction on the main branch. Resolution consists in adjusting the list of object files in the main branch version. This also applies to two files which are not listed as conflicting but had to be modified: board/compulab/common/Makefile board/udoo/Makefile include/configs/omap4_common.h conflicts are due to the OMAP4 conversion to ti_armv7_common.h on the ARM side, and CONFIG_SYS_HZ removal on the main side. Resolution is to convert as this icludes removal of CONFIG_SYS_HZ. include/configs/pdnb3.h is due to a removal on ARM side. Trivial resolution is to remove the file. Note: 'git show' will also list two files just because they are new: include/configs/am335x_igep0033.h include/configs/omap3_igep00x0.h
2013-11-04arm: atmel: at91sam9n12ek: add usb host supportBo Shen
Add usb host support for at91sam9n12ek board. Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-10-31avr32: convert makefiles to Kbuild styleMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Andreas Bießmann <andreas.devel@googlemail.com>
2013-09-24ARM: atmel: add RNDIS gadget supportBo Shen
Add RNDIS gadget support to test atmel usba udc driver Signed-off-by: Bo Shen <voice.shen@atmel.com>
2013-08-22arm: atmel: remove the config.mk fileBo Shen
remove the config.mk file move text base define to board config file for following boards - at91sam9m10g45ek - at91sam9x5ek Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-08-22arm: atmel: add gmac support for sama5d3xek boardBo Shen
add gmac support for sama5d3xek board, the gmac embedded in: - sama5d33, sama5d34, sama5d35 Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-07-22arm: at91sam9n12: change EBI IO to high drive modeBo Shen
As both the DDR SDRAM and NAND flash connect to EBI on at91sam9n12 and share the lower 8 bits data line. If use low drive of the data line, it will cause DDR data access corrupt in lower address, so change the data line to high drive mode This will fix the Linux kernel boot issue when use Lower address Signed-off-by: Bo Shen <voice.shen@atmel.com> Acked-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-06-24ARM: at91sam9n12: add network support with ksz8851_16mllBo Shen
add network support with ksz8851_16mll on at91sam9n12ek board Signed-off-by: Bo Shen <voice.shen@atmel.com> Acked-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-05-21ARM: atmel: add sama5d3xek supportBo Shen
Add sama5d3xek support with following feature - boot from NAND flash, PMECC support, 4bit ECC @ 512 bytes sector - boot from SPI flash support - boot from SD card support - LCD support - EMAC support - USB OHCI support Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-05-12at91sam9260ek: move board id setup to config headerAndreas Bießmann
Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Acked-by: Bo Shen <voice.shen@atmel.com>
2013-05-12arm: at91: enable mci support for at91sam9g20ek.Wu, Josh
2013-05-12arm: at91: add at91sam9n12ek board supportWu, Josh
Add support for following features: - nand boot, with PMECC 2bit ECC for 512 bytes sector - SPI flash boot - SD card boot - LCD support Signed-off-by: Josh Wu <josh.wu@atmel.com> [fix -Wimplicit-function-declaration for at91_lcd_hw_init()] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-02-19ARM: atmel: add at91sam9g20ek_2mmc nand boot supportBo Shen
Add at91sam9g20_2mmc nand boot support. on this board, there is no dataflash, so disable it change one commet for at91sam9g20ek board Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-12-09at91sam9x5: enable USB support for 9x5ek board.Richard Genoud
Signed-off-by: Richard Genoud <richard.genoud@gmail.com> Acked-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-10-17ARM: at91sam9x5: enable MCI0 support for 9x5ek board.Wu, Josh
2012-09-30Merge remote-tracking branch 'u-boot/master'Albert ARIBAUD
2012-09-13at91sam9x5: set default EBI I/O drive configuration.Wu, Josh
This patch configure at91sam9x5's EBI drive I/O. Without this, When SD card boot, the nand flash read/write are not stable. Which will cause kernel MTD test fail (Since mainline kernel doesn't configure the EBI register). Signed-off-by: Josh Wu <josh.wu@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-09-13avr32: add atngw100mkii boardAndreas Bießmann
This patch is derived from an older patch provided by atmel in its buildroot-avr32-v3.0.0.tar.bz2 Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no>
2012-09-01at91: 9x5: change SMC config timing that both works for PMECC & non-PMECC.Wu, Josh
Signed-off-by: Josh Wu <josh.wu@atmel.com> Tested-by: voice.shen@atmel.com Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-09-01arm:at91-boards: remove console_init_f where unnecessaryAndreas Bießmann
A lot of at91 boards have the console_init_f in board_init. This is useless cause it was called before by generic code in lib/board.c. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> cc: Jens Scharsig <esw@bus-elektronik.de> cc: Stelian Pop <stelian@popies.net> cc: Sedji Gaouaou<sedji.gaouaou@atmel.com> cc: Albin Tonnerre <albin.tonnerre@free-electrons.com> cc: Eric Benard <eric@eukrea.com> Tested-by: voice.shen@atmel.com Tested-by: voice.shen@atmel.com Acked-by: Jens Scharsig (BuS Elektronik) <esw@bus-elektronik.de> Tested-by: Jens Scharsig (BuS Elektronik) <esw@bus-elektronik.de>
2012-09-01at91sam9263ek: remove unnecessary console_init_fAndreas Bießmann
Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> cc: Stelian Pop <stelian@popies.net>
2012-09-01arm : at91sam9x5 : fix a small bug for NANDBo Shen
fix a bug: when not boot from NAND, the NAND flash can not be detected. Using this to fix it Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-09-01arm : Atmel : add at91sam9x5ek board supportBo Shen
Add at91sam9x5ek board support, this board support the following SoCs AT91SAM9G15, AT91SAM9G25, AT91SAM9G35, AT91SAM9X25, AT91SAM9X35 Using at91sam9x5ek_nandflash to configure for the board Now only supports NAND with software ECC boot up Signed-off-by: Bo Shen <voice.shen@atmel.com> [move MAINTAINERS entry to right place] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-07-07AT91SAM9*: Change kernel address in dataflash to match u-boot's sizeAlexandre Belloni
On at91sam platforms, u-boot grew larger than the allocated size in dataflash, the layout was: bootstrap 0x00000000 ubootenv 0x00004200 uboot 0x00008400 kernel 0x00042000 fs 0x00252000 u-boot with the defconfig doesn't seem to fit in 0x42000 - 0x8400 = 0x39C00 bytes anymore. Now, the layout is: bootstrap 0x00000000 ubootenv 0x00004200 uboot 0x00008400 kernel 0x00084000 fs 0x00294000 Signed-off-by: Alexandre Belloni <alexandre.belloni@piout.net> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-07-07Fix: broken boot message at serial line on AT91SAM9263-EK boardesw@bus-elektronik.de
Signed-off-by: Jens Scharsig (BuS Elektronik) <esw@bus-elektronik.de> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2011-11-29Fix Stelian's email addressStelian Pop
Change my old email address which is no longer valid. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-09-13led: remove camel casing of led identifiers globallyJason Kridner
Result of running the following command to address Wolfgang's comment about camel case: for file in `find . | grep '\.[chS]$'`; do perl -i -pe 's/(green|yellow|red|blue)_LED_(on|off)/$1_led_$2/g' $file; done Discussion: http://patchwork.ozlabs.org/patch/84988/ Signed-off-by: Jason Kridner <jkridner@beagleboard.org> Signed-off-by: Joel A Fernandes <agnel.joel@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-04ARM: remove broken "at91rm9200dk" boardWolfgang Denk
2011-09-04ARM: remove broken "at91cap9adk" boardWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stelian Pop <stelian.pop@leadtechdesign.com>
