path: root/board/atmel/sama5d3xek/sama5d3xek.c
2013-08-22arm: atmel: add gmac support for sama5d3xek boardBo Shen
add gmac support for sama5d3xek board, the gmac embedded in: - sama5d33, sama5d34, sama5d35 Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-05-21ARM: atmel: add sama5d3xek supportBo Shen
Add sama5d3xek support with following feature - boot from NAND flash, PMECC support, 4bit ECC @ 512 bytes sector - boot from SPI flash support - boot from SD card support - LCD support - EMAC support - USB OHCI support Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
