path: root/board/atmel/at91sam9rlek
2014-10-29kconfig: arm: introduce symbol for ARM CPUsGeorges Savoundararadj
This commit introduces a Kconfig symbol for each ARM CPU: CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136, CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100. Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected for CPU_ARM1176 and CPU_V7. For each target, the corresponding CPU is selected and the definition of SYS_CPU in the corresponding Kconfig file is removed. Also, it removes redundant "string" type in some Kconfig files. Signed-off-by: Georges Savoundararadj <savoundg@gmail.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-06-11cosmetic: atmel: replace old style struct initJeroen Hofstee
This prevents some warnings when building with clang. cc:: andreas.devel@googlemail.com Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2012-09-01arm:at91-boards: remove console_init_f where unnecessaryAndreas Bießmann
A lot of at91 boards have the console_init_f in board_init. This is useless cause it was called before by generic code in lib/board.c. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> cc: Jens Scharsig <esw@bus-elektronik.de> cc: Stelian Pop <stelian@popies.net> cc: Sedji Gaouaou<sedji.gaouaou@atmel.com> cc: Albin Tonnerre <albin.tonnerre@free-electrons.com> cc: Eric Benard <eric@eukrea.com> Tested-by: voice.shen@atmel.com Tested-by: voice.shen@atmel.com Acked-by: Jens Scharsig (BuS Elektronik) <esw@bus-elektronik.de> Tested-by: Jens Scharsig (BuS Elektronik) <esw@bus-elektronik.de>
2012-07-07AT91SAM9*: Change kernel address in dataflash to match u-boot's sizeAlexandre Belloni
On at91sam platforms, u-boot grew larger than the allocated size in dataflash, the layout was: bootstrap 0x00000000 ubootenv 0x00004200 uboot 0x00008400 kernel 0x00042000 fs 0x00252000 u-boot with the defconfig doesn't seem to fit in 0x42000 - 0x8400 = 0x39C00 bytes anymore. Now, the layout is: bootstrap 0x00000000 ubootenv 0x00004200 uboot 0x00008400 kernel 0x00084000 fs 0x00294000 Signed-off-by: Alexandre Belloni <alexandre.belloni@piout.net> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2011-11-29Fix Stelian's email addressStelian Pop
Change my old email address which is no longer valid. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-08-03AT91: Makes AT91SAM9RL-EK build correctly against u-boot-atmel/masterXu, Hong
Rework for AT91SAM9RL-EK, makes it build again. Based on the work for AT91SAM9260-EK. V4: added changes to MAKEALL Signed-off-by: Hong Xu <hong.xu@atmel.com> Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-03-07ARM change name of defines for AT91 arm926ejsAchim Ehrlich
Configuration defines should be preceeded with CONFIG_SYS_. Renamed some at91 specific defines to conform to this naming convention: AT91_CPU_NAME to CONFIG_SYS_AT91_CPU_NAME AT91_MAIN_CLOCK to CONFIG_SYS_AT91_MAIN_CLOCK Signed-off-by: Achim Ehrlich <aehrlich@taskit.de>
2009-04-16at91sam9/at91cap: improve clock frameworkJean-Christophe PLAGNIOL-VILLARD
calculate dynamically the clock rate and pllb setting for usb Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-03-22at91sam9/at91cap: move nand drivers to drivers/mtd/nandJean-Christophe PLAGNIOL-VILLARD
2009-03-22atmel/at91/boards: compile dataflash partition only when dataflash isJean-Christophe PLAGNIOL-VILLARD
2009-03-22at91sam9/at91cap: move common led management to cpuJean-Christophe PLAGNIOL-VILLARD
2009-03-22at91sam9/at91cap: move common spi initialisation to cpuJean-Christophe PLAGNIOL-VILLARD
2009-03-22at91sam9/at91cap: move common serial initialisation to cpuJean-Christophe PLAGNIOL-VILLARD
2008-11-21AT91: Use AT91_CPU_CLOCK in displaysStelian Pop
Introduce AT91_CPU_CLOCK and use it for displaying the CPU speed in the LCD driver. Also make AT91_MAIN_CLOCK and AT91_MASTER_CLOCK reflect the corresponding board clocks. Signed-off-by: Stelian Pop <stelian@popies.net>
2008-11-07AT91: Replace (undefined) AT91_ID_US* by the board specific values.Stelian Pop
AT91_ID_US0 / AT91_ID_US1 / AT91_ID_US2 were used but never defined. Since they are never used outside the board specific files, they can be replaced by the board specific AT91xxx_ID_US0 / AT91xxx_ID_US1 / AT91xxx_ID_US2. Bug spotted by Jesus Alvarez <jalvarez@micromint.com>. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-10-27lcd: Let the board code show board-specific infoHaavard Skinnemoen
The information displayed when CONFIG_LCD_INFO is set is inherently board-specific, so it should be done by the board code. The current code dealing with this only handles two cases, and is already a horrible mess of #ifdeffery. Yes, this duplicates some code, but it also allows boards to print more board-specific information; this used to be very difficult. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2008-08-13at91: Update board NAND drivers to current API.Scott Wood
2008-07-07Merge branch 'master' of git://www.denx.de/git/u-boot-at91Wolfgang Denk
2008-07-05[AT91SAM9] Fix NAND FLASH timingsPatrice Vilchez
Fix NAND FLASH timings for at91sam9x evaluation kits. New timings are based on application note "NAND Flash Support on AT91SAM9 Microcontrollers" available at http://atmel.com/dyn/resources/prod_documents/doc6255.pdf Signed-off-by: Patrice Vilchez <patice.vilchez@atmel.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Stelian Pop <stelian@popies.net>
2008-05-10AT91SAM9RLEK: hook up the ATMEL LCD driverStelian Pop
This patch makes the necessary adaptations (PIO configurations and defines in config header file) to hook up the Atmel LCD driver to the AT91SAM9RLEK board. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10AT91SAM9RLEK supportStelian Pop
This patch adds support for the AT91SAM9RL chip and the AT91SAM9RLEK board. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
