2010-10-18 | Rename TEXT_BASE into CONFIG_SYS_TEXT_BASE | Wolfgang Denk | |
The change is currently needed to be able to remove the board configuration scripting from the top level Makefile and replace it by a simple, table driven script. Moving this configuration setting into the "CONFIG_*" name space is also desirable because it is needed if we ever should move forward to a Kconfig driven configuration system. Signed-off-by: Wolfgang Denk <wd@denx.de> | |||
2008-05-10 | AT91SAM9RLEK support | Stelian Pop | |
This patch adds support for the AT91SAM9RL chip and the AT91SAM9RLEK board. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> |
