path: root/board/atmel/at91sam9n12ek
2017-09-14configs: at91: Remove CONFIG_SYS_EXTRA_OPTIONS assignmentWenyou Yang
To remove the assignment of CONFIG_SYS_EXTRA_OPTIONS option, which is deprecated, use the CONFIG_XXXX_BOOT options to indicate the boot media, and the SoC is selected by the board. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com>
2017-07-11board: atmel: use get_nand_dev_by_index()Grygorii Strashko
As part of preparation for nand DM conversion the new API has been introduced to remove direct access to nand_info array. So, use it here instead of accessing to nand_info array directly. Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com>
2017-05-09board: at91sam9n12ek: Enable early debug UARTWenyou Yang
Enable the early debug UART to debug problems when an ICE or other debug mechanism is not available. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-09board: at91sam9n12ek: Clean up codeWenyou Yang
Since the introduction of the pinctrl and clk driver and the device tree files, remove unneeded related code from the board file. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-09configs: at91sam9n12ek: Update for DT and DM supportWenyou Yang
Update the configuration files to support the device tree and driver model. The device clock and pins configuration are handled by the clock and the pinctrl drivers respectively. Because the limitation of internal SRAM size, the SPL with driver model can't be supported, disable the SPL option. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-04-13gpio: at91_gpio: remove CPU_HAS_PIO3 macroWenyou Yang
The intention of the removal is the preparation to introduce the new AT91 PIO pinctrl driver. Use the union to make the PIO3 and PIO2's registers be together and make their offset aligned. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-06-03nand: Embed mtd_info in struct nand_chipScott Wood
nand_info[] is now an array of pointers, with the actual mtd_info instance embedded in struct nand_chip. This is in preparation for syncing the NAND code with Linux 4.6, which makes the same change to struct nand_chip. It's in a separate commit due to the large amount of changes required to accommodate the change to nand_info[]. Signed-off-by: Scott Wood <oss@buserror.net>
2016-02-18board: atmel: clean up peripheral clock codeWenyou Yang
Due to introducing the new peripheral clock handle functions, use these functions to reduce duplicated code. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Tested-by: Heiko Schocher <hs@denx.de> [Rebased on current master, fixup for at91rm9200ek] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2016-02-02arm: at91/spl: mpddrc: add struct atmel_mpddrc_configWenyou Yang
Add struct atmel_mpddrc_config to accommodate the mpddrc register configurations, not using the mpddrc register map structure, struct atmel_mpddrc, in order to increase readability and reduce run-time memory use. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
2015-08-21arm: at91: pmc: replace the constant with a define in at91_pmc.hErik van Luijk
To enable the clocks on the at91 boards a constant (0x4) is used. This is replaced with a define in at91_pmc.h (1 << 2). Signed-off-by: Erik van Luijk <evanluijk@interact.nl> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
2015-08-21arm: at91: mpddr: allow multiple DDR controllersErik van Luijk
The mpddr.c depends on ATMEL_BASE_MPDDRC for the base address to configure the controller. This cannot be used when there is more than one controller (i.e. AT91SAM9G45, AT91SAM9M10). Signed-off-by: Erik van Luijk <evanluijk@interact.nl> [remove 'new blank line at EOF'] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2015-04-01ARM: atmel: at91sam9n12ek: enable spl supportBo Shen
Enable SPL support for at91sam9n12ek boards, now it supports boot up from NAND flash, serial flash. Signed-off-by: Bo Shen <voice.shen@atmel.com>
2014-10-29kconfig: arm: introduce symbol for ARM CPUsGeorges Savoundararadj
This commit introduces a Kconfig symbol for each ARM CPU: CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136, CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100. Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected for CPU_ARM1176 and CPU_V7. For each target, the corresponding CPU is selected and the definition of SYS_CPU in the corresponding Kconfig file is removed. Also, it removes redundant "string" type in some Kconfig files. Signed-off-by: Georges Savoundararadj <savoundg@gmail.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-09Merge branch 'iu-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: arch/arm/cpu/arm926ejs/mxs/Makefile board/compulab/cm_t35/Makefile board/corscience/tricorder/Makefile board/ppcag/bg0900/Makefile drivers/bootcount/Makefile include/configs/omap4_common.h include/configs/pdnb3.h Makefile conflicts are due to additions/removals of object files on the ARM branch vs KBuild introduction on the main branch. Resolution consists in adjusting the list of object files in the main branch version. This also applies to two files which are not listed as conflicting but had to be modified: board/compulab/common/Makefile board/udoo/Makefile include/configs/omap4_common.h conflicts are due to the OMAP4 conversion to ti_armv7_common.h on the ARM side, and CONFIG_SYS_HZ removal on the main side. Resolution is to convert as this icludes removal of CONFIG_SYS_HZ. include/configs/pdnb3.h is due to a removal on ARM side. Trivial resolution is to remove the file. Note: 'git show' will also list two files just because they are new: include/configs/am335x_igep0033.h include/configs/omap3_igep00x0.h
2013-11-04arm: atmel: at91sam9n12ek: add usb host supportBo Shen
Add usb host support for at91sam9n12ek board. Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-07-22arm: at91sam9n12: change EBI IO to high drive modeBo Shen
As both the DDR SDRAM and NAND flash connect to EBI on at91sam9n12 and share the lower 8 bits data line. If use low drive of the data line, it will cause DDR data access corrupt in lower address, so change the data line to high drive mode This will fix the Linux kernel boot issue when use Lower address Signed-off-by: Bo Shen <voice.shen@atmel.com> Acked-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-06-24ARM: at91sam9n12: add network support with ksz8851_16mllBo Shen
add network support with ksz8851_16mll on at91sam9n12ek board Signed-off-by: Bo Shen <voice.shen@atmel.com> Acked-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-05-12arm: at91: add at91sam9n12ek board supportWu, Josh
Add support for following features: - nand boot, with PMECC 2bit ECC for 512 bytes sector - SPI flash boot - SD card boot - LCD support Signed-off-by: Josh Wu <josh.wu@atmel.com> [fix -Wimplicit-function-declaration for at91_lcd_hw_init()] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
