path: root/board/atmark-techno
2017-01-28Revert "arm: Remove unregister MACH_TYPE_xxx uses"Tom Rini
This reverts commit 70b26cd057f42c7126088b49d4285955c8a00eae. This is not a strict revert as it is easier to fix board/atmark-techno/armadillo-800eva/armadillo-800eva.c to now the correct name (same value) than to revert that change too. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-01-14arm: Remove unregister MACH_TYPE_xxx usesTom Rini
Before we can sync with the latest mach-types.h file from the Linux Kernel we need to remove some instances of MACH_TYPE_xxx from our sources. As these values have been removed from the canonical upstream source we should not be using them either, so drop. Cc: Tom Warren <twarren@nvidia.com> Cc: Lucas Stach <dev@lynxeye.de> Cc: Luka Perkov <luka@openwrt.org> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Heiko Schocher <hs@denx.de> Cc: Thomas Weber <weber@corscience.de> Cc: Lucile Quirion <lucile.quirion@savoirfairelinux.com> Cc: Matthias Weisser <weisserm@arcor.de> Cc: Suriyan Ramasami <suriyan.r@gmail.com> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Cc: Bo Shen <voice.shen@atmel.com> Cc: Nick Thompson <nick.thompson@gefanuc.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Erik van Luijk <evanluijk@interact.nl> Cc: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2016-08-17ARM: Rmobile: Rename CONFIG_RMOBILE to CONFIG_ARCH_RMOBILENobuhiro Iwamatsu
2015-11-10Various Makefiles: Add SPDX-License-Identifier tagsTom Rini
After consulting with some of the SPDX team, the conclusion is that Makefiles are worth adding SPDX-License-Identifier tags too, and most of ours have one. This adds tags to ones that lack them and converts a few that had full (or in one case, very partial) license blobs into the equivalent tag. Cc: Kate Stewart <kstewart@linuxfoundation.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2014-08-30rmobile: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the Rmobile board select menu to rmobile/Kconfig. Consolidate also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="rmobile"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2013-10-14Coding Style cleanup: remove trailing empty linesWolfgang Denk
2012-10-03rmobile: armadillo-800eva: Change init function of SCIFA1Nobuhiro Iwamatsu
This initializes GPIO, without using PFC framework in board_early_init_f function. It is because it cannot initialize normally when PFC is used. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-10-03arm: rmobile: armadillo-800eva Remove board_eth_initNobuhiro Iwamatsu
2012-10-03arm: rmobile: Add support for ATMARK-TECHNO Armadillo-800EVA boardHideyuki Sano
The Armadillo-800EVA board has Renesas R-Mobile R8A7740, 512MB DDR3-SDRAM, Ethernet, and more. This patch supports the following functions: - 512MB DDR3-SDRAM - Serial console (SCIF) - Ethernet MAC(MII) & PHY(SMSC) Signed-off-by: Hideyuki Sano <hideyuki.sano.dn@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
