path: root/board/at91rm9200dk
2003-06-16* Patch by Nicolas Lacressonniere, 11 Jun 2003:wdenk
Modifications for Atmel AT91RM9200DK ARM920T based development kit - Add Atmel DataFlash support for reading and writing. - Add possibility to boot a Linux from DataFlash with BOOTM command. - Add Flash detection on Atmel AT91RM9200DK (between Atmel AT49BV1614 and AT49BV1614A flashes) - Replace old Ethernet PHY layer functions - Change link address * Patch by Frank Smith, 9 Jun 2003: use CRIT_EXCEPTION for machine check on 4xx * Patch by Detlev Zundel, 13 Jun 2003: added implementation of the "carinfo" command in cmd_immap.c
2003-03-31* Patch by Arun Dharankar, 24 Mar 2003:wdenk
- add threads / scheduler example code * Add patches by Robert Schwebel, 31 Mar 2003: - add ctrl-c support for kermit download - align bdinfo output on ARM * Add CPU ID, version, and clock speed for INCA-IP
2003-03-26* Patch by Rick Bronson, 16 Mar 2003:wdenk
Add support for Atmel AT91RM9200DK w/NAND * Patches by Robert Schwebel, 19 Mar 2003: - use arm-linux-gcc as default compiler for ARM - fix i2c fixup code - fix missing baudrate setting - added $loadaddr / CFG_LOAD_ADDR support to loadb - moved "ignoring trailing characters" _before_ u-boot wants to print out diagnostics messages; removes bogus characters at the end of transmission * Patch by John Zhan, 18 Mar 2003: Add support for SinoVee Microsystems SC8xx boards * Patch by Rolf Offermanns, 21 Mar 2003: ported the dnp1110 related changes from the current armboot cvs to current u-boot cvs. smc91111 does not work. problem marked in smc91111.c, grep for "FIXME". * Patch by Brian Auld, 25 Mar 2003: Add support for STM flash chips on ebony board * Add PCI support for MPC8250 Boards (PM825 module) * Patch by Stefan Roese, 25 Mar 2003:
