path: root/board/astro/mcf5373l/Makefile
2013-11-01m68k: convert makefiles to Kbuild styleMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Jason Jin <Jason.jin@freescale.com>
2010-03-24add ASTRO MCF5373L boardWolfgang Wegner
This patch adds support for ASTRO board(s) based on MCF5373L. Signed-off-by: Wolfgang Wegner <w.wegner@astro-kom.de>
