path: root/board/armltd
2015-05-13ARM: Clean up CONFIG_ARMV7_NONSEC/VIRT/PSCI conditionsJan Kiszka
CONFIG_ARMV7_VIRT depends on CONFIG_ARMV7_NONSEC, thus doesn't need to be taken into account additionally. CONFIG_ARMV7_PSCI is only set on boards that support CONFIG_ARMV7_NONSEC, and it only works on those. CC: Tang Yuantian <Yuantian.Tang@freescale.com> CC: York Sun <yorksun@freescale.com> CC: Steve Rae <srae@broadcom.com> CC: Andre Przywara <andre.przywara@linaro.org> Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Tested-by: Alison Wang <alison.wang@freescale.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-04-23integrator: stop zeroing the gd flagsLinus Walleij
This assignment conflicts with code that add flags with gd->flags |= FOO prior to the execution of this function. Seems like a historical artifact and creates bugs with early alloc(). Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-23ARM: integrator: move board select into mach-integrator/KconfigMasahiro Yamada
The board/SoC select menu in arch/arm/Kconfig is still cluttered. Add ARCH_INTEGRATOR into arch/arm/Kconfig and move the board select under arch/arm/mach-integrator. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Linus Walleij <linus.walleij@linaro.org>
2015-04-23vexpress64: use DM for all vexpress64 boardsLinus Walleij
Commit d8bafe1310487ba0e0785997726b4792072178d3 "ARMv8: enable DM in vexpress64 board" only enabled DM for the simulated vexpress64 board (FVP) with the hardcoded clock value for the simulated board, causing a console regression on the Juno board which was using a different clock setting. Fix this by enabling DM for all vexpress64 boards, defining the clock frequency per-board, deleting the static array of PL01x ports from the config file and relying solely on the port defined in the boardfile using platform data. Cc: David Feng <fenghua@phytium.com.cn> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-04-03Merge branch 'master' of git://git.denx.de/u-boot-tegraTom Rini
Conflicts: board/armltd/vexpress64/vexpress64.c Signed-off-by: Tom Rini <trini@konsulko.com>
2015-03-28vexpress64: cut config and defaults for unclear variantLinus Walleij
This variant that is neither FVP / Base Model or Juno Versatile Express 64bit is confusing. Get rid of it unless someone can point out what machine that really is. Seems to be an evolutional artifact in the config base. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-03-28vexpress64: remove board late init, use smhloadLinus Walleij
This removes the kludgy late board init from the FVP simulator version of Versatile Express 64bit (ARMv8), and replace it with a default boot command using the new smhload command to load the files using semihosting. Tested on the Foundation Model. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-03-27ARMv8: enable DM in vexpress64 boardDavid Feng
Signed-off-by: David Feng <fenghua@phytium.com.cn>
2015-03-24remove unnecessary version.h includesRob Herring
Various files are needlessly rebuilt every time due to the version and build time changing. As version.h is not actually needed, remove the include. Signed-off-by: Rob Herring <robh@kernel.org> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Stefano Babic <sbabic@denx.de> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Marek Vasut <marex@denx.de> Cc: Tom Warren <twarren@nvidia.com> Cc: Michal Simek <monstr@monstr.eu> Cc: Macpaul Lin <macpaul@andestech.com> Cc: Wolfgang Denk <wd@denx.de> Cc: York Sun <yorksun@freescale.com> Cc: Stefan Roese <sr@denx.de> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Cc: Simon Glass <sjg@chromium.org> Cc: Philippe Reynes <tremyfr@yahoo.fr> Cc: Eric Jarrige <eric.jarrige@armadeus.org> Cc: "David Müller" <d.mueller@elsoft.ch> Cc: Phil Edworthy <phil.edworthy@renesas.com> Cc: Robert Baldyga <r.baldyga@samsung.com> Cc: Torsten Koschorrek <koschorrek@synertronixx.de> Cc: Anatolij Gustschin <agust@denx.de> Reviewed-by: Linus Walleij <linus.walleij@linaro.org> Reviewed-by: Łukasz Majewski <l.majewski@samsung.com>
2015-03-09armv8/vexpress64: make multientry conditionalLinus Walleij
While the Freescale ARMv8 board LS2085A will enter U-Boot both on a master and a secondary (slave) CPU, this is not the common behaviour on ARMv8 platforms. The norm is that U-Boot is entered from the master CPU only, while the other CPUs are kept in WFI (wait for interrupt) state. The code determining which CPU we are running on is using the MPIDR register, but the definition of that register varies with platform to some extent, and handling multi-cluster platforms (such as the Juno) will become cumbersome. It is better to only enable the multiple entry code on machines that actually need it and disable it by default. Make the single entry default and add a special ARMV8_MULTIENTRY KConfig option to be used by the platforms that need multientry and set it for the LS2085A. Delete all use of the CPU_RELEASE_ADDR from the Vexpress64 boards as it is just totally unused and misleading, and make it conditional in the generic start.S code. This makes the Juno platform start U-Boot properly. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-03-05vexpress64: juno: support SMC9118 ethernetLinus Walleij
This configures the Juno board to enable ethernet using the SMSC9118 ethernet controller found in the board. Tested by TFTP-booting a kernel over ethernet. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-01-30vexpress64: support the Juno Development PlatformLinus Walleij
The Juno Development Platform is a physical Versatile Express device with some differences from the emulated semihosting models. The main difference is that the system is split in a SoC and an FPGA where the SoC hosts the serial ports at totally different adresses. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-01-30vexpress64: get rid of CONFIG_SYS_EXTRA_OPTIONSLinus Walleij
The Versatile Express ARMv8 semihosted FVP platform is still using the legacy CONFIG_SYS_EXTRA_OPTIONS method to configure some compile-time flags. Get rid of this and create a Kconfig entry for the FVP model, and a selectable bool for the semihosting library. The FVP subboard is now modeled as a target choice so we can eventually choose between different ARMv8 versatile express boards (FVP, base model, Juno...) this way. All dependent symbols are updated to reflect this. The 64bit Versatile Express board symbols are renamed VEXPRESS64 so we have some chance to see what is actually going on. Tested on the FVP fast model. Acked-by: Steve Rae <srae@broadcom.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-12-29vexpress64: take over maintenance of the semi vexpress64Linus Walleij
As agreed with Steve Rae I'm taking over maintenance of the semihosted, emulated FVP/foundation model Versatile Express 64 bit board variant. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Steve Rae <srae@broadcom.com>
2014-10-29kconfig: arm: introduce symbol for ARM CPUsGeorges Savoundararadj
This commit introduces a Kconfig symbol for each ARM CPU: CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136, CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100. Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected for CPU_ARM1176 and CPU_V7. For each target, the corresponding CPU is selected and the definition of SYS_CPU in the corresponding Kconfig file is removed. Also, it removes redundant "string" type in some Kconfig files. Signed-off-by: Georges Savoundararadj <savoundg@gmail.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-09-24MAINTAINERS: comment out blank M: fieldMasahiro Yamada
Since commit ddaf5c8f3030050fcd356a1e49e3ee8f8f52c6d4 (patman: RunPipe() should not pipe stdout/stderr unless asked), Patman spits lots of "Invalid MAINTAINERS address: '-'" error messages for patches with global changes. It takes too long for Patman to process them. Anyway, "M: -" does not carry any important information. Rather, it is just like a place holder in case of assigning a new board maintainer. Let's comment out. This commit can be reproduced by the following command: find . -name MAINTAINERS | xargs sed -i -e '/^M:[[:blank:]]*-$/s/^/#/' Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-09-24MAINTAINERS: comment out invalid maintainersMasahiro Yamada
The "S: Orphan" in MAINTAINERS means that the maintainer in the "M:" field is unreachable (i.e. the email address is not working). (Refer to the definition of "Orphan" adopted in U-Boot in the log of commit 31f1b654b2f395b69faa5d0d3c1eb0803923bd3b, "boards.cfg: move boards with invalid emails to Orphan") For patch files adding global changes, scripts/get_maintainer.pl adds bunch of such invalid email addresses, which results in tons of annoying bounce emails. This commit can be reproduced by the following command: find . -name MAINTAINERS | xargs sed -i -e ' /^M:[[:blank:]]/ { N /S:[[:blank:]]Orphan/s/^/#/ } ' Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-09-16kconfig: armv8: move CONFIG_ARM64 to KconfigMasahiro Yamada
2014-09-16vexpress64: kconfig: consolidate CONFIG_TARGET_VEXPRESS_AEMV8A_SEMIMasahiro Yamada
We do not have to distinguish CONFIG_TARGET_VEXPRESS_AEMV8A_SEMI from CONFIG_TARGET_VEXPRESS_AEMV8A. Rename the former to the latter. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Steve Rae <srae@broadcom.com> Cc: David Feng <fenghua@phytium.com.cn>
2014-08-30versatile: kconfig: move common settingsMasahiro Yamada
Move Versatile-specific settings to versatile/Kconfig. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-08-30MAINTAINERS: change the status of vexpress board to OrphanMasahiro Yamada
The email address of Matt Waddel is no longer working. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Marc Zyngier <marc.zyngier@arm.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Alexei Fedorov <alexie.fedorov@arm.com>
2014-07-03arm: Add support for semihosting for armv8 fastmodel targets.Darwin Rambo
The armv8 ARM Trusted Firmware (ATF) can be used to load various ATF images and u-boot, and does this for virtual platforms by using semihosting. This commit extends this idea by allowing u-boot to also use semihosting to load the kernel/ramdisk/dtb. This eliminates the need for a bootwrapper and produces a more realistic boot sequence with virtual models. Though the semihosting code is quite generic, support for armv7 in fastmodel is less useful due to the wide range of available silicon and the lack of a free armv7 fastmodel, so this change contains an untested armv7 placeholder for the service trap opcode. Please refer to doc/README.semihosting for a more detailed description of semihosting and how it is used with the armv8 virtual platforms. Signed-off-by: Darwin Rambo <drambo@broadcom.com> Cc: trini@ti.com Cc: fenghua@phytium.com.cn Cc: bhupesh.sharma@freescale.com
2014-02-26arm: remove unneeded symbol offsets and _TEXT_BASEAlbert ARIBAUD
Remove the last uses of symbol offsets in ARM U-Boot. Remove some needless uses of _TEXT_BASE. Remove all _TEXT_BASE definitions. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2014-01-28Merge branch 'u-boot-arm/next' into 'u-boot-arm/master'Albert ARIBAUD
2014-01-24lib: time: add weak timer_init() functionDarwin Rambo
If timer_init() is made a weak stub function, then it allows us to remove several empty timer_init functions for those boards that already have a timer initialized when u-boot starts. Architectures that use the timer framework may also remove the need for timer.c. Signed-off-by: Darwin Rambo <drambo@broadcom.com> Reviewed-by: Tim Kryger <tim.kryger@linaro.org>
2014-01-13ARM: versatile: pass correct machine type for Versatile ABLinus Walleij
When U-Boot is configured for Versatile AB, it will still pass the machine ID of Versatile PB to the kernel. After this simple fix the system boots correctly. Cc: Stefano Babic <sbabic@denx.de> Cc: Marek Vasut <marex@denx.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Marek Vasut <marex@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2014-01-09arm64: board support of vexpress_aemv8aDavid Feng
Signed-off-by: David Feng <fenghua@phytium.com.cn> Signed-off-by: Bhupesh Sharma <bhupesh.sharma@freescale.com>
2013-11-04ARM: vexpress: convert to common timer codeRob Herring
Convert vexpress to use the commmon timer code. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-10-03ARM: VExpress: enable ARMv7 virt support for VExpress A15Andre Przywara
To enable hypervisors utilizing the ARMv7 virtualization extension on the Versatile Express board with the A15 core tile, we add the required configuration variable. Also we define the board specific smp_set_cpu_boot_addr() function to set the start address for secondary cores in the VExpress specific manner. There is no need to provide a custom smp_waitloop() function here. This also serves as an example for what to do when adding support for new boards. Signed-off-by: Andre Przywara <andre.przywara@linaro.org>
2013-05-23ARM: vexpress: create A5 specific board configRyan Harkin
This patch creates a new config for the A5 dual core tile that includes the generic config for the Versatile Express platform. The generic config has been modified to provide support for the Extended Memory Map, as used on the A5 core tile. A5 does not support the legacy memory map. Signed-off-by: Ryan Harkin <ryan.harkin@linaro.org> Signed-off-by: Andre Przywara <andre.przywara@linaro.org>
2013-05-23ARM: vexpress: refactoring of Versatile Express CA9x4 supportRyan Harkin
The current ca9x4_ct_vxp platform contains support for a Versatile Express motherboard with a quad core A9 core tile. This patch separates the Versatile Express motherboard code and the A9 specific code, to ease supporting more core tiles in the next patches. Andre: merged the first two of Ryan's original patches and did some checkpatch fixes. Signed-off-by: Ryan Harkin <ryan.harkin@linaro.org> Signed-off-by: Andre Przywara <andre.przywara@linaro.org>
2012-09-01u8500: Separating mmc config parameters from driverJohn Rigby
Configuration in vexpress and u8500.v1 is different from what is needed in u8500.v2. As such, card configuration specifics need to reside in the board file rather than the driver. Signed-off-by: John Rigby <john.rigby@linaro.org> Signed-off-by: Mathieu Poirier <mathieu.poirier@linaro.org> Signed-off-by: Tom Rini <trini@ti.com>
2012-07-29doc: cleanup - move board READMEs into respective board directoriesWolfgang Denk
Also drop a few files referring to no longer / not yet supported boards. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Stefan Roese <sr@denx.de> Cc: Kim Phillips <kim.phillips@freescale.com> Cc: Andy Fleming <afleming@gmail.com> Cc: Jason Jin <jason.jin@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
2012-03-26ARMV7/Vexpress: add missing get_ticks() and get_tbclk()Liming Wang
commit f31a911fe (arm, post: add missing post_time_ms for arm) enables get_ticks and get_tbclk for all arm based boards, arm/vexpress also needs these functions to work. Signed-off-by: Liming Wang <walimisdev@gmail.com> Acked-by: Matt.Waddel@linaro.org
2012-03-04integrator: remove fragile delay loop from PCI codeLinus Walleij
The reference implementation of the PCI initialization code almost everywhere contain this fragile loop of "a few usecs", and its use of volatile variables to delay a number of bus cycles is indeed uncertain. Reading the manual "Integrator/AP Users Guide", page 5-15 it is clearly stated: "Wait until 230ms after the end of the reset period before accessing V360EPC internal registers. The V360EPC supports the use of a serial configuration PROM and the software must wait for the device to detect the absence of this PROM before accessing any registers. The required delay is a function of the PCI Clock, but at the lower frequency (25MHz) is 230ms". So let's simply wait 230ms per the spec. This solves the compilation error that looked like this: pci.c: In function ‘pci_init_board’: pci.c:286:18: warning: variable ‘j’ set but not used Reported-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-02-27integrator: rewrite the AP PCI driverLinus Walleij
The PCI support for the Integrator AP has apparently never been finished and I strongly suspect that it has never worked, so let's fix it. This is a list of the more or less un-splittable changes done in this driver rewrite: - Replace the register definitions stashed into the config file (!) with a copy if the register file from the Linux kernels arch/arm/include/asm/hardware/pci_v3.h - Delete the unreadable gigantic macros that perform the config accesses and replace them with copyedited code from Linux arch/arm/mach-integrator/pci_v3.c - Rewrite the rest of the setup code to use the v3_[read|write][lwb]() accessors. - Enable PCI by default in the AP board configuration. - Fix checkpatch warnings and make code more conformant. Tested-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-02-27integrator: stop calling pci_init() twiceLinus Walleij
The U-Boot startup infrastructure already makes sure pci_init() is called at a proper time, calling it again from within the board setup code will not make things better. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-11-10integrator: enable Vpp and disable flash protectionLinus Walleij
This enables Vpp and disables the flash protection on the Integrator when starting U-Boot. The integrator/AP has double protection mechanisms: this one and the EBI protection bit (patch earlier), the Integrator/CP has only one line of protection in these registers. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-11-10integrator: add system controller headerLinus Walleij
Break out the AP system controller and CP "CP controller" registers into a header file, it gives better overview than hardcoding its values and other disturbing practices. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-11-10integrator: make flash writeable on bootLinus Walleij
This reconfigures the EBI (External Bus Interface) on the integrator so that chip select 1, handling the flash memory, is set to writeable. Without this it is not possible for U-Boot to access flash memory and it crashes on startup since CFI won't work properly. Since this is the first time we use the EBI, we create a header file for its registers. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-11-10integrator: use io-accessors for board initLinus Walleij
Casting around to *(volatile ulong *) doesn't look good, so include the <asm/io.h> macros and use good old readl() instead. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-11-10integrator: move text offset to configLinus Walleij
Do away with the config.mk file and move the text offset to the config files to make things easier. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-11-08integrator: do not test first part of the memoryLinus Walleij
When booting from Flash, the Integrator remaps its flash memory from 0x24000000 to 0x00000000, and starts executing it at 0x00000000. This ROM thus hides the RAM underneath and first 0x40000 bytes of the memory cannot be tested by get_ram_size(). So let's test from 0x40000 to the end of detected memory instead. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
