path: root/board/armltd
2018-03-05libfdt: move headers to <linux/libfdt.h> and <linux/libfdt_env.h>Masahiro Yamada
Thomas reported U-Boot failed to build host tools if libfdt-devel package is installed because tools include libfdt headers from /usr/include/ instead of using internal ones. This commit moves the header code: include/libfdt.h -> include/linux/libfdt.h include/libfdt_env.h -> include/linux/libfdt_env.h and replaces include directives: #include <libfdt.h> -> #include <linux/libfdt.h> #include <libfdt_env.h> -> #include <linux/libfdt_env.h> Reported-by: Thomas Petazzoni <thomas.petazzoni@bootlin.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-02-19vexpress: Sign up as maintainerLinus Walleij
These ARM boards are in nice shape and still being used a lot with e.g. QEMU, so I can maintain them. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2017-11-17mmc: arm_pl180_mmci: update arm_pl180_mmci_init() prototypePatrice Chotard
Update arm_pl180_mmci_init() prototype by adding struct mmc** param. This is needed before converting this driver to driver model in order to use arm_pl180_mmci_init() in driver model and in none driver model implementation Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2017-06-05arm: Add explicit include of <asm/mach-types.h>Simon Glass
Rather than relying on common.h to provide this include, which is going away at some point, include it explicitly in each file. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-06-01dm: Use dm.h header when driver mode is usedSimon Glass
This header includes things that are needed to make driver build. Adjust existing users to include that always, even if other dm/ includes are present Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-05board_f: Drop setup_dram_config() wrapperSimon Glass
By making dram_init_banksize() return an error code we can drop the wrapper. Adjust this and clean up all implementations. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de>
2016-11-29vexpress64: Juno: Change PCI buss addresses for IO to start from zero.Liviu Dudau
Juno uses a 1:1 mapping between CPU and PCI addresses for IO. First, that will trip devices that cannot use more than 16 bits of addresses for IO, second it is un-necessary as the system can handle zero-based PCI addresses just fine. Change the mapping to start IO bus addresses from zero. Signed-off-by: Liviu Dudau <Liviu.Dudau@foss.arm.com>
2016-10-07vexpress: disable cci ace slave ports when booting in non-sec/hyp modeSudeep Holla
Commit f225d39d3093 ("vexpress: Check TC2 firmware support before defaulting to nonsec booting") added support to check if the firmware on TC2 is configured appropriately before booting in nonsec/hyp mode. However when booting in non-secure/hyp mode, CCI control must be done in secure firmware and can't be done in non-secure/hyp mode. In order to ensure that, this patch disables the cci slave port inteface so that it is not accessed at all. Cc: Jon Medhurst <tixy@linaro.org> Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Sudeep Holla <sudeep.holla@arm.com> Acked-by: Jon Medhurst <tixy@linaro.org> Tested-by: Jon Medhurst <tixy@linaro.org>
2016-08-15vexpress: Check TC2 firmware support before defaulting to nonsec bootingJon Medhurst \(Tixy\)
The firmware on TC2 needs to be configured appropriately before booting in nonsec mode will work as expected, so test for this and fall back to sec mode if required. Signed-off-by: Jon Medhurst <tixy@linaro.org> Reviewed-by: Ryan Harkin <ryan.harkin@linaro.org> Tested-by: Ryan Harkin <ryan.harkin@linaro.org>
2016-07-15armv8: mmu: Add support of non-identical mappingYork Sun
Introduce virtual and physical addresses in the mapping table. This change have no impact on existing boards because they all use idential mapping. Signed-off-by: York Sun <york.sun@nxp.com>
2016-03-15vexpress64: Add MMU tablesAlexander Graf
There's no good excuse for running with caches disabled on AArch64, so let's just move the vexpress64 target to enable the MMU and run with caches on. Signed-off-by: Alexander Graf <agraf@suse.de>
2015-11-21vexpress64: use 2nd DRAM bank only on junoRyan Harkin
This patch makes the 2nd DRAM bank available on Juno only and not on other vexpress64 targets, eg. the FVP models. The commit below added a 2nd bank of NOR flash for Juno, but also for all vexpress64 targets: commit 2d0cee1ca2b9d977fa3214896bb2e30cfec77059 Author: Liviu Dudau <Liviu.Dudau@foss.arm.com> Date: Mon Oct 19 11:08:31 2015 +0100 vexpress64: Juno: Declare all 8GB of RAM and make them visible to the kernel. Juno comes with 8GB RAM, but U-Boot only passes 2GB to the kernel. Declare a secondary memory bank and set the sizes correctly. Signed-off-by: Liviu Dudau <Liviu.Dudau@foss.arm.com> Reviewed-by: Linus Walleij <linus.walleij@linaro.org> Reviewed-by: Ryan Harkin <ryan.harkin@linaro.org> Tested-by: Ryan Harkin <ryan.harkin@linaro.org> Unfortunately, I only fully tested on Juno R0, R1 and the FVP Foundation model. Whilst FVP Base AEMV8 models run U-Boot OK, they fail to boot the kernel. Signed-off-by: Ryan Harkin <ryan.harkin@linaro.org> Acked-by: Liviu Dudau <liviu.dudau@foss.arm.com> Reviewed-by: Linus Walleij <linus.walleij@linaro.org>
2015-11-21vexpress64: compile Juno PCIe conditionallyRyan Harkin
Only compile in PCIe support if the board really uses it. Provide a __weak stub for the init function if e.g. FVP is being built. Signed-off-by: Ryan Harkin <ryan.harkin@linaro.org> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2015-11-21Juno: don't print PCI debug information by defaultAndre Przywara
On a Juno r1 the PCI controller init routine outputs the rather boring ATR entry information. Do this only with DEBUG defined to avoid cluttering the user's terminal. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Ryan Harkin <ryan.harkin@linaro.org>
2015-10-19vexpress64: Juno: Add initialisation code for Juno R1 PCIe host bridge.Liviu Dudau
Juno R1 has an XpressRICH3 PCIe host bridge that needs to be initialised in order for the Linux kernel to be able to enumerate the bus. Add support code here that enables the host bridge, trains the links and sets up the Address Translation Tables. Signed-off-by: Liviu Dudau <Liviu.Dudau@foss.arm.com> Tested-by: Ryan Harkin <ryan.harkin@linaro.org> [trini: Always declare vexpress64_pcie_init and continue handling logic inside the function] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-10-19vexpress64: Juno: Declare all 8GB of RAM and make them visible to the kernel.Liviu Dudau
2015-10-11vexpress64: fvp dram: add DRAM configurationRyan Harkin
Create an additional FVP configuration to boot images pre-loaded into DRAM. Sometimes it's preferential to boot the model by loading the files directly into DRAM via model parameters, rather than using SemiHosting. An example of model parmaters that are used to pre-load the files into DRAM: --data cluster0.cpu0=Image@0x80080000 \ --data cluster0.cpu0=fvp-base-gicv2-psci.dtb@0x83000000 \ --data cluster0.cpu0=uInitrd@0x84000000 Signed-off-by: Ryan Harkin <ryan.harkin@linaro.org> Reviewed-by: Linus Walleij <linus.walleij@linaro.org> [trini: Update board/armltd/vexpress64/Kconfig logic] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-10-11vexpress64: Kconfig: tidy upRyan Harkin
The FVP and Juno settings were identical, but duplicated, so I removed the duplication with this patch. Signed-off-by: Ryan Harkin <ryan.harkin@linaro.org> Reviewed-by: Linus Walleij <linus.walleij@linaro.org> [trini: Adjust logic to keep if/endif in the file] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-09-11arm: Remove versatileab boardSimon Glass
This board has not been converted to generic board by the deadline. Remove it. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-12integrator: switch to DM serial portLinus Walleij
This switches the Integrator boards over to using the device model for its serial ports. Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-05-13ARM: Clean up CONFIG_ARMV7_NONSEC/VIRT/PSCI conditionsJan Kiszka
CONFIG_ARMV7_VIRT depends on CONFIG_ARMV7_NONSEC, thus doesn't need to be taken into account additionally. CONFIG_ARMV7_PSCI is only set on boards that support CONFIG_ARMV7_NONSEC, and it only works on those. CC: Tang Yuantian <Yuantian.Tang@freescale.com> CC: York Sun <yorksun@freescale.com> CC: Steve Rae <srae@broadcom.com> CC: Andre Przywara <andre.przywara@linaro.org> Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Tested-by: Alison Wang <alison.wang@freescale.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-04-23integrator: stop zeroing the gd flagsLinus Walleij
This assignment conflicts with code that add flags with gd->flags |= FOO prior to the execution of this function. Seems like a historical artifact and creates bugs with early alloc(). Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-23ARM: integrator: move board select into mach-integrator/KconfigMasahiro Yamada
The board/SoC select menu in arch/arm/Kconfig is still cluttered. Add ARCH_INTEGRATOR into arch/arm/Kconfig and move the board select under arch/arm/mach-integrator. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Linus Walleij <linus.walleij@linaro.org>
2015-04-23vexpress64: use DM for all vexpress64 boardsLinus Walleij
Commit d8bafe1310487ba0e0785997726b4792072178d3 "ARMv8: enable DM in vexpress64 board" only enabled DM for the simulated vexpress64 board (FVP) with the hardcoded clock value for the simulated board, causing a console regression on the Juno board which was using a different clock setting. Fix this by enabling DM for all vexpress64 boards, defining the clock frequency per-board, deleting the static array of PL01x ports from the config file and relying solely on the port defined in the boardfile using platform data. Cc: David Feng <fenghua@phytium.com.cn> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-04-03Merge branch 'master' of git://git.denx.de/u-boot-tegraTom Rini
Conflicts: board/armltd/vexpress64/vexpress64.c Signed-off-by: Tom Rini <trini@konsulko.com>
2015-03-28vexpress64: cut config and defaults for unclear variantLinus Walleij
This variant that is neither FVP / Base Model or Juno Versatile Express 64bit is confusing. Get rid of it unless someone can point out what machine that really is. Seems to be an evolutional artifact in the config base. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-03-28vexpress64: remove board late init, use smhloadLinus Walleij
This removes the kludgy late board init from the FVP simulator version of Versatile Express 64bit (ARMv8), and replace it with a default boot command using the new smhload command to load the files using semihosting. Tested on the Foundation Model. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-03-27ARMv8: enable DM in vexpress64 boardDavid Feng
Signed-off-by: David Feng <fenghua@phytium.com.cn>
2015-03-24remove unnecessary version.h includesRob Herring
Various files are needlessly rebuilt every time due to the version and build time changing. As version.h is not actually needed, remove the include. Signed-off-by: Rob Herring <robh@kernel.org> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Stefano Babic <sbabic@denx.de> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Marek Vasut <marex@denx.de> Cc: Tom Warren <twarren@nvidia.com> Cc: Michal Simek <monstr@monstr.eu> Cc: Macpaul Lin <macpaul@andestech.com> Cc: Wolfgang Denk <wd@denx.de> Cc: York Sun <yorksun@freescale.com> Cc: Stefan Roese <sr@denx.de> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Cc: Simon Glass <sjg@chromium.org> Cc: Philippe Reynes <tremyfr@yahoo.fr> Cc: Eric Jarrige <eric.jarrige@armadeus.org> Cc: "David Müller" <d.mueller@elsoft.ch> Cc: Phil Edworthy <phil.edworthy@renesas.com> Cc: Robert Baldyga <r.baldyga@samsung.com> Cc: Torsten Koschorrek <koschorrek@synertronixx.de> Cc: Anatolij Gustschin <agust@denx.de> Reviewed-by: Linus Walleij <linus.walleij@linaro.org> Reviewed-by: Łukasz Majewski <l.majewski@samsung.com>
2015-03-09armv8/vexpress64: make multientry conditionalLinus Walleij
While the Freescale ARMv8 board LS2085A will enter U-Boot both on a master and a secondary (slave) CPU, this is not the common behaviour on ARMv8 platforms. The norm is that U-Boot is entered from the master CPU only, while the other CPUs are kept in WFI (wait for interrupt) state. The code determining which CPU we are running on is using the MPIDR register, but the definition of that register varies with platform to some extent, and handling multi-cluster platforms (such as the Juno) will become cumbersome. It is better to only enable the multiple entry code on machines that actually need it and disable it by default. Make the single entry default and add a special ARMV8_MULTIENTRY KConfig option to be used by the platforms that need multientry and set it for the LS2085A. Delete all use of the CPU_RELEASE_ADDR from the Vexpress64 boards as it is just totally unused and misleading, and make it conditional in the generic start.S code. This makes the Juno platform start U-Boot properly. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-03-05vexpress64: juno: support SMC9118 ethernetLinus Walleij
This configures the Juno board to enable ethernet using the SMSC9118 ethernet controller found in the board. Tested by TFTP-booting a kernel over ethernet. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-01-30vexpress64: support the Juno Development PlatformLinus Walleij
The Juno Development Platform is a physical Versatile Express device with some differences from the emulated semihosting models. The main difference is that the system is split in a SoC and an FPGA where the SoC hosts the serial ports at totally different adresses. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-01-30vexpress64: get rid of CONFIG_SYS_EXTRA_OPTIONSLinus Walleij
The Versatile Express ARMv8 semihosted FVP platform is still using the legacy CONFIG_SYS_EXTRA_OPTIONS method to configure some compile-time flags. Get rid of this and create a Kconfig entry for the FVP model, and a selectable bool for the semihosting library. The FVP subboard is now modeled as a target choice so we can eventually choose between different ARMv8 versatile express boards (FVP, base model, Juno...) this way. All dependent symbols are updated to reflect this. The 64bit Versatile Express board symbols are renamed VEXPRESS64 so we have some chance to see what is actually going on. Tested on the FVP fast model. Acked-by: Steve Rae <srae@broadcom.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-12-29vexpress64: take over maintenance of the semi vexpress64Linus Walleij
As agreed with Steve Rae I'm taking over maintenance of the semihosted, emulated FVP/foundation model Versatile Express 64 bit board variant. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Steve Rae <srae@broadcom.com>
2014-10-29kconfig: arm: introduce symbol for ARM CPUsGeorges Savoundararadj
This commit introduces a Kconfig symbol for each ARM CPU: CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136, CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100. Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected for CPU_ARM1176 and CPU_V7. For each target, the corresponding CPU is selected and the definition of SYS_CPU in the corresponding Kconfig file is removed. Also, it removes redundant "string" type in some Kconfig files. Signed-off-by: Georges Savoundararadj <savoundg@gmail.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-09-24MAINTAINERS: comment out blank M: fieldMasahiro Yamada
Since commit ddaf5c8f3030050fcd356a1e49e3ee8f8f52c6d4 (patman: RunPipe() should not pipe stdout/stderr unless asked), Patman spits lots of "Invalid MAINTAINERS address: '-'" error messages for patches with global changes. It takes too long for Patman to process them. Anyway, "M: -" does not carry any important information. Rather, it is just like a place holder in case of assigning a new board maintainer. Let's comment out. This commit can be reproduced by the following command: find . -name MAINTAINERS | xargs sed -i -e '/^M:[[:blank:]]*-$/s/^/#/' Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-09-24MAINTAINERS: comment out invalid maintainersMasahiro Yamada
The "S: Orphan" in MAINTAINERS means that the maintainer in the "M:" field is unreachable (i.e. the email address is not working). (Refer to the definition of "Orphan" adopted in U-Boot in the log of commit 31f1b654b2f395b69faa5d0d3c1eb0803923bd3b, "boards.cfg: move boards with invalid emails to Orphan") For patch files adding global changes, scripts/get_maintainer.pl adds bunch of such invalid email addresses, which results in tons of annoying bounce emails. This commit can be reproduced by the following command: find . -name MAINTAINERS | xargs sed -i -e ' /^M:[[:blank:]]/ { N /S:[[:blank:]]Orphan/s/^/#/ } ' Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-09-16kconfig: armv8: move CONFIG_ARM64 to KconfigMasahiro Yamada
2014-09-16vexpress64: kconfig: consolidate CONFIG_TARGET_VEXPRESS_AEMV8A_SEMIMasahiro Yamada
We do not have to distinguish CONFIG_TARGET_VEXPRESS_AEMV8A_SEMI from CONFIG_TARGET_VEXPRESS_AEMV8A. Rename the former to the latter. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Steve Rae <srae@broadcom.com> Cc: David Feng <fenghua@phytium.com.cn>
2014-08-30versatile: kconfig: move common settingsMasahiro Yamada
Move Versatile-specific settings to versatile/Kconfig. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-08-30MAINTAINERS: change the status of vexpress board to OrphanMasahiro Yamada
The email address of Matt Waddel is no longer working. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Marc Zyngier <marc.zyngier@arm.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Alexei Fedorov <alexie.fedorov@arm.com>
2014-07-03arm: Add support for semihosting for armv8 fastmodel targets.Darwin Rambo
The armv8 ARM Trusted Firmware (ATF) can be used to load various ATF images and u-boot, and does this for virtual platforms by using semihosting. This commit extends this idea by allowing u-boot to also use semihosting to load the kernel/ramdisk/dtb. This eliminates the need for a bootwrapper and produces a more realistic boot sequence with virtual models. Though the semihosting code is quite generic, support for armv7 in fastmodel is less useful due to the wide range of available silicon and the lack of a free armv7 fastmodel, so this change contains an untested armv7 placeholder for the service trap opcode. Please refer to doc/README.semihosting for a more detailed description of semihosting and how it is used with the armv8 virtual platforms. Signed-off-by: Darwin Rambo <drambo@broadcom.com> Cc: trini@ti.com Cc: fenghua@phytium.com.cn Cc: bhupesh.sharma@freescale.com
2014-02-26arm: remove unneeded symbol offsets and _TEXT_BASEAlbert ARIBAUD
Remove the last uses of symbol offsets in ARM U-Boot. Remove some needless uses of _TEXT_BASE. Remove all _TEXT_BASE definitions. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2014-01-28Merge branch 'u-boot-arm/next' into 'u-boot-arm/master'Albert ARIBAUD
2014-01-24lib: time: add weak timer_init() functionDarwin Rambo
If timer_init() is made a weak stub function, then it allows us to remove several empty timer_init functions for those boards that already have a timer initialized when u-boot starts. Architectures that use the timer framework may also remove the need for timer.c. Signed-off-by: Darwin Rambo <drambo@broadcom.com> Reviewed-by: Tim Kryger <tim.kryger@linaro.org>
2014-01-13ARM: versatile: pass correct machine type for Versatile ABLinus Walleij
When U-Boot is configured for Versatile AB, it will still pass the machine ID of Versatile PB to the kernel. After this simple fix the system boots correctly. Cc: Stefano Babic <sbabic@denx.de> Cc: Marek Vasut <marex@denx.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Marek Vasut <marex@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
