path: root/board/armltd
2010-04-04arm/integrator: Remove unneccessary CONFIG_PCI check.Detlev Zundel
pci_eth_init() is already conditional to CONFIG_PCI so not every caller needs to have conditionals. This is the only place in the current code base where such a check is still at the calling site. Signed-off-by: Detlev Zundel <dzu@denx.de> CC: Ben Warren <biggerbadderben@gmail.com> CC: Peter Pearse <peter.pearse@arm.com>
2009-12-05Generic udelay() with watchdog supportIngo van Lil
According to the PPC reference implementation the udelay() function is responsible for resetting the watchdog timer as frequently as needed. Most other architectures do not meet that requirement, so long-running operations might result in a watchdog reset. This patch adds a generic udelay() function which takes care of resetting the watchdog before calling an architecture-specific __udelay(). Signed-off-by: Ingo van Lil <inguin@gmx.de>
2009-10-04Convert SMC91111 Ethernet driver to CONFIG_NET_MULTI APIBen Warren
All in-tree boards that use this controller have CONFIG_NET_MULTI added Also: - changed CONFIG_DRIVER_SMC91111 to CONFIG_SMC91111 - cleaned up line lengths - modified all boards that override weak function in this driver - modified all eeprom standalone apps to work with new driver - updated blackfin standalone EEPROM app after testing Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-07-18ARM: make split_by_variant.sh output more usefulWolfgang Denk
The board/armltd/integrator/split_by_variant.sh script used to print "Configuring for integrator*p board..." no matter which board name was being compiled. This made it difficult to match MAKEALL output to board names. This patch fixes this. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-12versatile: update config and merge to cfi flash driverJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Peter Pearse <peter.pearse@arm.com> Cc: Catalin Marinas <catalin.marinas@arm.com>
2009-06-23integrator: merge integratorap and integratorcpJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Peter Pearse <peter.pearse@arm.com>
2009-06-23integratorap/cp: use cfi driverJean-Christophe PLAGNIOL-VILLARD
2009-06-23integratorap/cp/versatile: remove non used functionsJean-Christophe PLAGNIOL-VILLARD
2009-06-23integratorcp: split timer supportJean-Christophe PLAGNIOL-VILLARD
2009-06-23integratorap: split timer supportJean-Christophe PLAGNIOL-VILLARD
2009-06-23integratorap: split pci supportJean-Christophe PLAGNIOL-VILLARD
2009-06-12arm: unify linker scriptJean-Christophe PLAGNIOL-VILLARD
all arm boards except a few use the same cpu linker script so move it to cpu/$(CPU) that could be overwrite in following order SOC BOARD via the corresponding config.mk Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-06-12arm: timer and interrupt init reworkJean-Christophe PLAGNIOL-VILLARD
actually the timer init use the interrupt_init as init callback which make the interrupt and timer implementation difficult to follow so now rename it as int timer_init(void) and use interrupt_init for interrupt btw also remane the corresponding file to the functionnality implemented as ixp arch implement two timer - one based on interrupt - so all the timer related code is moved to timer.c Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-05-15Fix e-mail address of Gary Jennejohn.Detlev Zundel
2009-04-05arm: clean cache managementJean-Christophe PLAGNIOL-VILLARD
unify arm cache management except for non standard cache as ARM7TDMI Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-02-07pci: Rename PCI_REGION_MEMORY to PCI_REGION_SYS_MEMORY for clarityKumar Gala
The PCI_REGION_MEMORY and PCI_REGION_MEM are a bit to similar and can be confusing when reading the code. Rename PCI_REGION_MEMORY to PCI_REGION_SYS_MEMORY to clarify its used for system memory mapping purposes. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-01-29move ARM Ltd. to vendor dirJean-Christophe PLAGNIOL-VILLARD
