path: root/board/armltd/versatile
2011-09-28ARM: versatile: delete split_by_variant.shLinus Walleij
Since commit d388298a59ba375c76597b8f95b560afa971a0fb by Stefano Babic this file is no longer needed so delete it. Cc: Stefano Babic <sbabic@denx.de> Cc: Loïc Minier <loic.minier@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-09-04ARM: versatile: drop warningsStefano Babic
Drop warning: "passing argument 1 of 'get_ram_size' discards qualifiers from pointer target type" Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Albert Aribaud <albert.u.boot@aribaud.net>
2011-08-04ARM: versatile: fix board supportStefano Babic
Versatile board is used as example to run u-boot under qemu. The patch fixes relocation for all versatile boards and adds a versatileqemu target to be used under qemu. Patch tested only under qemu, not on real boards. Tested with QEMU emulator version 0.14.50. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Alessandro Rubini <rubini-list@gnudd.com> CC: Loïc Minier <loic.minier@linaro.org>
2009-10-04Convert SMC91111 Ethernet driver to CONFIG_NET_MULTI APIBen Warren
All in-tree boards that use this controller have CONFIG_NET_MULTI added Also: - changed CONFIG_DRIVER_SMC91111 to CONFIG_SMC91111 - cleaned up line lengths - modified all boards that override weak function in this driver - modified all eeprom standalone apps to work with new driver - updated blackfin standalone EEPROM app after testing Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-07-12versatile: update config and merge to cfi flash driverJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Peter Pearse <peter.pearse@arm.com> Cc: Catalin Marinas <catalin.marinas@arm.com>
2009-06-23integratorap/cp/versatile: remove non used functionsJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Peter Pearse <peter.pearse@arm.com>
2009-06-12arm: unify linker scriptJean-Christophe PLAGNIOL-VILLARD
all arm boards except a few use the same cpu linker script so move it to cpu/$(CPU) that could be overwrite in following order SOC BOARD via the corresponding config.mk Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-05-15Fix e-mail address of Gary Jennejohn.Detlev Zundel
Signed-off-by: Detlev Zundel <dzu@denx.de>
2009-01-29move ARM Ltd. to vendor dirJean-Christophe PLAGNIOL-VILLARD
