path: root/board/armadillo
2008-07-13Fix some more printf() format issues.Jean-Christophe PLAGNIOL-VILLARD
2005-10-06CleanupWolfgang Denk
2005-09-26Add board support for armadillo HT1070Wolfgang Denk
Patch by Rowel Atienza, 06 Apr 2005
