path: root/board/aristainetos/ddr-setup2.cfg
2015-05-26arm, imx6: add support for aristainetos2 boardHeiko Schocher
add support for imx6dl based aristainetos2 board U-Boot 2015.04-rc5-00066-g60f6ed4 (Apr 10 2015 - 08:46:27) CPU: Freescale i.MX6DL rev1.1 at 792 MHz Reset cause: WDOG Board: aristaitenos2 Watchdog enabled I2C: ready DRAM: 1 GiB NAND: 1024 MiB MMC: FSL_SDHC: 0 SF: Detected N25Q128A with page size 256 Bytes, erase size 64 KiB, total 16 MiB Display: lg4573 (480x800) In: serial Out: serial Err: serial Net: FEC [PRIME] Hit any key to stop autoboot: 0 => Signed-off-by: Heiko Schocher <hs@denx.de>
