path: root/board/aristainetos/aristainetos.cfg
2014-07-23arm, imx6: add aristainetos boardHeiko Schocher
CPU: Freescale i.MX6DL rev1.1 at 792 MHz Board: aristaitenos I2C: ready DRAM: 1 GiB NAND: 512 MiB MMC: FSL_SDHC: 0, FSL_SDHC: 1 SF: Detected N25Q128 with page size 256 Bytes, erase size 64 KiB, total 16 MiB Display: lb07wv8 (800x480) - UART5 is console - MMC 0 and 1 - USB 0 and 1 - boot from mmc0 and spi nor flash - Splash screen support Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Stefano Babic <sbabic@denx.de>
