path: root/board/aries
2018-02-04arm: imx: m53evk: remove usage of mx53_dram_sizePatrick Bruenn
Static variables are not available during board_init_f(). 'static uint32_t mx53_dram_size[2];' was used in board specific dram_init(), dram_init_banksize() and get_effective_memsize() to avoid multiple calls to get_ram_size(). Reused dram initialization functions from arch/arm/mach-imx/mx5/mx53_dram.c Signed-off-by: Patrick Bruenn <p.bruenn@beckhoff.com>
2017-07-18ARM: Mark AE boards orphanMarek Vasut
I no longer have any of these boards, mark boards orphan. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Tom Rini <trini@konsulko.com>
Change is consistent with other SOCs and it is in preparation for adding SOMs. SOC's related files are moved from cpu/ to mach-imx/<SOC>. This change is also coherent with the structure in kernel. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Fabio Estevam <fabio.estevam@nxp.com> CC: Akshay Bhat <akshaybhat@timesys.com> CC: Ken Lin <Ken.Lin@advantech.com.tw> CC: Marek Vasut <marek.vasut@gmail.com> CC: Heiko Schocher <hs@denx.de> CC: "Sébastien Szymanski" <sebastien.szymanski@armadeus.com> CC: Christian Gmeiner <christian.gmeiner@gmail.com> CC: Stefan Roese <sr@denx.de> CC: Patrick Bruenn <p.bruenn@beckhoff.com> CC: Troy Kisky <troy.kisky@boundarydevices.com> CC: Nikita Kiryanov <nikita@compulab.co.il> CC: Otavio Salvador <otavio@ossystems.com.br> CC: "Eric Bénard" <eric@eukrea.com> CC: Jagan Teki <jagan@amarulasolutions.com> CC: Ye Li <ye.li@nxp.com> CC: Peng Fan <peng.fan@nxp.com> CC: Adrian Alonso <adrian.alonso@nxp.com> CC: Alison Wang <b18965@freescale.com> CC: Tim Harvey <tharvey@gateworks.com> CC: Martin Donnelly <martin.donnelly@ge.com> CC: Marcin Niestroj <m.niestroj@grinn-global.com> CC: Lukasz Majewski <lukma@denx.de> CC: Adam Ford <aford173@gmail.com> CC: "Albert ARIBAUD (3ADEV)" <albert.aribaud@3adev.fr> CC: Boris Brezillon <boris.brezillon@free-electrons.com> CC: Soeren Moch <smoch@web.de> CC: Richard Hu <richard.hu@technexion.com> CC: Wig Cheng <wig.cheng@technexion.com> CC: Vanessa Maegima <vanessa.maegima@nxp.com> CC: Max Krummenacher <max.krummenacher@toradex.com> CC: Stefan Agner <stefan.agner@toradex.com> CC: Markus Niebel <Markus.Niebel@tq-group.com> CC: Breno Lima <breno.lima@nxp.com> CC: Francesco Montefoschi <francesco.montefoschi@udoo.org> CC: Jaehoon Chung <jh80.chung@samsung.com> CC: Scott Wood <oss@buserror.net> CC: Joe Hershberger <joe.hershberger@ni.com> CC: Anatolij Gustschin <agust@denx.de> CC: Simon Glass <sjg@chromium.org> CC: "Andrew F. Davis" <afd@ti.com> CC: "Łukasz Majewski" <l.majewski@samsung.com> CC: Patrice Chotard <patrice.chotard@st.com> CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Hans de Goede <hdegoede@redhat.com> CC: Masahiro Yamada <yamada.masahiro@socionext.com> CC: Stephen Warren <swarren@nvidia.com> CC: Andre Przywara <andre.przywara@arm.com> CC: "Álvaro Fernández Rojas" <noltari@gmail.com> CC: York Sun <york.sun@nxp.com> CC: Xiaoliang Yang <xiaoliang.yang@nxp.com> CC: Chen-Yu Tsai <wens@csie.org> CC: George McCollister <george.mccollister@gmail.com> CC: Sven Ebenfeld <sven.ebenfeld@gmail.com> CC: Filip Brozovic <fbrozovic@gmail.com> CC: Petr Kulhavy <brain@jikos.cz> CC: Eric Nelson <eric@nelint.com> CC: Bai Ping <ping.bai@nxp.com> CC: Anson Huang <Anson.Huang@nxp.com> CC: Sanchayan Maity <maitysanchayan@gmail.com> CC: Lokesh Vutla <lokeshvutla@ti.com> CC: Patrick Delaunay <patrick.delaunay@st.com> CC: Gary Bisson <gary.bisson@boundarydevices.com> CC: Alexander Graf <agraf@suse.de> CC: u-boot@lists.denx.de Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2017-06-29ARM: at91: ma5d4: Support both SF and eMMC SoMsMarek Vasut
Discern the SoMs based on the presence of SPI flash to support both variants of the SoM, one booting from SPI NOR and one booting from eMMC. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com>
2017-06-29ARM: at91: ma5d4: Boot from MMC2 when using SAM-BAMarek Vasut
Continue loading U-Boot from MMC2 when the SPL was loaded using SAM-BA loader. This allows the board to boot system from the removable media instead of the eMMC, which is useful for commissioning purposes. When booting from the eMMC, always boot from it as it is not possible to boot from the SD interface directly. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com>
2017-06-29ARM: at91: ma5d4: Swap SD/MMC controller orderMarek Vasut
The SDHCI1 is the primary boot controller on rev. 2.1 SoM, which is the version available on the market. Swap the controller order to match this and future versions of the SoM. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com>
2017-06-29ARM: at91: ma5d4: Init SD/MMC controller in SPLMarek Vasut
Init the controllers, otherwise the board cannot boot from SD/MMC. This boot option is new on rev. 2.1 SoM . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com>
2017-06-29ARM: at91: ma5d4: Reset CAN controllers lateMarek Vasut
The CAN controllers need slight delay between toggling of their reset line. Move this action into board_init(), otherwise timer will not be initialized and the board might hang. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com>
2017-06-29ARM: at91: ma5d4: Switch DDR2 controller to sequencial address decodingMarek Vasut
According to the datasheet, sequential mapping is used for DDR SDRAM, while interleaved mapping is used for regular SDRAM. Incorrect configuration of this bit does indeed cause sporadic memory instability. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Wenyou Yang <wenyou.yang@atmel.com>
2017-06-29ARM: atmel: Rename MA5D4EVKMarek Vasut
The board is now manufactured by Aries Embedded GmbH , rename it. Signed-off-by: Marek Vasut <marex@denx.de>
2017-04-14Merge branch 'master' of git://git.denx.de/u-boot-socfpgaTom Rini
2017-04-14ARM: socfpga: Rename MCVEVKMarek Vasut
2017-04-13Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
Drop CONFIG_STACKSIZE from include/configs/imx6_logic.h Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-05ARM: mx5: Rename M53EVKMarek Vasut
2017-04-05ARM: mxs: Rename M28EVKMarek Vasut
