path: root/board/aries/mcvevk/socfpga.c
2019-05-14arm: socfpga: Re-add support for Aries MCV SoM and MCVEV[KP] boardWolfgang Grandegger
Re-add support for Aries Embedded MCV SoM, which is CycloneV based and the associated MCVEVK and MCVEVP baseboard. The board can boot from eMMC. Ethernet and USB is supported. The Aries Embedded boards have been removed with commit 03b54997d568 ("board/aries: Remove"). I will now take care of them. The device-tree files are from mainline Linux commit e93c9c99a629 ("Linux v5.1)". Signed-off-by: Wolfgang Grandegger <wg@aries-embedded.de> CC: Marek Vasut <marex@denx.de> CC: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
2018-07-02board/aries: RemoveTom Rini
The various Aries Embedded boards have been orphaned for a year and no one has come forward to take care of them. Remove. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-14ARM: socfpga: Rename MCVEVKMarek Vasut
The board is now manufactured by Aries Embedded GmbH , rename it. Signed-off-by: Marek Vasut <marex@denx.de>
