path: root/board/aries/m28evk/Makefile
2018-07-02board/aries: RemoveTom Rini
The various Aries Embedded boards have been orphaned for a year and no one has come forward to take care of them. Remove. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-05ARM: mxs: Rename M28EVKMarek Vasut
The board is now manufactured by Aries Embedded GmbH , rename it. Signed-off-by: Marek Vasut <marex@denx.de>
