path: root/board/apollon
2012-09-18ARM: Remove apollon boardMarek Vasut
This board is the only board that still sticks to OneNAND IPL. Remove this board, since we have SPL around for a while and OneNAND is well supported in the SPL framework. The board can be revived if necessary. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Tom Rini <trini@ti.com>
2011-12-10board/apollon/sys_info.c: Fix GCC 4.6 build warningWolfgang Denk
Fix: sys_info.c: In function 'display_board_info': sys_info.c:260:16: warning: variable 'db_s' set but not used [-Wunused-but-set-variable] Also fix resulting warnings: sys_info.c:251:7: warning: unused variable 'db_ip' [-Wunused-variable] sys_info.c:250:7: warning: unused variable 'db_men' [-Wunused-variable] Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Kyungmin Park <kyungmin.park@samsung.com>
2011-12-10board/apollon/apollon.c: Fix GCc 4.6 build warnings.Wolfgang Denk
Fix: apollon.c: In function 'dram_init': apollon.c:188:29: warning: variable 'cpu' set but not used [-Wunused-but-set-variable] apollon.c:188:20: warning: variable 'rev' set but not used [-Wunused-but-set-variable] apollon.c:187:26: warning: variable 'size1' set but not used [-Wunused-but-set-variable] Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Kyungmin Park <kyungmin.park@samsung.com>
2009-12-14Net: Clean up LAN91C96 SupportBen Warren
A previous Commit converted the LAN91C96 Ethernet driver to using the CONFIG_NET_MULTI API, but did not include full board support. This patch finishes the job. Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-12-13LAN91C96: Enable NET_MULTI LAN driverNishanth Menon
This modification is NOT tested on any of the platforms modified as I dont have them. please help by testing+building+fixing Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-06-12arm: unify linker scriptJean-Christophe PLAGNIOL-VILLARD
all arm boards except a few use the same cpu linker script so move it to cpu/$(CPU) that could be overwrite in following order SOC BOARD via the corresponding config.mk Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-05-15Fix e-mail address of Gary Jennejohn.Detlev Zundel
Signed-off-by: Detlev Zundel <dzu@denx.de>
2008-11-19ARM: Add Apollon UBI supportKyungmin Park
To enable UBI on Apollon you need to uncomment the CONFIG_SYS_USE_UBI macro. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-09-07apollon: use the last memory area for u-bootKyungmin Park
2008-07-10Remove useless print message at apollonKyungmin Park
Remove useless print message at apollon Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2008-06-28Use better Ethernet timings for apollon boardKyungmin Park
2008-02-22Fix GPMC CS2 memory setup at apollonKyungmin Park
It disables the current map first Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2008-02-14OneNAND Initial Program Loader (IPL) supportKyungmin Park
This patch enables the OneNAND boot within U-Boot. Before this work, we used another OneNAND IPL called X-Loader based on open source. With this work, we can build the oneboot.bin image without other program. The build sequence is simple. First, it compiles the u-boot.bin Second, it compiles OneNAND IPL Finally, it becomes the oneboot.bin from OneNAND IPL and u-boot.bin The mechanism is similar with NAND boot except it boots from itself. Another thing is that you can only use the OneNAND IPL only to work other bootloader such as RedBoot and so on. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2008-01-09Coding Style cleanup, update CHANGELOGWolfgang Denk
2007-11-15Correction patchPeter Pearse
2007-11-09Add apollon board supportPeter Pearse
