path: root/board/amlogic
2020-07-08boards: amlogic: add Odroid C4 supportChristian Hewitt
Odroid C4 is an Amlogic SM1 device, the board config and board documentation are adapted from the Odroid-N2 support from the same vendor. Signed-off-by: Christian Hewitt <christianshewitt@gmail.com> [narmstrong: fix odroid-c4.rst typos and structure] Signed-off-by: Neil Armstrong <narmstrong@baylibre.com> Tested-by: Anand Moon <linux.amoon@gmail.com>
2020-07-08board: amlogic: Add Odroid-N2 board supportPascal Vizeli
Add a proper Odroid-N2 board support to handle the Ethernet MAC address stored in the in-SoC eFuses. Signed-off-by: Pascal Vizeli <pvizeli@syshack.ch> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com> Tested-by: Anand Moon <linux.amoon@gmail.com>
2020-06-18board: amlogic: add board doc files to MAINTAINERSNeil Armstrong
Add the recently added reStructuredText board documentation in the appropriate MAINTAINERS files. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2020-06-18board: amlogic: move boards doc into doc/board/amlogicNeil Armstrong
Move the natural text Amlogic board README files to doc/board/amlogic into reStructuredText and : - add reStructuredText markup for bash code - fix secondary titles markup - move board support into global support matrix Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2020-06-02amlogic: Remove ARCH= references from documentationTom Rini
When building U-Boot we select the architecture via Kconfig and not ARCH being passed in via the environment or make cmdline. Cc: Beniamino Galvani <b.galvani@gmail.com> Acked-by: Neil Armstrong <narmstrong@baylibre.com> Cc: u-boot-amlogic@groups.io Signed-off-by: Tom Rini <trini@konsulko.com>
2020-05-18command: Remove the cmd_tbl_t typedefSimon Glass
We should not use typedefs in U-Boot. They cannot be used as forward declarations which means that header files must include the full header to access them. Drop the typedef and rename the struct to remove the _s suffix which is now not useful. This requires quite a few header-file additions. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop init.h from common headerSimon Glass
Move this uncommon header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop net.h from common headerSimon Glass
Move this header out of the common header. Network support is used in quite a few places but it still does not warrant blanket inclusion. Note that this net.h header itself has quite a lot in it. It could be split into the driver-mode support, functions, structures, checksumming, etc. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-04-06arm64: dts: meson: add libretech-pc supportJerome Brunet
Add support for the Amlogic based libretech-pc platform. This platform comes with 2 variant, based on the s905d or s912 SoC. Acked-by: Neil Armstrong <narmstrong@baylibre.com> Signed-off-by: Jerome Brunet <jbrunet@baylibre.com> [narmstrong: update board/amlogic/q200/MAINTAINERS] Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2020-01-07boards: amlogic: add Khadas VIM3L supportChristian Hewitt
Khadas VIM3L uses the same board layout as VIM3, but with an S905D3 chip instead of A311D. Board config is derived from khadas-vim3_defconfig and sei610_defconfig. README is based on README.khadas-vim3; the difference is that VIM3L uses FIP files from the g12a folder in vendor sources not the g12b folder. Signed-off-by: Christian Hewitt <christianshewitt@gmail.com> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com> [narmstrong: added vim3l readme into w400 MAINTAINERS]
2019-10-18configs: sei610: Add config file to fix userdata sizeGuillaume La Roque
Add separate config file to handle the different eMMC size on the sei610 board. Signed-off-by: Guillaume La Roque <glaroque@baylibre.com> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2019-10-18boards: amlogic: add SEI610 supportNeil Armstrong
Add support for the customer board SEI610 manufactured by SEI Robotics with the following specifications: - Amlogic S905X3 ARM Cortex-A55 quad-core SoC - 2GB DDR4 SDRAM - 10/100 Ethernet (Internal PHY) - 1 x USB 3.0 Host - 1 x USB Type-C DRD - 1 x FTDI USB Serial Debug Interface - eMMC - SDcard - Infrared receiver - SDIO WiFi Module Like it's SEI510 counterpart, the boot flow is designed to boot Android AOSP built for the Yukawa Android device. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2019-10-18configs: Add Khadas VIM3 defconfigAndreas Färber
Derived from odroid-n2_defconfig and README.odroid-n2. Reviewed-by: Neil Armstrong <narmstrong@baylibre.com> Signed-off-by: Andreas Färber <afaerber@suse.de> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2019-10-18board: amlogic: document alternative libretech-cc installation methodsDaniel Drake
As already documented in this README, several binaries must be glued together in order to boot the device. Extend the documentation to cover the prebuilt binaries (saving you the hassle of installing ancient cross-compilers), and also mention the open source replacements for the encryption tool (which is especially useful if you want to avoid requiring 32-bit x86 binaries in your build system). Signed-off-by: Daniel Drake <drake@endlessm.com> Cc: Neil Armstrong <narmstrong@baylibre.com> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2019-08-12Merge tag 'u-boot-amlogic-20190812' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-amlogic - amlogic: add support for the SEI Robotic SEI510
2019-08-12boards: meson: add g12a sei510Jerome Brunet
The SEI510 board is based on the Amlogic S905X2 SoC from the Amlogic G12A SoC family. The board has the following specifications : - Amlogic S905X2 ARM Cortex-A53 quad-core SoC - XGB DDR4 SDRAM - 10/100 Ethernet (Internal PHY) - 1 x USB 3.0 Host - eMMC - SDcard - Infrared receiver - SDIO WiFi Module The board default behaviour is for booting Android and triggers fastboot on recovery or reboot mode. USB vendor ID (used by fastboot) is 0x18d1 (Google) for default udev rules for existing android users work out of the box. Signed-off-by: Kevin Hilman <khilman@baylibre.com> Signed-off-by: Jerome Brunet <jbrunet@baylibre.com> Signed-off-by: Guillaume La Roque <glaroque@baylibre.com> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2019-08-11env: Rename environment.h to env_internal.hSimon Glass
This file contains lots of internal details about the environment. Most code can include env.h instead, calling the functions there as needed. Rename this file and add a comment at the top to indicate its internal nature. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> [trini: Fixup apalis-tk1.c] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-08-11env: Drop environment.h header file where not neededSimon Glass
This header file is now only used by files that access internal environment features. Drop it from various places where it is not needed. Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2019-08-11env: Move env_set() to env.hSimon Glass
Move env_set() over to the new header file. Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2019-07-31board: amlogic: add support for Odroid-N2Neil Armstrong
ODROID-N2 is a single board computer manufactured by Hardkernel Co. Ltd with the following specifications: - Amlogic S922X ARM Cortex-A53 dual-core + Cortex-A73 quad-core SoC - 4GB DDR4 SDRAM - Gigabit Ethernet - HDMI 2.1 4K/60Hz display - 40-pin GPIO header - 4 x USB 3.0 Host, 1 x USB OTG - eMMC, microSD - Infrared receiver The board directory is W400, the name of the Amlogic Reference Design of Amlogic G12B with Gigabit boards, which will be used for similar boards. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com> Tested-by: Mark Kettenis <kettenis@openbsd.org>
2019-07-08Merge tag 'u-boot-amlogic-20190704' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-amlogic - fix khadas-vim README - add support for unique generated MAC adresses from SoC serial, limited to Amlogic GXL/GXM boards for now
2019-07-04board: amlogic: add mailing-list to MAINTAINERSNeil Armstrong
Add missing mailing-list to the amlogic boards MAINTAINERS file. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2019-07-04board: amlogic: Generate unique MAC address for Q200 and P212 based boardsNeil Armstrong
Enable unique MAC address generation for boards usins SoCs having a known functional and valid unique serial number. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2019-07-04board: amlogic: vim: Fix READMEAndreas Färber
Unlike the BayLibre repos Khadas' repo defaults to using native gcc, so specify the CROSS_COMPILE setting matching the prescribed toolchain. Signed-off-by: Andreas Färber <afaerber@suse.de> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2019-05-31boards: amlogic-g200: remove phy resetNeil Armstrong
The PHY reset is now handled by the MAC driver, remove this leftover. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2019-04-23board: amlogic-q200: fix Khadas VIM2 READMENeil Armstrong
The vendor U-boot branch and defconfig was wrong for the Khadas VIM2, fix this. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2019-04-23boards: meson: add g12a u200Jerome Brunet
The Amlogic U200 board is based on the Amlogic S905D2 SoC from the Amlogic G12A SoC family. The board has the following specifications : - Amlogic S905D2 ARM Cortex-A53 quad-core SoC - XGB DDR4 SDRAM - 10/100 Ethernet (Internal PHY) - 1 x USB 3.0 Host - eMMC - SDcard - Infrared receiver - SDIO WiFi Module - MIPI DSI Connector - Audio HAT Connector - PCI-E M.2 Connector Signed-off-by: Jerome Brunet <jbrunet@baylibre.com> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2019-04-10boards: Amlogic: Add support for Libretech-ACNeil Armstrong
LibreTech AC is a single board computer manufactured by Libre Technology with the following specifications: - Amlogic S805X ARM Cortex-A53 quad-core SoC @ 1.2GHz - ARM Mali 450 GPU - 512MiB DDR4 SDRAM - 10/100 Ethernet - HDMI 2.0 4K/60Hz display - 40-pin GPIO header - 4 x USB 2.0 Host - eMMC, SPI NOR Flash - Infrared receiver The u-boot specific code is the same as the P212 support, so use the P212 board support code with a distinct defconfig and config include files. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2019-04-10ARM: board: meson: add p201 boardMohammad Rasim
This adds support for p201 reference boards Signed-off-by: Mohammad Rasim <mohammad.rasim96@gmail.com> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2019-04-10ARM: board: meson: add p200 boardMohammad Rasim
This adds the defconfig and README files for p200 board Signed-off-by: Mohammad Rasim <mohammad.rasim96@gmail.com> Acked-by: Neil Armstrong <narmstrong@baylibre.com> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2019-04-10ARM: board: meson: rename odroid-c2 to p200Mohammad Rasim
This renames the odroid-c2 to p200 and set it as the default GXBB board Other boards (odroid-c2 and nanopi-k2) will inherit from p200 Signed-off-by: Mohammad Rasim <mohammad.rasim96@gmail.com> Acked-by: Neil Armstrong <narmstrong@baylibre.com> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2018-11-29Merge tag 'u-boot-amlogic-20181126' of git://git.denx.de/u-boot-amlogicTom Rini
Cleanup and update towards support for Amlogic Meson AXG SoCs : - mmc: meson-gx: Add AXG compatible - net: designware: add meson meson compatibles - Amlogic Meson cleanup for AXG SoC support
2018-11-26ARM: meson: factorize common code out amlogic's boardsJerome Brunet
Now we have moved all the Amlogic board support to common generic board code, we can move the identical board_init() and ft_board_setup() functions to weak functions into the board-common mach-meson file. Signed-off-by: Jerome Brunet <jbrunet@baylibre.com> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2018-11-26board: amlogic: add support for S400 boardNeil Armstrong
The S400 board is the Amlogic AXG SoC reference board including : - Amlogic A113DX ARM Cortex-A53 quad-core SoC @ 1.2GHz - 1GB DDR4 SDRAM - 10/100 Ethernet - 2 x USB 2.0 Host - eMMC - Infrared receiver - SDIO WiFi Module - MIPI DSI Connector - Audio HAT Connector - PCI-E M.2 Connectors Signed-off-by: Jerome Brunet <jbrunet@baylibre.com> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2018-11-26ARM: meson: rework soc arch file to prepare for new SoCJerome Brunet
We are about to add support for the Amlogic AXG SoC. While very close to the Gx SoC family, we will need to handle a few thing which are different in this SoC. Rework the meson arch directory to prepare for this. Signed-off-by: Jerome Brunet <jbrunet@baylibre.com> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2018-11-26ARM: rework amlogic configurationJerome Brunet
Rework the board SYS_BOARD, SYS_VENDOR and SYS_CONFIG_NAME setup by moving the board Kconfig into the mach-meson Kconfig to make it easier to add new boards for a SoC architecture and add a custom config header or custom board handler for a platform. This drops the board CONFIGs and the duplicate boards configs headers in favor of a single meson64.h config header. Signed-off-by: Jerome Brunet <jbrunet@baylibre.com> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2018-11-26board: amlogic: factorise gxbb boardsJerome Brunet
The nanopi-k2 and the odroid-c2 are similar enough to be supported by the same u-boot board. This change use odroid-c2 u-boot board for the nanopi-k2 as well. Dedicated defconfig are kept to customize the names and device tree. Signed-off-by: Jerome Brunet <jbrunet@baylibre.com> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2018-11-26board: amlogic: move khadas-vim2 as q200 ref boardNeil Armstrong
The Khadas vim2 derive from amlogic s912 reference design (Q200). This patch moves the khadas-vim2 board support to a generic Q200 board, while keeping a dedicated defconfig to customize the names and device tree. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2018-11-26board: amlogic: remove p212 derivativesJerome Brunet
The Khadas vim and the libretech aml-s905x-cc (aka Potato) derive from amlogic s905x reference design (P212). All the code in these board is a copy/paste from the p212, which is tedious to maintain. This change use p212 u-boot board for all these boards, while keeping a dedicated defconfig to customize the names and device tree. Signed-off-by: Jerome Brunet <jbrunet@baylibre.com> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2018-10-10ARM: meson: Add Khadas VIM2 board supportLoic Devulder
This adds platform code for the Khadas VIM2 board based on a Meson GXM (S912) SoC with the Meson GXM configuration. This initial submission supports UART, MMC/SDCard and Ethernet. USB is partially supported. All the code is from Neil Armstrong! I just rebased the code, do some cleanup and tested on my board. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com> Signed-off-by: Loic Devulder <ldevulder@suse.de> Acked-by: Neil Armstrong <narmstrong@baylibre.com>
2018-09-05amlogic: board p212: Fix Ethernet PHY initJasper kcoding
Without this patch the Ethernet PHY on the p212 board does not get fully configured. When this happens Ethernet does not function. The similar libretech-cc and khadas-vim boards have this code already. That's why the Ethernet on these boards do work. Signed-off-by: Jasper Kcoding <jasperkcoding@gmail.com> Acked-by: Neil Armstrong <narmstrong@baylibre.com>
2018-08-24boards: amlogic: remove ethernet gpio reset code from boardsBeniamino Galvani
The reset is already handled by the designware driver using information from device tree. Signed-off-by: Beniamino Galvani <b.galvani@gmail.com> Acked-by: Neil Armstrong <narmstrong@baylibre.com>
2018-07-20Fix README for Khadas VIM boardLoic Devulder
Explicitly add 'python' call for 'acs_tool.pyc', to avoid failed execution on some OSes. Signed-off-by: Loic Devulder <ldevulder@suse.de> Acked-by: Neil Armstrong <narmstrong@baylibre.com>
2018-07-19boards: amlogic: Fix boards READMENeil Armstrong
Fix typos and update the supported devices for all Amlogic boards. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2018-07-19boards: amlogic: Add FriendlyElec NanoPi K2 board supportThomas McKahan
This adds platform code for the FriendlyElec NanoPi K2 board based on a Meson GXBB (S905) SoC with the Meson GXBB configuration. This initial submission only supports: - UART - MMC/SDCard - Ethernet - Reset Controller - Clock controller Cc: Yuefei Tan <yftan@friendlyarm.com> Signed-off-by: Thomas McKahan <tonymckahan@gmail.com> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2018-06-19meson: use the clock driverBeniamino Galvani
Use the clk framework to initialize clocks from drivers that need them instead of having hardcoded frequencies and initializations from board code. Signed-off-by: Beniamino Galvani <b.galvani@gmail.com> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2018-05-08ARM: meson: rename GXBB to GXNeil Armstrong
Taking into account the Amlogic Family name starts with GX, including the GXBB, GXL and GXM SoCs. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2018-04-08net: Move enetaddr env access code to env config instead of net configAlex Kiernan
In order that we can use eth_env_* even when CONFIG_NET isn't set, move these functions to environment code from net code. This fixes failures such as: board/ti/am335x/built-in.o: In function `board_late_init': board/ti/am335x/board.c:752: undefined reference to `eth_env_set_enetaddr' u-boot/board/ti/am335x/board.c:766: undefined reference to `eth_env_set_enetaddr' which caters for use cases such as: commit f411b5cca48f ("board: am335x: Always set eth/eth1addr environment variable") when Ethernet is required in Linux, but not U-Boot. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
2018-01-02boards: amlogic: khadas-vim: Typo fixupNeil Armstrong
Khadas VIM is an Open Source DIY Box manufactured by Shenzhen Wesion NOT 'Tomato' The fix was provided by Khadas Team member 'numbqq'. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
