path: root/board/amlogic/odroid-c2/odroid-c2.c
2016-09-06meson: odroid-c2: enable Ethernet support through the device treeBeniamino Galvani
Remove the device definition from board file, update the driver with the new compatible property and update config with necessary options. Signed-off-by: Beniamino Galvani <b.galvani@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-06-24board: amlogic: Rename folder for Amlogic boardsCarlo Caione
s/hardkernel/amlogic/ to have a single place for all the amlogic-based boards. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Carlo Caione <carlo@endlessm.com> Acked-by: Beniamino Galvani <b.galvani@gmail.com>
