Now that the other architecture-specific lib directories have been
moved out of the top-level directory there's not much reason to have the
'_generic' suffix on the common lib directory.
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk
This change is intended to clean up the top-level directory structure
and more closely mimic Linux's directory organization.
These boards have special linker scripts right now. We can't use the
common 4xx linker script here. So overrride the linker script (LDSCRIPT)
in board/*/config.mk and choose the board specific version.
The following changes allow U-Boot to fully relocate from flash to
RAM:
- Remove linker scripts' .fixup sections from the .text section
- Add -mrelocatable to PLATFORM_RELFLAGS for all boards
- Define CONFIG_RELOC_FIXUP_WORKS for all boards
Previously, U-Boot would partially relocate, but statically initialized
pointers needed to be manually relocated.
Many of the help messages were not really helpful; for example, many
commands that take no arguments would not print a correct synopsis
line, but "No additional help available." which is not exactly wrong,
but not helpful either.
Commit ``Make "usage" messages more helpful.'' changed this
partially. But it also became clear that lots of "Usage" and "Help"
messages (fields "usage" and "help" in struct cmd_tbl_s respective)
were actually redundant.
This patch cleans this up - for example:
Before:
=> help dtt
dtt - Digital Thermometer and Thermostat
Usage:
dtt - Read temperature from digital thermometer and thermostat.
After:
=> help dtt
dtt - Read temperature from Digital Thermometer and Thermostat
Usage:
dtt
A recent gcc added a new unaligned rodata section called '.rodata.str1.1',
which needs to be added the the linker script. Instead of just adding this
one section, we use a wildcard ".rodata*" to get all rodata linker section
gcc has now and might add in the future.
However, '*(.rodata*)' by itself will result in sub-optimal section
ordering. The sections will be sorted by object file, which causes extra
padding between the unaligned rodata.str.1.1 of one object file and the
aligned rodata of the next object file. This is easy to fix by using the
SORT_BY_ALIGNMENT command.
This patch has not be tested one most of the boards modified. Some boards
have a linker script that looks something like this:
*(.text)
. = ALIGN(16);
*(.rodata)
*(.rodata.str1.4)
*(.eh_frame)
I change this to:
*(.text)
. = ALIGN(16);
*(.eh_frame)
*(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*)))
This means the start of rodata will no longer be 16 bytes aligned.
However, the boundary between text and rodata/eh_frame is still aligned to
16 bytes, which is what I think the real purpose of the ALIGN call is.
Signed-off-by: Trent Piepho <xyzzy@speakeasy.org>
The PCI_REGION_MEMORY and PCI_REGION_MEM are a bit to similar and
can be confusing when reading the code.
Rename PCI_REGION_MEMORY to PCI_REGION_SYS_MEMORY to clarify its used
for system memory mapping purposes.
Remove command name from all command "usage" fields and update
common/command.c to display "name - usage" instead of
just "usage". Also remove newlines from command usage fields.
Most of the bss initialization loop increments 4 bytes
at a time. And the loop end is checked for an 'equal'
condition. Make the bss end address aligned by 4, so
that the loop will end as expected.
Signed-off-by: Selvamuthukumar <selva.muthukumar@e-coninfotech.com>
Affected boards:
ap1000
mvbc_p
PM854
Removed initialization of the driver from net/eth.c
This patch changes the return type of initdram() from long int to phys_size_t.
This is required for a couple of reasons: long int limits the amount of dram
to 2GB, and u-boot in general is moving over to phys_size_t to represent the
size of physical memory. phys_size_t is defined as an unsigned long on almost
all current platforms.
This patch *only* changes the return type of the initdram function (in
include/common.h, as well as in each board's implementation of initdram). It
does not actually modify the code inside the function on any of the platforms;
platforms which wish to support more than 2GB of DRAM will need to modify
their initdram() function code.
Build tested with MAKEALL for ppc, arm, mips, mips-el. Booted on powerpc
MPC8641HPCN.
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
Historically the 405 U-Boot port had a dram_init() call in early init
stage. This function was still called from start.S and most of the time
coded in assembler. This is not needed anymore (since a long time) and
boards should implement the common initdram() function in C instead.
This patch now removed the dram_init() call from start.S and removes the
empty implementations that are scattered through most of the 405 board
ports. Some older board ports really implement this dram_init() though.
These are:
csb272
csb472
ERIC
EXBITGEN
W7OLMC
W7OLMG
I changed those boards to call this assembler dram_init() function now
from their board specific initdram() instead. This *should* work, but please
test again on those platforms. And it is perhaps a good idea that those
boards use some common 405 SDRAM initialization code from cpu/ppc4xx at
some time. So further patches welcome here.
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
The cross compiler is responsible for providing the correct libraries
and the logic to find the linking libraries.
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
With recent toolchain versions, some boards would not build because
or errors like this one (here for ocotea board when building with
ELDK 4.2 beta):
ppc_4xx-ld: section .bootpg [fffff000 -> fffff23b] overlaps section .bss [fffee900 -> fffff8ab]
For many boards, the .bss section is big enough that it wraps around
at the end of the address space (0xFFFFFFFF), so the problem will not
be visible unless you use a 64 bit tool chain for development. On
some boards however, changes to the code size (due to different
optimizations) we bail out with section overlaps like above.
The fix is to add the NOLOAD attribute to the .bss and .sbss
sections, telling the linker that .bss does not consume any space in
the image.
Change all linker scripts to reference the changed driver name 4xx_uart.o.
Note: In most cased all these explicit referencing of these object files
in the linker scripts is not neccessary. Only for manually embedded
environment into the U-Boot image, which is not done is most cases.
Fixed some broken instances of "#ifdef CMD_CFG_IDE" too.
Those always evaluated TRUE, and thus were always compiled
even when IDE really wasn't defined/wanted.
This is a compatibility step that allows both the older form
and the new form to co-exist for a while until the older can
be removed entirely.
All transformations are of the form:
Before:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT)
After:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT) || defined(CONFIG_CMD_AUTOSCRIPT)
Modifications are based on the linux kernel approach and
support two use cases:
1) Add O= to the make command line
'make O=/tmp/build all'
2) Set environement variable BUILD_DIR to point to the desired location
'export BUILD_DIR=/tmp/build'
'make'
The second approach can also be used with a MAKEALL script
'./MAKEALL'
Command line 'O=' setting overrides BUILD_DIR environent variable.
When none of the above methods is used the local build is performed and
the object files are placed in the source directory.
Patch by Stefan Roese, 18 Jan 2006
Patch by Art Shipkowski, 12 May 2005
Cleanup.
Patch by James MacAulay, 07 Oct 2005
