path: root/board/amcc
2010-10-04ppc44x: config GPIOs for USB on canyonlands boardRupjyoti Sarmah
The GPIO 16 and 19 reconfiguration should be done once USB is initialized. So moved the reconfiguration to the USB init function. Signed-off-by: Rupjyoti Sarmah <rsarmah@apm.com> Signed-off-by: Stefan Roese <sr@denx.de>
2010-10-04ppc4xx: Small whitespace cleanup in canyonlands.cStefan Roese
2010-10-04APM821xx: Add bluestone board supportTirumala Marri
Add support code for bluestone board wth APM821XX processor based. This patch includes early board init, misc init, configure EBC, initializes UIC, MAKEALL, board.cfg and MAINTAINERS file. Signed-off-by: Tirumala R Marri <tmarri@apm.com Signed-off-by: Stefan Roese <sr@denx.de>
2010-09-28Merge branch 'next' of /home/wd/git/u-boot/nextWolfgang Denk
Conflicts: include/ppc4xx.h Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-09-23ppc4xx: Use common NS16550 driver for PPC4xx UARTStefan Roese
This patch removes the PPC4xx UART driver. Instead the common NS16550 driver is used, since all PPC4xx SoC's use this peripheral device. The file 4xx_uart.c now only implements the UART clock calculation function which also sets the SoC internal UART divisors. All PPC4xx board config headers are changed to use this common NS16550 driver now. Tested on these boards: acadia, canyonlands, katmai, kilauea, sequoia, zeus Signed-off-by: Stefan Roese <sr@denx.de>
2010-09-23ppc4xx: Big header cleanup part 2, mostly PPC405 relatedStefan Roese
This cleanup is done by creating header files for all SoC versions and moving the SoC specific defines into these special headers. This way the common header ppc405.h and ppc440.h can be cleaned up finally. As a part from this cleanup, the GPIO definitions for PPC405EP are corrected. The high and low parts of the registers (for example CONFIG_SYS_GPIO0_OSRL vs. CONFIG_SYS_GPIO0_OSRH) have been defined in the wrong order. This patch now fixes this issue by switching these xxxH and xxxL values. This brings the GPIO 405EP port in sync with all other PPC4xx ports. Signed-off-by: Stefan Roese <sr@denx.de>
2010-09-23ppc4xx: Big header cleanup, mostly PPC440 relatedStefan Roese
This patch starts a bit PPC4xx header cleanup. First patch mostly touches PPC440 files. A later patch will touch the PPC405 files as well. This cleanup is done by creating header files for all SoC versions and moving the SoC specific defines into these special headers. This way the common header ppc405.h and ppc440.h can be cleaned up finally. Signed-off-by: Stefan Roese <sr@denx.de>
2010-09-23ppc4xx: Move gpio.h to ppc4xx-gpio.h since its ppc4xx specificStefan Roese
2010-09-23ppc4xx: Move ppc4xx headers to powerpc include directoryStefan Roese
This patch moves some ppc4xx related headers from the common include directory (include/) to the powerpc specific one (arch/powerpc/include/asm/). This way to common include directory is not so cluttered with files. Signed-off-by: Stefan Roese <sr@denx.de>
2010-09-23ppc4xx/fdt/flash: Change fdt_fixup_nor_flash_node() to not rely on cs sizeStefan Roese
This patch changes the behaviour of the fdt_fixup_nor_flash_node() function. Now it doesn't patch the size of the "reg" property with the chip-select size, but with the size returned from the new function flash_get_bank_size(). This function will return per weak default the flash size of the bank (bank = chip-select numer) detected by the flash driver. If this does not fit your needs, this function may be overridden by a board specific one. For this the parameters needed to be changed. So I intentionally squashed the PPC4xx stuff using this routine into this patch. Otherwise it would not be git-bisectable anymore. The board specific function for the AMCC/APM Ebony eval board is now included in this patch version. Signed-off-by: Stefan Roese <sr@denx.de> Tested-by: Detlev Zundel <dzu@denx.de> Cc: Gerald Van Baren <vanbaren@cideas.com> Cc: Wolfgang Denk <wd@denx.de>
2010-09-194xx: adjust TEXT_BASE to increase U-Boot image sizeWolfgang Denk
On some boards (canyonlands, luan, sequoia) we need more room for the U-Boot image to allow for new features like the new environment code. Shift TEXT_BASE as needed. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2010-07-24cmd_usage(): simplify return code handlingWolfgang Denk
Lots of code use this construct: cmd_usage(cmdtp); return 1; Change cmd_usage() let it return 1 - then we can replace all these ocurrances by return cmd_usage(cmdtp); This fixes a few places with incorrect return code handling, too. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-07-23ppc4xx/Canyonlands added USB board callbacksRupjyoti Sarmah
Functions added to support board callbacks for USB init. This isolates USB manipulations such that it is only touched if USB is used by U-Boot. Signed-off-by: Dave Mitchell <dmitchell@appliedmicro.com> Signed-off-by: Rupjyoti Sarmah <rsarmah@appliedmicro.com> Signed-off-by: Stefan Roese <sr@denx.de>
2010-04-24Merge branch 'master' of git://git.denx.de/u-boot-ppc4xxWolfgang Denk
2010-04-19ppc4xx: TLB init file cleanupStefan Roese
This patch adds new macros, with frequently used combinations of the 4xx TLB access control and storage attibutes. Additionally the 4xx init.S files are updated to make use of these new macros. Resulting in easier to read TLB definitions. Additionally some init.S files are updated to use the mmu header for the TLB defines, instead of defining their own macros. Signed-off-by: Stefan Roese <sr@denx.de>
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2010-04-13Replace "#include <asm-$ARCH/$FILE>" with "#include <asm/$FILE>"Peter Tyser
The appropriate include/asm-$ARCH directory should already by symlinked to include/asm so using the whole "asm-$ARCH" path is unnecessary. This change should also allow us to move the include/asm-$ARCH directories into their appropriate lib/$ARCH/ directories. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-01-23ppc4xx: Kilauea: Add CPLD version detection and EBC reconfigurationStefan Roese
A newer CPLD version on the 405EX evaluation board requires a different EBC controller setup for the CPLD register access. This patch adds a CPLD version detection for Kilauea and code to reconfigure the EBC controller (chip select 2) for the old CPLD if no new version is found. Additionally the CPLD version is printed upon bootup: Board: Kilauea - AMCC PPC405EX Evaluation Board (CPLD rev. 0) Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Wolfgang Denk <wd@denx.de> Cc: Zhang Bao Quan <bqzhang@udtech.com.cn>
2010-01-17PCIe, USB: Replace 'end point' references with 'endpoint'Peter Tyser
When referring to PCIe and USB 'endpoint' is the standard naming convention. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Remy Bohmer <linux@bohmer.net>
2009-12-07POST: Remove duplicated post_hotkey_pressed() functionsStefan Roese
This patch introduces a weak default function for post_hotkey_pressed(), returning 0, for boards without hotkey support. The long-running tests won't be started on those boards. This default function was implemented in many board directories. By implementing this weak default we can remove all those duplicate versions. Boards with hotkey support, can override this weak default function by defining one in their board specific code. Signed-off-by: Stefan Roese <sr@denx.de>
2009-11-19ppc4xx: Consolidate pci_master_init() functionStefan Roese
This patch removes the duplicted implementations of the pci_master_init() function by introducing a weak default function for it. It can be overridden by a board specific version. Signed-off-by: Stefan Roese <sr@denx.de>
2009-11-19ppc4xx: Consolidate pci_pre_init() functionStefan Roese
This patch removes the duplicted implementations of the pci_pre_init() function by introducing a weak default function for it. This weak default has a different implementation for some PPC variants. It can be overridden by a board specific version. Signed-off-by: Stefan Roese <sr@denx.de>
2009-11-19ppc4xx: Consolidate pci_target_init() functionStefan Roese
This patch removes the duplicted implementations of the pci_target_init() function by introducing a weak default function for it. This weak default has a different implementation for 440EP(x)/GR(x) PPC's. It can be overridden by a board specific version (e.g. PMC440, korat). Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu>
2009-11-10ppc4xx: Katmai: Add chip_config commandStefan Roese
This patch removes the Katmai "bootstrap" command and replaces it with the now common command "chip_config". Signed-off-by: Stefan Roese <sr@denx.de>
2009-11-09ppc4xx: Fix NAND booting targets after 4xx linker script consolidationStefan Roese
Somehow I missed the NAND booting targets in the 4xx linker script consolidation patchset. This patch fixes this issue. Signed-off-by: Stefan Roese <sr@denx.de>
2009-11-09ppc4xx: Remove duplicated is_pci_host() functionsStefan Roese
This patch introduces a weak default function for is_pci_host(), returning 1. This is the default behaviour, since most boards only implement PCI host functionality. This weak default can be overridden by a board specific version if needed. Signed-off-by: Stefan Roese <sr@denx.de>
2009-11-09ppc4xx: Consolidate 4xx PCIe board specific configurationStefan Roese
This patch consolidates the PPC4xx board specific PCIe configuration code. This way the duplicated code is removed. Boards can implement a special, non standard behaviour (e.g. number of PCIe slots, etc) by overriding the weak default functions. Signed-off-by: Stefan Roese <sr@denx.de>
2009-11-02ppc4xx: Remove board specific linker scripts from most PPC4xx boardsStefan Roese
All these linker scripts can be removed since the new common ppc4xx linker script should be able to handle all of those boards. Please test and report problems. Thanks. Signed-off-by: Stefan Roese <sr@denx.de>
2009-10-23ppc4xx: Sequoia: Add chip_config commandStefan Roese
This patch removes the Sequoia "bootstrap" command and replaces it with the now common command "chip_config". Please note that the patches with the dynamic PCI sync clock configuration have to be applied, before this one should go in. This is because Sequoia has 2 different bootstrap EEPROMs, and the old bootstrap command configured different values depending on the detected PCI async clock (33 vs. 66MHz). With the PCI sync clock patches, this is not necessary anymore. The PCI sync clock will be configured correctly on-the-fly now. Signed-off-by: Stefan Roese <sr@denx.de>
2009-10-23ppc4xx: Yosemite/Yellowstone: Check and reconfigure the PCI sync clockStefan Roese
This patch now uses the 440EP(x)/GR(x) function to check and dynamically reconfigure the PCI sync clock. Signed-off-by: Stefan Roese <sr@denx.de>
2009-10-23ppc4xx: Sequoia/Rainer: Check and reconfigure the PCI sync clockStefan Roese
2009-10-09Merge branch 'reloc'Wolfgang Denk
2009-10-07ppc_4xx: Apply new HW register namesNiklaus Giger
Modify all existing *.c files to use the new register names as seen in the AMCC manuals. Signed-off-by: Niklaus Giger <niklaus.giger@member.fsf.org> Signed-off-by: Stefan Roese <sr@denx.de>
2009-10-07ppc4xx: Fix msg "initialization as root-complex failed" upon PCIe scanStefan Roese
This message is printed upon PCIe bus scan, not only upon error, but also if no PCIe device is detected at all. Since this is not an error, let's remove this message in this case. We already have the message "link is not up." if there is no PCIe device present. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Wolfgang Denk <wd@denx.de>
2009-10-03ppc: Enable full relocation to RAMPeter Tyser
The following changes allow U-Boot to fully relocate from flash to RAM: - Remove linker scripts' .fixup sections from the .text section - Add -mrelocatable to PLATFORM_RELFLAGS for all boards - Define CONFIG_RELOC_FIXUP_WORKS for all boards Previously, U-Boot would partially relocate, but statically initialized pointers needed to be manually relocated. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-09-28ppc4xx: Convert PPC4xx SDRAM defines from lower case to upper caseStefan Roese
The latest PPC4xx register cleanup patch missed some SDRAM defines. This patch now changes lower case UIC defines to upper case. Also some names are changed to match the naming in the IBM/AMCC users manuals (e.g. mem_mcopt1 -> SDRAM0_CFG). Signed-off-by: Stefan Roese <sr@denx.de>
2009-09-28ppc4xx: Convert PPC4xx UIC defines from lower case to upper caseStefan Roese
The latest PPC4xx register cleanup patch missed the UIC defines. This patch now changes lower case UIC defines to upper case. Signed-off-by: Stefan Roese <sr@denx.de>
2009-09-15Merge branch 'master' of git://git.denx.de/u-boot-ppc4xxWolfgang Denk
2009-09-15board/amcc/common/flash.c: Fix compile warningWolfgang Denk
Fix warning: ../common/flash.c:917: warning: dereferencing type-punned pointer will break strict-aliasing rules Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2009-09-15board/amcc/yucca/flash.c: Fix compile warningWolfgang Denk
Fix warning: flash.c:919: warning: dereferencing type-punned pointer will break strict-aliasing rules Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2009-09-15board/amcc/taihu/flash.c: Fix compile warningWolfgang Denk
Fix warnings: flash.c: In function 'write_word_1': flash.c:696: warning: dereferencing type-punned pointer will break strict-aliasing rules flash.c: In function 'write_word_2': flash.c:1044: warning: dereferencing type-punned pointer will break strict-aliasing rules Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2009-09-11ppc4xx: Big cleanup of PPC4xx definesStefan Roese
This patch cleans up multiple issues of the 4xx register (mostly DCR, SDR, CPR, etc) definitions: - Change lower case defines to upper case (plb4_acr -> PLB4_ACR) - Change the defines to better match the names from the user's manuals (e.g. cprpllc -> CPR0_PLLC) - Removal of some unused defines Please test this patch intensive on your PPC4xx platform. Even though I tried not to break anything and tested successfully on multiple 4xx AMCC platforms, testing on custom platforms is recommended. Signed-off-by: Stefan Roese <sr@denx.de>
2009-08-18ppc4xx: Fix "chip_config" command for AMCC ArchesStefan Roese
This patch fixes the "chip_config" command for I2C bootstrap EEPROM configuration. First it changes the I2C bootstrap EEPROM address to 0x54 as this is used on Arches (instead of 0x52 on Canyonlands/ Glacier). Additionally, the NAND bootstrap settings are removed for Arches since Arches doesn't support NAND-booting. Signed-off-by: Stefan Roese <sr@denx.de>
2009-07-30ppc4xx: Add support for PPC460EX/460GT rev B chip to AMCC CanyonlandsStefan Roese
This patch is based on a diff created by Phong Vo from AMCC. Signed-off-by: Phong Vo <pvo@amcc.com> Signed-off-by: Stefan Roese <sr@denx.de>
2009-07-28ppc4xx: Fix problem with NOR range assignment in Canyonlands ft_board_setupStefan Roese
This patch fixes the problem, that the current fdt board fixup code only set's one range, the one for NOR. By this it's overwriting the already correctly configured values done in __ft_board_setup(). Just remove this now unneeded NOR fixup and all the ranges are correctly defined. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Dirk Eibach <eibach@gdsys.de> Cc: Felix Radensky <felix@embedded-sol.com>
2009-07-28ppc4xx: Add some NAND-booting bootstrap entries to Kilauea chip_config cmdStefan Roese
This patch adds some I2C bootstrap setting for NAND booting to the Kilauea chip_config command ("533-nand" and "600-nand"). Additionally some incorrectly indented lines are fixed. Signed-off-by: Stefan Roese <sr@denx.de>
2009-07-28ppc4xx: Fix Arches DDR2 initializationStefan Roese
Testing on AMCC Arches with the latest U-Boot version yielded that DDR2 initialization is currently broken. U-Boot hangs upon relocation to SDRAM or crashes with random traps. This patch fixes this problem. Arches now uses a different WRDTR and CLKTR default setting than Canyonlands/Glacier. Signed-off-by: Stefan Roese <sr@denx.de>
