The appropriate include/asm-$ARCH directory should already by symlinked
to include/asm so using the whole "asm-$ARCH" path is unnecessary.
This change should also allow us to move the include/asm-$ARCH
directories into their appropriate lib/$ARCH/ directories.
A newer CPLD version on the 405EX evaluation board requires a different
EBC controller setup for the CPLD register access. This patch adds a CPLD
version detection for Kilauea and code to reconfigure the EBC controller
(chip select 2) for the old CPLD if no new version is found.
Additionally the CPLD version is printed upon bootup:
Board: Kilauea - AMCC PPC405EX Evaluation Board (CPLD rev. 0)
Acked-by: Wolfgang Denk <wd@denx.de>
Cc: Zhang Bao Quan <bqzhang@udtech.com.cn>
When referring to PCIe and USB 'endpoint' is the standard naming
convention.
Acked-by: Remy Bohmer <linux@bohmer.net>
This patch introduces a weak default function for post_hotkey_pressed(),
returning 0, for boards without hotkey support. The long-running tests
won't be started on those boards. This default function was implemented
in many board directories. By implementing this weak default we can
remove all those duplicate versions.
Boards with hotkey support, can override this weak default function
by defining one in their board specific code.
This patch removes the duplicted implementations of the pci_master_init()
function by introducing a weak default function for it. It can be
overridden by a board specific version.
This patch removes the duplicted implementations of the pci_pre_init()
function by introducing a weak default function for it. This weak default
has a different implementation for some PPC variants. It can be
This patch removes the duplicted implementations of the pci_target_init()
has a different implementation for 440EP(x)/GR(x) PPC's. It can be
overridden by a board specific version (e.g. PMC440, korat).
Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu>
This patch removes the Katmai "bootstrap" command and replaces it
with the now common command "chip_config".
Somehow I missed the NAND booting targets in the 4xx linker script
consolidation patchset. This patch fixes this issue.
This patch introduces a weak default function for is_pci_host(),
returning 1. This is the default behaviour, since most boards only
implement PCI host functionality. This weak default can be overridden
by a board specific version if needed.
This patch consolidates the PPC4xx board specific PCIe configuration
code. This way the duplicated code is removed. Boards can implement a
special, non standard behaviour (e.g. number of PCIe slots, etc) by
overriding the weak default functions.
All these linker scripts can be removed since the new common ppc4xx
linker script should be able to handle all of those boards.
Please test and report problems. Thanks.
This patch removes the Sequoia "bootstrap" command and replaces it
Please note that the patches with the dynamic PCI sync clock
configuration have to be applied, before this one should go in.
This is because Sequoia has 2 different bootstrap EEPROMs, and
the old bootstrap command configured different values depending
on the detected PCI async clock (33 vs. 66MHz). With the PCI sync
clock patches, this is not necessary anymore. The PCI sync clock
will be configured correctly on-the-fly now.
This patch now uses the 440EP(x)/GR(x) function to check and dynamically
reconfigure the PCI sync clock.
Modify all existing *.c files to use the new register names
as seen in the AMCC manuals.
Signed-off-by: Niklaus Giger <niklaus.giger@member.fsf.org>
This message is printed upon PCIe bus scan, not only upon error, but also
if no PCIe device is detected at all. Since this is not an error, let's
remove this message in this case. We already have the message
"link is not up." if there is no PCIe device present.
The following changes allow U-Boot to fully relocate from flash to
RAM:
- Remove linker scripts' .fixup sections from the .text section
- Add -mrelocatable to PLATFORM_RELFLAGS for all boards
- Define CONFIG_RELOC_FIXUP_WORKS for all boards
Previously, U-Boot would partially relocate, but statically initialized
pointers needed to be manually relocated.
The latest PPC4xx register cleanup patch missed some SDRAM defines.
This patch now changes lower case UIC defines to upper case. Also
some names are changed to match the naming in the IBM/AMCC users
manuals (e.g. mem_mcopt1 -> SDRAM0_CFG).
The latest PPC4xx register cleanup patch missed the UIC defines.
Fix warning: ../common/flash.c:917: warning: dereferencing type-punned
pointer will break strict-aliasing rules
Cc: Stefan Roese <sr@denx.de>
Fix warning: flash.c:919: warning: dereferencing type-punned pointer
Fix warnings:
flash.c: In function 'write_word_1':
flash.c:696: warning: dereferencing type-punned pointer will break strict-aliasing rules
flash.c: In function 'write_word_2':
flash.c:1044: warning: dereferencing type-punned pointer will break strict-aliasing rules
This patch cleans up multiple issues of the 4xx register (mostly
DCR, SDR, CPR, etc) definitions:
- Change lower case defines to upper case (plb4_acr -> PLB4_ACR)
- Change the defines to better match the names from the
user's manuals (e.g. cprpllc -> CPR0_PLLC)
- Removal of some unused defines
Please test this patch intensive on your PPC4xx platform. Even though
I tried not to break anything and tested successfully on multiple
4xx AMCC platforms, testing on custom platforms is recommended.
This patch fixes the "chip_config" command for I2C bootstrap EEPROM
configuration. First it changes the I2C bootstrap EEPROM address to
0x54 as this is used on Arches (instead of 0x52 on Canyonlands/
Glacier). Additionally, the NAND bootstrap settings are removed
for Arches since Arches doesn't support NAND-booting.
This patch is based on a diff created by Phong Vo from AMCC.
Signed-off-by: Phong Vo <pvo@amcc.com>
This patch fixes the problem, that the current fdt board fixup code only
set's one range, the one for NOR. By this it's overwriting the already
correctly configured values done in __ft_board_setup(). Just remove this
now unneeded NOR fixup and all the ranges are correctly defined.
Cc: Dirk Eibach <eibach@gdsys.de>
Cc: Felix Radensky <felix@embedded-sol.com>
This patch adds some I2C bootstrap setting for NAND booting to the Kilauea
chip_config command ("533-nand" and "600-nand").
Additionally some incorrectly indented lines are fixed.
Testing on AMCC Arches with the latest U-Boot version yielded that DDR2
initialization is currently broken. U-Boot hangs upon relocation to SDRAM
or crashes with random traps. This patch fixes this problem. Arches now
uses a different WRDTR and CLKTR default setting than Canyonlands/Glacier.
This patch removes the "alterpll" command and replaces it with the now
ppc4xx standard "chip_config" command to configure the I2C bootstrap
EEPROM.
This patch adds a generic command for programming I2C bootstrap
eeproms on PPC4xx. An implementation for Canyonlands board is
included.
The command name is intentionally chosen not to be PPC4xx specific.
This way other CPU's/SoC's can implement a similar command under
the same name, perhaps with a different syntax.
Usage on Canyonlands:
=> chip_config
Available configurations (I2C address 0x52):
600-nor - NOR CPU: 600 PLB: 200 OPB: 100 EBC: 100
600-nand - NAND CPU: 600 PLB: 200 OPB: 100 EBC: 100
800-nor - NOR CPU: 800 PLB: 200 OPB: 100 EBC: 100
800-nand - NAND CPU: 800 PLB: 200 OPB: 100 EBC: 100
1000-nor - NOR CPU:1000 PLB: 200 OPB: 100 EBC: 100
1000-nand - NAND CPU:1000 PLB: 200 OPB: 100 EBC: 100
1066-nor - NOR CPU:1066 PLB: 266 OPB: 88 EBC: 88 ***
1066-nand - NAND CPU:1066 PLB: 266 OPB: 88 EBC: 88
=> chip_config 600-nor
Using configuration:
done (dump via 'i2c md 52 0.1 10')
Reset the board for the changes to take effect
Other 4xx boards will be migrated to use this command soon
as well.
Signed-off-by: Dirk Eibach <eibach@gdsys.de>
This patch fixes 2 problems with FDT EBC mappings on Canyonlands.
First, NAND EBC mapping was missing, making Linux NAND driver
unusable on this board. Second, NOR remapping code assumed that
NOR is always on CS0, however when booting from NAND NOR is on CS3.
Signed-off-by: Felix Radensky <felix@embedded-sol.com>
Many of the help messages were not really helpful; for example, many
commands that take no arguments would not print a correct synopsis
line, but "No additional help available." which is not exactly wrong,
but not helpful either.
Commit ``Make "usage" messages more helpful.'' changed this
partially. But it also became clear that lots of "Usage" and "Help"
messages (fields "usage" and "help" in struct cmd_tbl_s respective)
were actually redundant.
This patch cleans this up - for example:
Before:
=> help dtt
dtt - Digital Thermometer and Thermostat
Usage:
dtt - Read temperature from digital thermometer and thermostat.
After:
=> help dtt
dtt - Read temperature from Digital Thermometer and Thermostat
Usage:
dtt
This patch adds another build target for the AMCC Sequoia PPC440EPx
eval board. This RAM-booting version is targeted for boards without
NOR FLASH (NAND booting) which need a possibility to initially
program their NAND FLASH. Using a JTAG debugger (e.g. BDI2000/3000)
configured to setup the SDRAM, this debugger can load this RAM-
booting image to the target address in SDRAM (in this case 0x1000000)
and start it there. Then U-Boot's standard NAND commands can be
used to program the NAND FLASH (e.g. "nand write ...").
Here the commands to load and start this image from the BDI2000:
440EPX>reset halt
440EPX>load 0x1000000 /tftpboot/sequoia/u-boot.bin
440EPX>go 0x1000000
Please note that this image automatically scans for an already
initialized SDRAM TLB (detected by EPN=0). This TLB will not be
cleared. This TLB doesn't need to be TLB #0, this RAM-booting
version will detect it and preserve it. So booting via BDI2000
will work and booting with a complete different TLB init via
U-Boot works as well.
The current define of get_bus_freq() in the CONFIG_NAND_SPL #ifdef is not
used at all. This patch changes it's define to the currently used value of
133333333 and removes the unnecessary code.
Currently the NOR & NAND support in Linux only works for the "standard"
Sequoia, the version booting for NOR flash. The NAND-booting version
has the chip-selects swapped. Here the chip-select mappings:
"Standard" NOR-booting version:
CS0 NOR
CS3 NAND
NAND-booting version:
CS0 NAND
CS3 NOR
With this path the dtb gets fixed-up, so that the correct chip-select
numbers are patched in the dtb enabling correct NOR & NAND support
in Linux on the NAND-booting Sequoia version.
This patch fixes a bug in the Sequoia TLB init code to reconfigure
the correct TLB (boot space) after running from RAM. This bug was
introduced with patch 4d332dbeb08f5863d1ea69d91a00c5499d3a87ed
[ppc4xx: Make Sequoia boot vxWorks] which changed the order of the
TLB in the Sequoia init.S file.
A recent gcc added a new unaligned rodata section called '.rodata.str1.1',
which needs to be added the the linker script. Instead of just adding this
one section, we use a wildcard ".rodata*" to get all rodata linker section
gcc has now and might add in the future.
However, '*(.rodata*)' by itself will result in sub-optimal section
ordering. The sections will be sorted by object file, which causes extra
padding between the unaligned rodata.str.1.1 of one object file and the
aligned rodata of the next object file. This is easy to fix by using the
SORT_BY_ALIGNMENT command.
This patch has not be tested one most of the boards modified. Some boards
have a linker script that looks something like this:
*(.text)
. = ALIGN(16);
*(.rodata)
*(.rodata.str1.4)
*(.eh_frame)
I change this to:
*(.text)
. = ALIGN(16);
*(.eh_frame)
*(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*)))
This means the start of rodata will no longer be 16 bytes aligned.
However, the boundary between text and rodata/eh_frame is still aligned to
16 bytes, which is what I think the real purpose of the ALIGN call is.
Signed-off-by: Trent Piepho <xyzzy@speakeasy.org>
Sequoia board schematics (DES0211_11_SCH_11.pdf, page 5, unit U1D)
specifies that BankSel#1 is not connected, while bootloader memory
configuration is (board/amcc/sequoia/sdram.c):
mtsdram(DDR0_10, 0x00000300);
i.e. both Chip Selects used - not correct.
If we change to correct value here:
mtsdram(DDR0_10, 0x00000100);
memory is accessible OK also.
Signed-off-by: Mikhail Zolotaryov <lebon@lebon.org.ua>
Some AMCC eval boards do have a board_eth_init() function calling
pci_eth_init(). These boards need to call cpu_eth_init() explicitly now
with the new eth_init rework.
Remove command name from all command "usage" fields and update
common/command.c to display "name - usage" instead of
just "usage". Also remove newlines from command usage fields.
Update taihu and taishan commands to use cmd_usage() function
to display usage messages.
Expanded OCM TLB to allow access to 64K OCM as well as 256K of
internal SRAM.
Adjusted internal SRAM initialization to match updated user
manual recommendation.
OCM & ISRAM are now mapped as follows:
physical virtual size
ISRAM 0x4_0000_0000 0xE300_0000 256k
OCM 0x4_0004_0000 0xE304_0000 64k
A single TLB was used for this mapping.
Signed-off-by: Dave Mitchell <dmitch71@gmail.com>
Added include/asm-ppc/ppc4xx-isram.h and moved internal SRAM and
L2 cache DCRs from ppc440.h to this new header.
Also converted these DCR defines from lowercase to uppercase and
modified referencing modules to use them.
Most of the bss initialization loop increments 4 bytes
at a time. And the loop end is checked for an 'equal'
condition. Make the bss end address aligned by 4, so
that the loop will end as expected.
Signed-off-by: Selvamuthukumar <selva.muthukumar@e-coninfotech.com>
