path: root/board/amcc
2009-08-18ppc4xx: Fix "chip_config" command for AMCC ArchesStefan Roese
This patch fixes the "chip_config" command for I2C bootstrap EEPROM configuration. First it changes the I2C bootstrap EEPROM address to 0x54 as this is used on Arches (instead of 0x52 on Canyonlands/ Glacier). Additionally, the NAND bootstrap settings are removed for Arches since Arches doesn't support NAND-booting. Signed-off-by: Stefan Roese <sr@denx.de>
2009-07-30ppc4xx: Add support for PPC460EX/460GT rev B chip to AMCC CanyonlandsStefan Roese
This patch is based on a diff created by Phong Vo from AMCC. Signed-off-by: Phong Vo <pvo@amcc.com> Signed-off-by: Stefan Roese <sr@denx.de>
2009-07-28ppc4xx: Fix problem with NOR range assignment in Canyonlands ft_board_setupStefan Roese
This patch fixes the problem, that the current fdt board fixup code only set's one range, the one for NOR. By this it's overwriting the already correctly configured values done in __ft_board_setup(). Just remove this now unneeded NOR fixup and all the ranges are correctly defined. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Dirk Eibach <eibach@gdsys.de> Cc: Felix Radensky <felix@embedded-sol.com>
2009-07-28ppc4xx: Add some NAND-booting bootstrap entries to Kilauea chip_config cmdStefan Roese
This patch adds some I2C bootstrap setting for NAND booting to the Kilauea chip_config command ("533-nand" and "600-nand"). Additionally some incorrectly indented lines are fixed. Signed-off-by: Stefan Roese <sr@denx.de>
2009-07-28ppc4xx: Fix Arches DDR2 initializationStefan Roese
Testing on AMCC Arches with the latest U-Boot version yielded that DDR2 initialization is currently broken. U-Boot hangs upon relocation to SDRAM or crashes with random traps. This patch fixes this problem. Arches now uses a different WRDTR and CLKTR default setting than Canyonlands/Glacier. Signed-off-by: Stefan Roese <sr@denx.de>
2009-07-24ppc4xx: Add chip_config command to AMCC Kilauea eval boardStefan Roese
This patch removes the "alterpll" command and replaces it with the now ppc4xx standard "chip_config" command to configure the I2C bootstrap EEPROM. Signed-off-by: Stefan Roese <sr@denx.de>
2009-07-24Add "chip_config" command for PPC4xx bootstrap configurationStefan Roese
This patch adds a generic command for programming I2C bootstrap eeproms on PPC4xx. An implementation for Canyonlands board is included. The command name is intentionally chosen not to be PPC4xx specific. This way other CPU's/SoC's can implement a similar command under the same name, perhaps with a different syntax. Usage on Canyonlands: => chip_config Available configurations (I2C address 0x52): 600-nor - NOR CPU: 600 PLB: 200 OPB: 100 EBC: 100 600-nand - NAND CPU: 600 PLB: 200 OPB: 100 EBC: 100 800-nor - NOR CPU: 800 PLB: 200 OPB: 100 EBC: 100 800-nand - NAND CPU: 800 PLB: 200 OPB: 100 EBC: 100 1000-nor - NOR CPU:1000 PLB: 200 OPB: 100 EBC: 100 1000-nand - NAND CPU:1000 PLB: 200 OPB: 100 EBC: 100 1066-nor - NOR CPU:1066 PLB: 266 OPB: 88 EBC: 88 *** 1066-nand - NAND CPU:1066 PLB: 266 OPB: 88 EBC: 88 => chip_config 600-nor Using configuration: 600-nor - NOR CPU: 600 PLB: 200 OPB: 100 EBC: 100 done (dump via 'i2c md 52 0.1 10') Reset the board for the changes to take effect Other 4xx boards will be migrated to use this command soon as well. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Dirk Eibach <eibach@gdsys.de> Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu>
2009-07-08ppc4xx: Fix FDT EBC mappings on CanyonlandsFelix Radensky
This patch fixes 2 problems with FDT EBC mappings on Canyonlands. First, NAND EBC mapping was missing, making Linux NAND driver unusable on this board. Second, NOR remapping code assumed that NOR is always on CS0, however when booting from NAND NOR is on CS3. Signed-off-by: Felix Radensky <felix@embedded-sol.com> Signed-off-by: Stefan Roese <sr@denx.de>
2009-06-12General help message cleanupWolfgang Denk
Many of the help messages were not really helpful; for example, many commands that take no arguments would not print a correct synopsis line, but "No additional help available." which is not exactly wrong, but not helpful either. Commit ``Make "usage" messages more helpful.'' changed this partially. But it also became clear that lots of "Usage" and "Help" messages (fields "usage" and "help" in struct cmd_tbl_s respective) were actually redundant. This patch cleans this up - for example: Before: => help dtt dtt - Digital Thermometer and Thermostat Usage: dtt - Read temperature from digital thermometer and thermostat. After: => help dtt dtt - Read temperature from Digital Thermometer and Thermostat Usage: dtt Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-06-12ppc4xx: Add Sequoia RAM-booting targetStefan Roese
This patch adds another build target for the AMCC Sequoia PPC440EPx eval board. This RAM-booting version is targeted for boards without NOR FLASH (NAND booting) which need a possibility to initially program their NAND FLASH. Using a JTAG debugger (e.g. BDI2000/3000) configured to setup the SDRAM, this debugger can load this RAM- booting image to the target address in SDRAM (in this case 0x1000000) and start it there. Then U-Boot's standard NAND commands can be used to program the NAND FLASH (e.g. "nand write ..."). Here the commands to load and start this image from the BDI2000: 440EPX>reset halt 440EPX>load 0x1000000 /tftpboot/sequoia/u-boot.bin 440EPX>go 0x1000000 Please note that this image automatically scans for an already initialized SDRAM TLB (detected by EPN=0). This TLB will not be cleared. This TLB doesn't need to be TLB #0, this RAM-booting version will detect it and preserve it. So booting via BDI2000 will work and booting with a complete different TLB init via U-Boot works as well. Signed-off-by: Stefan Roese <sr@denx.de>
2009-04-16ppc4xx: Remove unused code for Sequoia NAND booting versionStefan Roese
The current define of get_bus_freq() in the CONFIG_NAND_SPL #ifdef is not used at all. This patch changes it's define to the currently used value of 133333333 and removes the unnecessary code. Signed-off-by: Stefan Roese <sr@denx.de>
2009-04-16ppc4xx: Fixup chip-selects in dtb for NAND-booting SequoiaStefan Roese
Currently the NOR & NAND support in Linux only works for the "standard" Sequoia, the version booting for NOR flash. The NAND-booting version has the chip-selects swapped. Here the chip-select mappings: "Standard" NOR-booting version: CS0 NOR CS3 NAND NAND-booting version: CS0 NAND CS3 NOR With this path the dtb gets fixed-up, so that the correct chip-select numbers are patched in the dtb enabling correct NOR & NAND support in Linux on the NAND-booting Sequoia version. Signed-off-by: Stefan Roese <sr@denx.de>
2009-03-26ppc4xx: Sequoia: Fix TLB reassignment in NAND booting codeStefan Roese
This patch fixes a bug in the Sequoia TLB init code to reconfigure the correct TLB (boot space) after running from RAM. This bug was introduced with patch 4d332dbeb08f5863d1ea69d91a00c5499d3a87ed [ppc4xx: Make Sequoia boot vxWorks] which changed the order of the TLB in the Sequoia init.S file. Signed-off-by: Stefan Roese <sr@denx.de>
2009-03-17Fix AMCC Sequoia board DDR memory configurationMikhail Zolotaryov
Sequoia board schematics (DES0211_11_SCH_11.pdf, page 5, unit U1D) specifies that BankSel#1 is not connected, while bootloader memory configuration is (board/amcc/sequoia/sdram.c): mtsdram(DDR0_10, 0x00000300); i.e. both Chip Selects used - not correct. If we change to correct value here: mtsdram(DDR0_10, 0x00000100); memory is accessible OK also. Signed-off-by: Mikhail Zolotaryov <lebon@lebon.org.ua> Signed-off-by: Stefan Roese <sr@denx.de>
2009-02-12ppc4xx: Fix problem with board_eth_init() vs cpu_eth_init() on AMCC boardsStefan Roese
Some AMCC eval boards do have a board_eth_init() function calling pci_eth_init(). These boards need to call cpu_eth_init() explicitly now with the new eth_init rework. Signed-off-by: Stefan Roese <sr@denx.de>
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-01-28amcc: Clean up command usage outputPeter Tyser
Update taihu and taishan commands to use cmd_usage() function to display usage messages. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-01-28Standardize command usage messages with cmd_usage()Peter Tyser
2008-11-21ppc4xx: Changed 460EX/GT OCM TLB and internal SRAM initializationDave Mitchell
Expanded OCM TLB to allow access to 64K OCM as well as 256K of internal SRAM. Adjusted internal SRAM initialization to match updated user manual recommendation. OCM & ISRAM are now mapped as follows: physical virtual size ISRAM 0x4_0000_0000 0xE300_0000 256k OCM 0x4_0004_0000 0xE304_0000 64k A single TLB was used for this mapping. Signed-off-by: Dave Mitchell <dmitch71@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-11-21ppc4xx: Added ppc4xx-isram.h for internal SRAM and L2 cache DCRsDave Mitchell
Added include/asm-ppc/ppc4xx-isram.h and moved internal SRAM and L2 cache DCRs from ppc440.h to this new header. Also converted these DCR defines from lowercase to uppercase and modified referencing modules to use them. Signed-off-by: Dave Mitchell <dmitch71@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-11-02Coding Style cleanup, update CHANGELOGWolfgang Denk
2008-10-21Merge branch 'master' of git://git.denx.de/u-boot-ppc4xxWolfgang Denk
2008-10-21ppc4xx: Add 1.0 & 1.066 GHz to canyonlands bootstrap command for PLL setupStefan Roese
2008-10-21ppc4xx: Add AMCC Arches board support (dual 460GT)Adam Graham
The Arches Evaluation board is based on the AMCC 460GT SoC chip. This board is a dual processor board with each processor providing independent resources for Rapid IO, Gigabit Ethernet, and serial communications. Each 460GT has it's own 512MB DDR2 memory, 32MB NOR FLASH, UART, EEPROM and temperature sensor, along with a shared debug port. The two 460GT's will communicate with each other via shared memory, Gigabit Ethernet and x1 PCI-Express. Signed-off-by: Adam Graham <agraham@amcc.com> Signed-off-by: Victor Gallardo <vgallardo@amcc.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-10-21Cleanup: fix "MHz" spellingWolfgang Denk
2008-09-22ppc4xx: Canyonlands: Remove unnecessary FDT warning upon DTB fixupStefan Roese
Depending on the configuration jumper "SATA SELECT", U-Boot disabled either one PCIe node or the SATA node in the device tree blob. This patch removes the unnecessary and even confusing warning, when the node is not found at all. Signed-off-by: Stefan Roese <sr@denx.de>
2008-09-12Merge branch 'Makefile-next' of git://git.denx.de/u-boot-armWolfgang Denk
2008-09-12ppc4xx: Fix SDRAM inititialization of multiple 405 based board portsStefan Roese
This patch fixes a problem introdiced with patch bbeff30c [ppc4xx: Remove superfluous dram_init() call or replace it by initdram()]. The boards affected are: - PCI405 - PPChameleonEVB - quad100hd - taihu - zeus Signed-off-by: Stefan Roese <sr@denx.de>
2008-09-10move cmd_get_data_size to command.cJean-Christophe PLAGNIOL-VILLARD
add CMD_DATA_SIZE macro to enable it Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-09-02Moved initialization of EEPRO100 Ethernet controller to board_eth_init()Ben Warren
Affected boards: db64360 db64460 katmai taihu taishan yucca cpc45 cpu87 eXalion elppc debris kvme080 mpc8315erdb integratorap ixdp425 oxc pm826 pm828 pm854 pm856 ppmc7xx sc3 sc520_spunk sorcery tqm8272 tqm85xx utx8245 Removed initialization of the driver from net/eth.c Also, wrapped contents of pci_eth_init() by CONFIG_PCI. Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-08-12Merge branch 'master' of /home/stefan/git/u-boot/u-boot into nextStefan Roese
2008-08-07ppc4xx: Sequoia has two UARTs in "4-pin" mode. Configure the GPIOs as per ↵Steven A. Falco
schematic. The Sequoia board has two UARTs in "4-pin" mode. This patch modifies the GPIO configuration to match the schematic, and also sets the SDR0_PFC1 register to select the corresponding mode for the UARTs. Signed-off-by: Steven A. Falco <sfalco@harris.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-07-14Merge branch 'master' of /home/stefan/git/u-boot/u-boot into nextStefan Roese
2008-07-13ppc4xx: Remove redundant ft_board_setup() functions from some 4xx boardsStefan Roese
This patch removes some ft_board_setup() functions from some 4xx boards. This can be done since we now have a default weak implementation for this in cpu/ppc4xx/fdt.c. Only board in need for a different/custom implementation like canyonlands need their own version. Signed-off-by: Stefan Roese <sr@denx.de>
2008-07-11Fix some more printf() format issues.Wolfgang Denk
2008-07-11ppc4xx: Some Rewood cleanups (coding style, leading white spaces)Stefan Roese
2008-07-11ppc4xx: Cleanup Katmai & Yucca PCIe register usageStefan Roese
This patch cleans up the 440SPe PCIe register usage. Now only defines from the include/asm-ppc/4xx_pcie.h are used. Signed-off-by: Stefan Roese <sr@denx.de>
2008-07-11ppc4xx: Rework 440GX UIC handlingStefan Roese
This patch reworks the 440GX interrupt handling so that the common 4xx code can be used. The 440GX is an exception to all other 4xx variants by having the cascading interrupt vectors not on UIC0 but on a special UIC named UICB0 (UIC Base 0). With this patch now, U-Boot references the 440GX UICB0 when UIC0 is selected. And the common 4xx interrupt handling is simpler without any 440GX special cases. Also some additional cleanup to cpu/ppc4xx/interrupt.c is done. Signed-off-by: Stefan Roese <sr@denx.de>
2008-07-11ppc4xx: Consolidate PPC4xx UIC definesStefan Roese
This 2nd patch now removes all UIC mask bit definition. They should be generated from the vectors by using the UIC_MASK() macro from now on. This way only the vectors need to get defined for new PPC's. Also only the really used interrupt vectors are now defined. This makes definitions for new PPC versions easier and less error prone. Another part of this patch is that the 4xx emac driver got a little cleanup, since now the usage of the interrupts is clearer. Signed-off-by: Stefan Roese <sr@denx.de>
This patch is the first step to consolidate the UIC related defines in the 4xx headers. Move header from asm-ppc/ppc4xx-intvec.h to asm-ppc/ppc4xx-uic.h as it will hold all UIC related defines in the next steps. Signed-off-by: Stefan Roese <sr@denx.de>
2008-07-11ppc4xx: Remove redundant ft_board_setup() functions from some 4xx boardsStefan Roese
2008-07-11ppc4xx: Initial framework of the AMCC PPC460SX redwood reference board.Feng Kan
Add AMCC Redwood reference board that uses the latest PPC 464 CPU processor combined with a rich mix of peripheral controllers. The board will support PCIe, mutiple Gig ethernet ports, advanced hardware RAID assistance and IEEE 1588. Signed-off-by: Feng Kan <fkan@amcc.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-07-10ppc4xx: Fix printf format warnings now visible with the updated format checkStefan Roese
This patch fixes ppc4xx related printf format warning. Those warnings are now visible since patch dc4b0b38d4aadf08826f6c31270f1eecd27964fd [Fix printf errors.] by Andrew Klossner has been applied. Thanks, this is really helpful. Signed-off-by: Stefan Roese <sr@denx.de>
2008-07-02Cleanup: remove redundant deleting on *~ filesWolfgang Denk
