path: root/board/amcc/yucca/flash.c
2010-09-23ppc4xx: Move ppc4xx headers to powerpc include directoryStefan Roese
This patch moves some ppc4xx related headers from the common include directory (include/) to the powerpc specific one (arch/powerpc/include/asm/). This way to common include directory is not so cluttered with files. Signed-off-by: Stefan Roese <sr@denx.de>
2009-09-15Merge branch 'master' of git://git.denx.de/u-boot-ppc4xxWolfgang Denk
2009-09-15board/amcc/yucca/flash.c: Fix compile warningWolfgang Denk
Fix warning: flash.c:919: warning: dereferencing type-punned pointer will break strict-aliasing rules Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2009-09-11ppc4xx: Big cleanup of PPC4xx definesStefan Roese
This patch cleans up multiple issues of the 4xx register (mostly DCR, SDR, CPR, etc) definitions: - Change lower case defines to upper case (plb4_acr -> PLB4_ACR) - Change the defines to better match the names from the user's manuals (e.g. cprpllc -> CPR0_PLLC) - Removal of some unused defines Please test this patch intensive on your PPC4xx platform. Even though I tried not to break anything and tested successfully on multiple 4xx AMCC platforms, testing on custom platforms is recommended. Signed-off-by: Stefan Roese <sr@denx.de>
2006-07-19Add support for TB5200 boardWolfgang Denk
The TB5200 ("Tinybox") is a small baseboard for the TQM5200 module integrated in a little aluminium case. Patch by Martin Krause, 8 Jun 2006 Some code cleanup
2006-06-30Add support for AMCC 440SPe CPU based eval board (Yucca).Marian Balakowicz
