path: root/board/amcc/yosemite/Makefile
2005-08-11Update AMCC Yosemite to get a consistent setup for all AMCC evalStefan Roese
boards (baudrate, environment...). Flash driver fixed. Patch by Stefan Roese, 11 Aug 2005
2005-08-01Add support for AMCC PPC440EP/GR eval boards Yosemite and Yellowstone.Stefan Roese
Patch by Steven Blakeslee, 27 Jul 2005
