path: root/board/amcc/taishan
2011-10-22consolidate mdelay by providing a common function for all usersAnatolij Gustschin
There are several mdelay() definitions in the driver and board code. Remove them all and provide a common mdelay() in lib/time.c. Signed-off-by: Anatolij Gustschin <agust@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-05-12Fix incorrect use of getenv() before relocationWolfgang Denk
A large number of boards incorrectly used getenv() in their board init code running before relocation. In some cases this caused U-Boot to hang when certain environment variables grew too long. Fix the code to use getenv_r(). Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: The LEOX team <team@leox.org> Cc: Michael Schwingen <michael@schwingen.org> Cc: Georg Schardt <schardt@team-ctech.de> Cc: Werner Pfister <Pfister_Werner@intercontrol.de> Cc: Dirk Eibach <eibach@gdsys.de> Cc: Peter De Schrijver <p2@mind.be> Cc: John Zhan <zhanz@sinovee.com> Cc: Rishi Bhattacharya <rishi@ti.com> Cc: Peter Tyser <ptyser@xes-inc.com>
2010-09-23ppc4xx: Use common NS16550 driver for PPC4xx UARTStefan Roese
This patch removes the PPC4xx UART driver. Instead the common NS16550 driver is used, since all PPC4xx SoC's use this peripheral device. The file 4xx_uart.c now only implements the UART clock calculation function which also sets the SoC internal UART divisors. All PPC4xx board config headers are changed to use this common NS16550 driver now. Tested on these boards: acadia, canyonlands, katmai, kilauea, sequoia, zeus Signed-off-by: Stefan Roese <sr@denx.de>
2010-09-23ppc4xx: Move ppc4xx headers to powerpc include directoryStefan Roese
This patch moves some ppc4xx related headers from the common include directory (include/) to the powerpc specific one (arch/powerpc/include/asm/). This way to common include directory is not so cluttered with files. Signed-off-by: Stefan Roese <sr@denx.de>
2010-07-24cmd_usage(): simplify return code handlingWolfgang Denk
Lots of code use this construct: cmd_usage(cmdtp); return 1; Change cmd_usage() let it return 1 - then we can replace all these ocurrances by return cmd_usage(cmdtp); This fixes a few places with incorrect return code handling, too. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-04-19ppc4xx: TLB init file cleanupStefan Roese
This patch adds new macros, with frequently used combinations of the 4xx TLB access control and storage attibutes. Additionally the 4xx init.S files are updated to make use of these new macros. Resulting in easier to read TLB definitions. Additionally some init.S files are updated to use the mmu header for the TLB defines, instead of defining their own macros. Signed-off-by: Stefan Roese <sr@denx.de>
2009-12-07POST: Remove duplicated post_hotkey_pressed() functionsStefan Roese
This patch introduces a weak default function for post_hotkey_pressed(), returning 0, for boards without hotkey support. The long-running tests won't be started on those boards. This default function was implemented in many board directories. By implementing this weak default we can remove all those duplicate versions. Boards with hotkey support, can override this weak default function by defining one in their board specific code. Signed-off-by: Stefan Roese <sr@denx.de>
2009-11-19ppc4xx: Consolidate pci_pre_init() functionStefan Roese
This patch removes the duplicted implementations of the pci_pre_init() function by introducing a weak default function for it. This weak default has a different implementation for some PPC variants. It can be overridden by a board specific version. Signed-off-by: Stefan Roese <sr@denx.de>
2009-11-19ppc4xx: Consolidate pci_target_init() functionStefan Roese
This patch removes the duplicted implementations of the pci_target_init() function by introducing a weak default function for it. This weak default has a different implementation for 440EP(x)/GR(x) PPC's. It can be overridden by a board specific version (e.g. PMC440, korat). Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu>
2009-11-09ppc4xx: Remove duplicated is_pci_host() functionsStefan Roese
This patch introduces a weak default function for is_pci_host(), returning 1. This is the default behaviour, since most boards only implement PCI host functionality. This weak default can be overridden by a board specific version if needed. Signed-off-by: Stefan Roese <sr@denx.de>
2009-11-02ppc4xx: Remove board specific linker scripts from most PPC4xx boardsStefan Roese
All these linker scripts can be removed since the new common ppc4xx linker script should be able to handle all of those boards. Please test and report problems. Thanks. Signed-off-by: Stefan Roese <sr@denx.de>
2009-10-09Merge branch 'reloc'Wolfgang Denk
2009-10-07ppc_4xx: Apply new HW register namesNiklaus Giger
Modify all existing *.c files to use the new register names as seen in the AMCC manuals. Signed-off-by: Niklaus Giger <niklaus.giger@member.fsf.org> Signed-off-by: Stefan Roese <sr@denx.de>
2009-10-03ppc: Enable full relocation to RAMPeter Tyser
The following changes allow U-Boot to fully relocate from flash to RAM: - Remove linker scripts' .fixup sections from the .text section - Add -mrelocatable to PLATFORM_RELFLAGS for all boards - Define CONFIG_RELOC_FIXUP_WORKS for all boards Previously, U-Boot would partially relocate, but statically initialized pointers needed to be manually relocated. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-09-28ppc4xx: Convert PPC4xx UIC defines from lower case to upper caseStefan Roese
The latest PPC4xx register cleanup patch missed the UIC defines. This patch now changes lower case UIC defines to upper case. Signed-off-by: Stefan Roese <sr@denx.de>
2009-09-11ppc4xx: Big cleanup of PPC4xx definesStefan Roese
This patch cleans up multiple issues of the 4xx register (mostly DCR, SDR, CPR, etc) definitions: - Change lower case defines to upper case (plb4_acr -> PLB4_ACR) - Change the defines to better match the names from the user's manuals (e.g. cprpllc -> CPR0_PLLC) - Removal of some unused defines Please test this patch intensive on your PPC4xx platform. Even though I tried not to break anything and tested successfully on multiple 4xx AMCC platforms, testing on custom platforms is recommended. Signed-off-by: Stefan Roese <sr@denx.de>
2009-06-12General help message cleanupWolfgang Denk
Many of the help messages were not really helpful; for example, many commands that take no arguments would not print a correct synopsis line, but "No additional help available." which is not exactly wrong, but not helpful either. Commit ``Make "usage" messages more helpful.'' changed this partially. But it also became clear that lots of "Usage" and "Help" messages (fields "usage" and "help" in struct cmd_tbl_s respective) were actually redundant. This patch cleans this up - for example: Before: => help dtt dtt - Digital Thermometer and Thermostat Usage: dtt - Read temperature from digital thermometer and thermostat. After: => help dtt dtt - Read temperature from Digital Thermometer and Thermostat Usage: dtt Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-02-12ppc4xx: Fix problem with board_eth_init() vs cpu_eth_init() on AMCC boardsStefan Roese
Some AMCC eval boards do have a board_eth_init() function calling pci_eth_init(). These boards need to call cpu_eth_init() explicitly now with the new eth_init rework. Signed-off-by: Stefan Roese <sr@denx.de>
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-01-28amcc: Clean up command usage outputPeter Tyser
Update taihu and taishan commands to use cmd_usage() function to display usage messages. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-09-02Moved initialization of EEPRO100 Ethernet controller to board_eth_init()Ben Warren
Affected boards: db64360 db64460 katmai taihu taishan yucca cpc45 cpu87 eXalion elppc debris kvme080 mpc8315erdb integratorap ixdp425 oxc pm826 pm828 pm854 pm856 ppmc7xx sc3 sc520_spunk sorcery tqm8272 tqm85xx utx8245 Removed initialization of the driver from net/eth.c Also, wrapped contents of pci_eth_init() by CONFIG_PCI. Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-07-14Merge branch 'master' of /home/stefan/git/u-boot/u-boot into nextStefan Roese
2008-07-11Fix some more printf() format issues.Wolfgang Denk
2008-07-11ppc4xx: Rework 440GX UIC handlingStefan Roese
This patch reworks the 440GX interrupt handling so that the common 4xx code can be used. The 440GX is an exception to all other 4xx variants by having the cascading interrupt vectors not on UIC0 but on a special UIC named UICB0 (UIC Base 0). With this patch now, U-Boot references the 440GX UICB0 when UIC0 is selected. And the common 4xx interrupt handling is simpler without any 440GX special cases. Also some additional cleanup to cpu/ppc4xx/interrupt.c is done. Signed-off-by: Stefan Roese <sr@denx.de>
2008-06-03ppc4xx: Remove implementations of testdram()Stefan Roese
This patch removes the used testdram() implementations of the board that are maintained by myself. Signed-off-by: Stefan Roese <sr@denx.de>
2007-10-31ppc4xx: Rework of 4xx serial driver (2)Stefan Roese
Change all linker scripts to reference the changed driver name 4xx_uart.o. Note: In most cased all these explicit referencing of these object files in the linker scripts is not neccessary. Only for manually embedded environment into the U-Boot image, which is not done is most cases. Signed-off-by: Stefan Roese <sr@denx.de>
2007-10-31ppc4xx: Consolidate some of the 405 and 440 macros/structs into 4xxStefan Roese
This patch moves some common 4xx macros and the PPC405_SYS_INFO/ PPC440_SYS_INFO structure into the common ppc4xx.h header. Lot's of other macros are good candidates to be consolidated this way in the future. Signed-off-by: Stefan Roese <sr@denx.de>
2007-09-15Fix cases where DECLARE_GLOBAL_DATA_PTR was not declared as globalWolfgang Denk
2007-06-25ppc4xx: Add pci_pre_init() for 405 boardsStefan Roese
This patch removes the CFG_PCI_PRE_INIT option completely, since it's not needed anymore with the patch from Matthias Fuchs with the "weak" pci_pre_init() implementation. Signed-off-by: Stefan Roese <sr@denx.de>
2007-01-19Minor code cleanup.Wolfgang Denk
2007-01-18[PATCH] Add support for AMCC Taishan PPC440GX eval boardStefan Roese
