path: root/board/amcc/sequoia
2011-03-27rename _end to __bss_end__Po-Yu Chuang
Currently, _end is used for end of BSS section. We want _end to mean end of u-boot image, so we rename _end to __bss_end__ first. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2010-11-27ppc4xx: Cleanup for partial linking and --gc-sectionsWolfgang Denk
This commit adapts 4xx boards for partial linking with --gc-sections. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Tirumala Marri <tmarri@apm.com> Cc: David Updegraff <dave@cray.com> Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Cc: Dirk Eibach <eibach@gdsys.de> Cc: Larry Johnson <lrj@acm.org> Cc: Peter De Schrijver <p2@mind.be> Cc: Niklaus Giger <niklaus.giger@netstal.com> Cc: Daniel Poirot <dan.poirot@windriver.com> Acked-by: Stefan Roese <sr@denx.de>
2010-10-20ppc4xx: Enable NOR flash support in sequoia_ramboot targetStefan Roese
Until now, the Sequoia RAM-booting image disabled NOR flash support as this image was mainly created for NAND-only boards. This patch now enables NOR flash support for this RAM-booting version as well. Signed-off-by: Stefan Roese <sr@denx.de>
2010-09-23ppc4xx: Big header cleanup, mostly PPC440 relatedStefan Roese
This patch starts a bit PPC4xx header cleanup. First patch mostly touches PPC440 files. A later patch will touch the PPC405 files as well. This cleanup is done by creating header files for all SoC versions and moving the SoC specific defines into these special headers. This way the common header ppc405.h and ppc440.h can be cleaned up finally. Signed-off-by: Stefan Roese <sr@denx.de>
2010-09-23ppc4xx: Move gpio.h to ppc4xx-gpio.h since its ppc4xx specificStefan Roese
2010-09-23ppc4xx: Move ppc4xx headers to powerpc include directoryStefan Roese
This patch moves some ppc4xx related headers from the common include directory (include/) to the powerpc specific one (arch/powerpc/include/asm/). This way to common include directory is not so cluttered with files. Signed-off-by: Stefan Roese <sr@denx.de>
2010-09-194xx: adjust TEXT_BASE to increase U-Boot image sizeWolfgang Denk
On some boards (canyonlands, luan, sequoia) we need more room for the U-Boot image to allow for new features like the new environment code. Shift TEXT_BASE as needed. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2010-04-24Merge branch 'master' of git://git.denx.de/u-boot-ppc4xxWolfgang Denk
2010-04-19ppc4xx: TLB init file cleanupStefan Roese
This patch adds new macros, with frequently used combinations of the 4xx TLB access control and storage attibutes. Additionally the 4xx init.S files are updated to make use of these new macros. Resulting in easier to read TLB definitions. Additionally some init.S files are updated to use the mmu header for the TLB defines, instead of defining their own macros. Signed-off-by: Stefan Roese <sr@denx.de>
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2010-04-13Replace "#include <asm-$ARCH/$FILE>" with "#include <asm/$FILE>"Peter Tyser
The appropriate include/asm-$ARCH directory should already by symlinked to include/asm so using the whole "asm-$ARCH" path is unnecessary. This change should also allow us to move the include/asm-$ARCH directories into their appropriate lib/$ARCH/ directories. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-12-07POST: Remove duplicated post_hotkey_pressed() functionsStefan Roese
This patch introduces a weak default function for post_hotkey_pressed(), returning 0, for boards without hotkey support. The long-running tests won't be started on those boards. This default function was implemented in many board directories. By implementing this weak default we can remove all those duplicate versions. Boards with hotkey support, can override this weak default function by defining one in their board specific code. Signed-off-by: Stefan Roese <sr@denx.de>
2009-11-19ppc4xx: Consolidate pci_master_init() functionStefan Roese
This patch removes the duplicted implementations of the pci_master_init() function by introducing a weak default function for it. It can be overridden by a board specific version. Signed-off-by: Stefan Roese <sr@denx.de>
2009-11-19ppc4xx: Consolidate pci_pre_init() functionStefan Roese
This patch removes the duplicted implementations of the pci_pre_init() function by introducing a weak default function for it. This weak default has a different implementation for some PPC variants. It can be overridden by a board specific version. Signed-off-by: Stefan Roese <sr@denx.de>
2009-11-19ppc4xx: Consolidate pci_target_init() functionStefan Roese
This patch removes the duplicted implementations of the pci_target_init() function by introducing a weak default function for it. This weak default has a different implementation for 440EP(x)/GR(x) PPC's. It can be overridden by a board specific version (e.g. PMC440, korat). Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu>
2009-11-09ppc4xx: Fix NAND booting targets after 4xx linker script consolidationStefan Roese
Somehow I missed the NAND booting targets in the 4xx linker script consolidation patchset. This patch fixes this issue. Signed-off-by: Stefan Roese <sr@denx.de>
2009-11-09ppc4xx: Remove duplicated is_pci_host() functionsStefan Roese
This patch introduces a weak default function for is_pci_host(), returning 1. This is the default behaviour, since most boards only implement PCI host functionality. This weak default can be overridden by a board specific version if needed. Signed-off-by: Stefan Roese <sr@denx.de>
2009-11-02ppc4xx: Remove board specific linker scripts from most PPC4xx boardsStefan Roese
All these linker scripts can be removed since the new common ppc4xx linker script should be able to handle all of those boards. Please test and report problems. Thanks. Signed-off-by: Stefan Roese <sr@denx.de>
2009-10-23ppc4xx: Sequoia: Add chip_config commandStefan Roese
This patch removes the Sequoia "bootstrap" command and replaces it with the now common command "chip_config". Please note that the patches with the dynamic PCI sync clock configuration have to be applied, before this one should go in. This is because Sequoia has 2 different bootstrap EEPROMs, and the old bootstrap command configured different values depending on the detected PCI async clock (33 vs. 66MHz). With the PCI sync clock patches, this is not necessary anymore. The PCI sync clock will be configured correctly on-the-fly now. Signed-off-by: Stefan Roese <sr@denx.de>
2009-10-23ppc4xx: Sequoia/Rainer: Check and reconfigure the PCI sync clockStefan Roese
This patch now uses the 440EP(x)/GR(x) function to check and dynamically reconfigure the PCI sync clock. Signed-off-by: Stefan Roese <sr@denx.de>
2009-10-09Merge branch 'reloc'Wolfgang Denk
2009-10-07ppc_4xx: Apply new HW register namesNiklaus Giger
Modify all existing *.c files to use the new register names as seen in the AMCC manuals. Signed-off-by: Niklaus Giger <niklaus.giger@member.fsf.org> Signed-off-by: Stefan Roese <sr@denx.de>
2009-10-03ppc: Enable full relocation to RAMPeter Tyser
The following changes allow U-Boot to fully relocate from flash to RAM: - Remove linker scripts' .fixup sections from the .text section - Add -mrelocatable to PLATFORM_RELFLAGS for all boards - Define CONFIG_RELOC_FIXUP_WORKS for all boards Previously, U-Boot would partially relocate, but statically initialized pointers needed to be manually relocated. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-09-28ppc4xx: Convert PPC4xx UIC defines from lower case to upper caseStefan Roese
The latest PPC4xx register cleanup patch missed the UIC defines. This patch now changes lower case UIC defines to upper case. Signed-off-by: Stefan Roese <sr@denx.de>
2009-09-11ppc4xx: Big cleanup of PPC4xx definesStefan Roese
This patch cleans up multiple issues of the 4xx register (mostly DCR, SDR, CPR, etc) definitions: - Change lower case defines to upper case (plb4_acr -> PLB4_ACR) - Change the defines to better match the names from the user's manuals (e.g. cprpllc -> CPR0_PLLC) - Removal of some unused defines Please test this patch intensive on your PPC4xx platform. Even though I tried not to break anything and tested successfully on multiple 4xx AMCC platforms, testing on custom platforms is recommended. Signed-off-by: Stefan Roese <sr@denx.de>
2009-06-12General help message cleanupWolfgang Denk
Many of the help messages were not really helpful; for example, many commands that take no arguments would not print a correct synopsis line, but "No additional help available." which is not exactly wrong, but not helpful either. Commit ``Make "usage" messages more helpful.'' changed this partially. But it also became clear that lots of "Usage" and "Help" messages (fields "usage" and "help" in struct cmd_tbl_s respective) were actually redundant. This patch cleans this up - for example: Before: => help dtt dtt - Digital Thermometer and Thermostat Usage: dtt - Read temperature from digital thermometer and thermostat. After: => help dtt dtt - Read temperature from Digital Thermometer and Thermostat Usage: dtt Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-06-12ppc4xx: Add Sequoia RAM-booting targetStefan Roese
This patch adds another build target for the AMCC Sequoia PPC440EPx eval board. This RAM-booting version is targeted for boards without NOR FLASH (NAND booting) which need a possibility to initially program their NAND FLASH. Using a JTAG debugger (e.g. BDI2000/3000) configured to setup the SDRAM, this debugger can load this RAM- booting image to the target address in SDRAM (in this case 0x1000000) and start it there. Then U-Boot's standard NAND commands can be used to program the NAND FLASH (e.g. "nand write ..."). Here the commands to load and start this image from the BDI2000: 440EPX>reset halt 440EPX>load 0x1000000 /tftpboot/sequoia/u-boot.bin 440EPX>go 0x1000000 Please note that this image automatically scans for an already initialized SDRAM TLB (detected by EPN=0). This TLB will not be cleared. This TLB doesn't need to be TLB #0, this RAM-booting version will detect it and preserve it. So booting via BDI2000 will work and booting with a complete different TLB init via U-Boot works as well. Signed-off-by: Stefan Roese <sr@denx.de>
2009-04-16ppc4xx: Remove unused code for Sequoia NAND booting versionStefan Roese
The current define of get_bus_freq() in the CONFIG_NAND_SPL #ifdef is not used at all. This patch changes it's define to the currently used value of 133333333 and removes the unnecessary code. Signed-off-by: Stefan Roese <sr@denx.de>
2009-04-16ppc4xx: Fixup chip-selects in dtb for NAND-booting SequoiaStefan Roese
Currently the NOR & NAND support in Linux only works for the "standard" Sequoia, the version booting for NOR flash. The NAND-booting version has the chip-selects swapped. Here the chip-select mappings: "Standard" NOR-booting version: CS0 NOR CS3 NAND NAND-booting version: CS0 NAND CS3 NOR With this path the dtb gets fixed-up, so that the correct chip-select numbers are patched in the dtb enabling correct NOR & NAND support in Linux on the NAND-booting Sequoia version. Signed-off-by: Stefan Roese <sr@denx.de>
2009-03-26ppc4xx: Sequoia: Fix TLB reassignment in NAND booting codeStefan Roese
This patch fixes a bug in the Sequoia TLB init code to reconfigure the correct TLB (boot space) after running from RAM. This bug was introduced with patch 4d332dbeb08f5863d1ea69d91a00c5499d3a87ed [ppc4xx: Make Sequoia boot vxWorks] which changed the order of the TLB in the Sequoia init.S file. Signed-off-by: Stefan Roese <sr@denx.de>
2009-03-17Fix AMCC Sequoia board DDR memory configurationMikhail Zolotaryov
Sequoia board schematics (DES0211_11_SCH_11.pdf, page 5, unit U1D) specifies that BankSel#1 is not connected, while bootloader memory configuration is (board/amcc/sequoia/sdram.c): mtsdram(DDR0_10, 0x00000300); i.e. both Chip Selects used - not correct. If we change to correct value here: mtsdram(DDR0_10, 0x00000100); memory is accessible OK also. Signed-off-by: Mikhail Zolotaryov <lebon@lebon.org.ua> Signed-off-by: Stefan Roese <sr@denx.de>
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-01-28Standardize command usage messages with cmd_usage()Peter Tyser
2008-08-12Merge branch 'master' of /home/stefan/git/u-boot/u-boot into nextStefan Roese
2008-08-07ppc4xx: Sequoia has two UARTs in "4-pin" mode. Configure the GPIOs as per ↵Steven A. Falco
schematic. The Sequoia board has two UARTs in "4-pin" mode. This patch modifies the GPIO configuration to match the schematic, and also sets the SDR0_PFC1 register to select the corresponding mode for the UARTs. Signed-off-by: Steven A. Falco <sfalco@harris.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-07-13ppc4xx: Remove redundant ft_board_setup() functions from some 4xx boardsStefan Roese
This patch removes some ft_board_setup() functions from some 4xx boards. This can be done since we now have a default weak implementation for this in cpu/ppc4xx/fdt.c. Only board in need for a different/custom implementation like canyonlands need their own version. Signed-off-by: Stefan Roese <sr@denx.de>
2008-07-11ppc4xx: Consolidate PPC4xx UIC definesStefan Roese
This 2nd patch now removes all UIC mask bit definition. They should be generated from the vectors by using the UIC_MASK() macro from now on. This way only the vectors need to get defined for new PPC's. Also only the really used interrupt vectors are now defined. This makes definitions for new PPC versions easier and less error prone. Another part of this patch is that the 4xx emac driver got a little cleanup, since now the usage of the interrupts is clearer. Signed-off-by: Stefan Roese <sr@denx.de>
This patch is the first step to consolidate the UIC related defines in the 4xx headers. Move header from asm-ppc/ppc4xx-intvec.h to asm-ppc/ppc4xx-uic.h as it will hold all UIC related defines in the next steps. Signed-off-by: Stefan Roese <sr@denx.de>
2008-07-11ppc4xx: Remove redundant ft_board_setup() functions from some 4xx boardsStefan Roese
