This patch removes the used testdram() implementations of the board
that are maintained by myself.
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
The cross compiler is responsible for providing the correct libraries
and the logic to find the linking libraries.
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
With recent toolchain versions, some boards would not build because
or errors like this one (here for ocotea board when building with
ELDK 4.2 beta):
ppc_4xx-ld: section .bootpg [fffff000 -> fffff23b] overlaps section .bss [fffee900 -> fffff8ab]
For many boards, the .bss section is big enough that it wraps around
at the end of the address space (0xFFFFFFFF), so the problem will not
be visible unless you use a 64 bit tool chain for development. On
some boards however, changes to the code size (due to different
optimizations) we bail out with section overlaps like above.
The fix is to add the NOLOAD attribute to the .bss and .sbss
sections, telling the linker that .bss does not consume any space in
the image.
Change all linker scripts to reference the changed driver name 4xx_uart.o.
Note: In most cased all these explicit referencing of these object files
in the linker scripts is not neccessary. Only for manually embedded
environment into the U-Boot image, which is not done is most cases.
This patch removes the CFG_PCI_PRE_INIT option completely, since
it's not needed anymore with the patch from Matthias Fuchs with
the "weak" pci_pre_init() implementation.
Define CONFIG_PROG_SDRAM_TLB so that the TLB entries for the
DDR memory are dynamically programmed matching the total size
of the equipped memory (DIMM modules).
Patch by Stefan Roese, 30 Sep 2006
Modifications are based on the linux kernel approach and
support two use cases:
1) Add O= to the make command line
'make O=/tmp/build all'
2) Set environement variable BUILD_DIR to point to the desired location
'export BUILD_DIR=/tmp/build'
'make'
The second approach can also be used with a MAKEALL script
'./MAKEALL'
Command line 'O=' setting overrides BUILD_DIR environent variable.
When none of the above methods is used the local build is performed and
the object files are placed in the source directory.
On PPC44x platforms, the startup message generated in "cpu.c" only
comprised the ppc type and revision but not additional informations
like speed etc. Those speed infos where printed in the board specific
code. This new implementation now prints all CPU infos in the common
cpu specific code. No board specific code is needed anymore and
therefore removed from all current 44x implementations.
Patch by Stefan Roese, 27 Nov 2005
Patch by Stefan Roese, 01 Nov 2005
Pointed out by Gerhard Jaeger, 31 Aug 2005;
cf. http://sourceware.org/ml/binutils/2005-08/msg00412.html
now handling all 4xx cpu's.
Patch by Stefan Roese, 16 Aug 2005
Patch by Stefan Roese, 01 Aug 2005
