path: root/board/amcc/luan/u-boot.lds
2007-03-08[PATCH] Update AMCC Luan 440SP eval board supportStefan Roese
The AMCC Luan now uses the common 440SP(e) DDR SPD code for DDR inititializition. This includes DDR auto calibration and support for different DIMM modules, instead of the fixed setup used in the earlier version. This patch also enables the cache in FLASH for the startup phase of U-Boot (while running from FLASH). After relocating to SDRAM the cache is disabled again. This will speed up the boot process, especially the SDRAM setup, since there are some loops for memory testing (auto calibration). Signed-off-by: Stefan Roese <sr@denx.de>
2005-11-29Add support for AMCC 440SP, add support for AMCC Luan 440SP eval board.Stefan Roese
Patch by John Otken, 23 Nov 2005
