path: root/board/amcc/luan/luan.c
2011-05-12Fix incorrect use of getenv() before relocationWolfgang Denk
A large number of boards incorrectly used getenv() in their board init code running before relocation. In some cases this caused U-Boot to hang when certain environment variables grew too long. Fix the code to use getenv_r(). Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: The LEOX team <team@leox.org> Cc: Michael Schwingen <michael@schwingen.org> Cc: Georg Schardt <schardt@team-ctech.de> Cc: Werner Pfister <Pfister_Werner@intercontrol.de> Cc: Dirk Eibach <eibach@gdsys.de> Cc: Peter De Schrijver <p2@mind.be> Cc: John Zhan <zhanz@sinovee.com> Cc: Rishi Bhattacharya <rishi@ti.com> Cc: Peter Tyser <ptyser@xes-inc.com>
2010-09-23ppc4xx: Move ppc4xx headers to powerpc include directoryStefan Roese
This patch moves some ppc4xx related headers from the common include directory (include/) to the powerpc specific one (arch/powerpc/include/asm/). This way to common include directory is not so cluttered with files. Signed-off-by: Stefan Roese <sr@denx.de>
2010-07-24cmd_usage(): simplify return code handlingWolfgang Denk
Lots of code use this construct: cmd_usage(cmdtp); return 1; Change cmd_usage() let it return 1 - then we can replace all these ocurrances by return cmd_usage(cmdtp); This fixes a few places with incorrect return code handling, too. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2009-11-19ppc4xx: Consolidate pci_pre_init() functionStefan Roese
This patch removes the duplicted implementations of the pci_pre_init() function by introducing a weak default function for it. This weak default has a different implementation for some PPC variants. It can be overridden by a board specific version. Signed-off-by: Stefan Roese <sr@denx.de>
2009-11-19ppc4xx: Consolidate pci_target_init() functionStefan Roese
This patch removes the duplicted implementations of the pci_target_init() function by introducing a weak default function for it. This weak default has a different implementation for 440EP(x)/GR(x) PPC's. It can be overridden by a board specific version (e.g. PMC440, korat). Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu>
2009-11-09ppc4xx: Remove duplicated is_pci_host() functionsStefan Roese
This patch introduces a weak default function for is_pci_host(), returning 1. This is the default behaviour, since most boards only implement PCI host functionality. This weak default can be overridden by a board specific version if needed. Signed-off-by: Stefan Roese <sr@denx.de>
2009-10-07ppc_4xx: Apply new HW register namesNiklaus Giger
Modify all existing *.c files to use the new register names as seen in the AMCC manuals. Signed-off-by: Niklaus Giger <niklaus.giger@member.fsf.org> Signed-off-by: Stefan Roese <sr@denx.de>
2009-09-28ppc4xx: Convert PPC4xx UIC defines from lower case to upper caseStefan Roese
The latest PPC4xx register cleanup patch missed the UIC defines. This patch now changes lower case UIC defines to upper case. Signed-off-by: Stefan Roese <sr@denx.de>
2009-09-11ppc4xx: Big cleanup of PPC4xx definesStefan Roese
This patch cleans up multiple issues of the 4xx register (mostly DCR, SDR, CPR, etc) definitions: - Change lower case defines to upper case (plb4_acr -> PLB4_ACR) - Change the defines to better match the names from the user's manuals (e.g. cprpllc -> CPR0_PLLC) - Removal of some unused defines Please test this patch intensive on your PPC4xx platform. Even though I tried not to break anything and tested successfully on multiple 4xx AMCC platforms, testing on custom platforms is recommended. Signed-off-by: Stefan Roese <sr@denx.de>
2009-06-12General help message cleanupWolfgang Denk
Many of the help messages were not really helpful; for example, many commands that take no arguments would not print a correct synopsis line, but "No additional help available." which is not exactly wrong, but not helpful either. Commit ``Make "usage" messages more helpful.'' changed this partially. But it also became clear that lots of "Usage" and "Help" messages (fields "usage" and "help" in struct cmd_tbl_s respective) were actually redundant. This patch cleans this up - for example: Before: => help dtt dtt - Digital Thermometer and Thermostat Usage: dtt - Read temperature from digital thermometer and thermostat. After: => help dtt dtt - Read temperature from Digital Thermometer and Thermostat Usage: dtt Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-01-28Standardize command usage messages with cmd_usage()Peter Tyser
2008-11-21ppc4xx: Added ppc4xx-isram.h for internal SRAM and L2 cache DCRsDave Mitchell
Added include/asm-ppc/ppc4xx-isram.h and moved internal SRAM and L2 cache DCRs from ppc440.h to this new header. Also converted these DCR defines from lowercase to uppercase and modified referencing modules to use them. Signed-off-by: Dave Mitchell <dmitch71@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-06-03ppc4xx: Remove implementations of testdram()Stefan Roese
This patch removes the used testdram() implementations of the board that are maintained by myself. Signed-off-by: Stefan Roese <sr@denx.de>
2007-12-06ppc4xx: Enable hardware-fix for PCI/DMA errata on AMCC 440SP/SPe boardsStefan Roese
This patch enables the hardware-fix for the PCI/DMA errata's 19+22 by setting the FIXD bit in the SDR0_MFR register. Here a description of the symptoms: Problem Description ------------------------------ If a DMA is performed between memory and PCI with the DMA 1 Controller using prefetch, and as a result uses a special purpose buffer selected by the PCIXn Bridge Options 1 Register (PCIXn_BRDGOPT1[RBP7] - bits 31-29), the first part of the transfer sequence is performed twice. The PPC440SPe PCI Controller requests more data than was needed such that in the case of enforce memory protection, a host CPU exception can occur. No data is corrupted, because data transfer is stopped in the PCI Controller. Prefetch enable is specified by setting DMA Configuration Register (I2O0_DMAx_CFG[DXEPD] - bit 31) to 0. Behavior that may be observed in a running system --------------------------------------------------------------------------- 1. DMA performance is decreased because of the double access on the PCI bus interface. 2. If an illegal access to some address on the PCI bus is detected at the system level, a machine check or similar system error may occur. Workarounds Available ---------------------------------- 1. Do not program prefetch. Note that a prefetch command cannot be programmed without selecting a special purpose buffer. 2. To avoid crossing a physical boundary of the PCI slave device, add 512 bytes of address to the PCI address range. This patch was originally provided by Pravin M. Bathija <pbathija@amcc.com> from AMCC and slighly changed. Signed-off-by: Pravin M. Bathija <pbathija@amcc.com> Signed-off-by: Stefan Roese <sr@denx.de>
2007-10-02ppc4xx: Coding style cleanupStefan Roese
2007-10-02Program EPLD to force full duplex mode for PHY.Grzegorz Bernacki
EPLD forces modes of PHY operation. By default full duplex is turned off. This fix turns it on. Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com>
2007-07-16ppc4xx: AMCC Luan uses the new boardspecific DDR2 controller setupStefan Roese
2007-06-25ppc4xx: Add pci_pre_init() for 405 boardsStefan Roese
This patch removes the CFG_PCI_PRE_INIT option completely, since it's not needed anymore with the patch from Matthias Fuchs with the "weak" pci_pre_init() implementation. Signed-off-by: Stefan Roese <sr@denx.de>
2007-03-08[PATCH] Update AMCC Luan 440SP eval board supportStefan Roese
The AMCC Luan now uses the common 440SP(e) DDR SPD code for DDR inititializition. This includes DDR auto calibration and support for different DIMM modules, instead of the fixed setup used in the earlier version. This patch also enables the cache in FLASH for the startup phase of U-Boot (while running from FLASH). After relocating to SDRAM the cache is disabled again. This will speed up the boot process, especially the SDRAM setup, since there are some loops for memory testing (auto calibration). Signed-off-by: Stefan Roese <sr@denx.de>
2005-11-29Add support for AMCC 440SP, add support for AMCC Luan 440SP eval board.Stefan Roese
Patch by John Otken, 23 Nov 2005
