path: root/board/amcc/luan/init.S
2010-09-23ppc4xx: Use common NS16550 driver for PPC4xx UARTStefan Roese
This patch removes the PPC4xx UART driver. Instead the common NS16550 driver is used, since all PPC4xx SoC's use this peripheral device. The file 4xx_uart.c now only implements the UART clock calculation function which also sets the SoC internal UART divisors. All PPC4xx board config headers are changed to use this common NS16550 driver now. Tested on these boards: acadia, canyonlands, katmai, kilauea, sequoia, zeus Signed-off-by: Stefan Roese <sr@denx.de>
2010-04-19ppc4xx: TLB init file cleanupStefan Roese
This patch adds new macros, with frequently used combinations of the 4xx TLB access control and storage attibutes. Additionally the 4xx init.S files are updated to make use of these new macros. Resulting in easier to read TLB definitions. Additionally some init.S files are updated to use the mmu header for the TLB defines, instead of defining their own macros. Signed-off-by: Stefan Roese <sr@denx.de>
2010-04-13Replace "#include <asm-$ARCH/$FILE>" with "#include <asm/$FILE>"Peter Tyser
The appropriate include/asm-$ARCH directory should already by symlinked to include/asm so using the whole "asm-$ARCH" path is unnecessary. This change should also allow us to move the include/asm-$ARCH directories into their appropriate lib/$ARCH/ directories. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2007-03-08[PATCH] Update AMCC Luan 440SP eval board supportStefan Roese
The AMCC Luan now uses the common 440SP(e) DDR SPD code for DDR inititializition. This includes DDR auto calibration and support for different DIMM modules, instead of the fixed setup used in the earlier version. This patch also enables the cache in FLASH for the startup phase of U-Boot (while running from FLASH). After relocating to SDRAM the cache is disabled again. This will speed up the boot process, especially the SDRAM setup, since there are some loops for memory testing (auto calibration). Signed-off-by: Stefan Roese <sr@denx.de>
2005-11-29Add support for AMCC 440SP, add support for AMCC Luan 440SP eval board.Stefan Roese
Patch by John Otken, 23 Nov 2005
