path: root/board/amcc/kilauea
2011-05-12Fix incorrect use of getenv() before relocationWolfgang Denk
A large number of boards incorrectly used getenv() in their board init code running before relocation. In some cases this caused U-Boot to hang when certain environment variables grew too long. Fix the code to use getenv_r(). Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: The LEOX team <team@leox.org> Cc: Michael Schwingen <michael@schwingen.org> Cc: Georg Schardt <schardt@team-ctech.de> Cc: Werner Pfister <Pfister_Werner@intercontrol.de> Cc: Dirk Eibach <eibach@gdsys.de> Cc: Peter De Schrijver <p2@mind.be> Cc: John Zhan <zhanz@sinovee.com> Cc: Rishi Bhattacharya <rishi@ti.com> Cc: Peter Tyser <ptyser@xes-inc.com>
2011-04-30Handle most LDSCRIPT setting centrallyScott Wood
Currently, some linker scripts are found by common code in config.mk. Some are found using CONFIG_SYS_LDSCRIPT, but the code for that is sometimes in arch config.mk and sometimes in board config.mk. Some are found using an arch-specific rule for looking in CPUDIR, etc. Further, the powerpc config.mk rule relied on CONFIG_NAND_SPL when it really wanted CONFIG_NAND_U_BOOT -- which covered up the fact that not all NAND_U_BOOT builds actually wanted CPUDIR/u-boot-nand.lds. Replace all of this -- except for a handful of boards that are actually selecting a linker script in a unique way -- with centralized ldscript finding. If board code specifies LDSCRIPT, that will be used. Otherwise, if CONFIG_SYS_LDSCRIPT is specified, that will be used. If neither of these are specified, then the central config.mk will check for the existence of the following, in order: $(TOPDIR)/board/$(BOARDDIR)/u-boot-nand.lds (only if CONFIG_NAND_U_BOOT) $(TOPDIR)/$(CPUDIR)/u-boot-nand.lds (only if CONFIG_NAND_U_BOOT) $(TOPDIR)/board/$(BOARDDIR)/u-boot.lds $(TOPDIR)/$(CPUDIR)/u-boot.lds Some boards (sc3, cm5200, munices) provided their own u-boot.lds that were dead code, because they were overridden by a CPUDIR u-boot.lds under the old powerpc rules. These boards' own u-boot.lds have bitrotted and no longer work -- these lds files have been removed. Signed-off-by: Scott Wood <scottwood@freescale.com> Tested-by: Graeme Russ <graeme.russ@gmail.com>
2011-03-27rename _end to __bss_end__Po-Yu Chuang
Currently, _end is used for end of BSS section. We want _end to mean end of u-boot image, so we rename _end to __bss_end__ first. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2010-12-15ppc4xx: Fix missing linker scripts for partial linkingStefan Roese
This patch fixes the acadia_nand and kilauea_nand linker scripts which have been missing in commit ee8028b7 [ppc4xx: Cleanup for partial linking and --gc-sections] Signed-off-by: Stefan Roese <sr@denx.de> Cc: Bernhard Weirich <Bernhard.Weirich@riedel.net>
2010-09-23ppc4xx: Move ppc4xx headers to powerpc include directoryStefan Roese
This patch moves some ppc4xx related headers from the common include directory (include/) to the powerpc specific one (arch/powerpc/include/asm/). This way to common include directory is not so cluttered with files. Signed-off-by: Stefan Roese <sr@denx.de>
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2010-01-23ppc4xx: Kilauea: Add CPLD version detection and EBC reconfigurationStefan Roese
A newer CPLD version on the 405EX evaluation board requires a different EBC controller setup for the CPLD register access. This patch adds a CPLD version detection for Kilauea and code to reconfigure the EBC controller (chip select 2) for the old CPLD if no new version is found. Additionally the CPLD version is printed upon bootup: Board: Kilauea - AMCC PPC405EX Evaluation Board (CPLD rev. 0) Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Wolfgang Denk <wd@denx.de> Cc: Zhang Bao Quan <bqzhang@udtech.com.cn>
2009-12-07POST: Remove duplicated post_hotkey_pressed() functionsStefan Roese
This patch introduces a weak default function for post_hotkey_pressed(), returning 0, for boards without hotkey support. The long-running tests won't be started on those boards. This default function was implemented in many board directories. By implementing this weak default we can remove all those duplicate versions. Boards with hotkey support, can override this weak default function by defining one in their board specific code. Signed-off-by: Stefan Roese <sr@denx.de>
2009-11-19ppc4xx: Consolidate pci_pre_init() functionStefan Roese
This patch removes the duplicted implementations of the pci_pre_init() function by introducing a weak default function for it. This weak default has a different implementation for some PPC variants. It can be overridden by a board specific version. Signed-off-by: Stefan Roese <sr@denx.de>
2009-11-09ppc4xx: Fix NAND booting targets after 4xx linker script consolidationStefan Roese
Somehow I missed the NAND booting targets in the 4xx linker script consolidation patchset. This patch fixes this issue. Signed-off-by: Stefan Roese <sr@denx.de>
2009-11-09ppc4xx: Consolidate 4xx PCIe board specific configurationStefan Roese
This patch consolidates the PPC4xx board specific PCIe configuration code. This way the duplicated code is removed. Boards can implement a special, non standard behaviour (e.g. number of PCIe slots, etc) by overriding the weak default functions. Signed-off-by: Stefan Roese <sr@denx.de>
2009-11-02ppc4xx: Remove board specific linker scripts from most PPC4xx boardsStefan Roese
All these linker scripts can be removed since the new common ppc4xx linker script should be able to handle all of those boards. Please test and report problems. Thanks. Signed-off-by: Stefan Roese <sr@denx.de>
2009-10-09Merge branch 'reloc'Wolfgang Denk
2009-10-07ppc4xx: Fix msg "initialization as root-complex failed" upon PCIe scanStefan Roese
This message is printed upon PCIe bus scan, not only upon error, but also if no PCIe device is detected at all. Since this is not an error, let's remove this message in this case. We already have the message "link is not up." if there is no PCIe device present. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Wolfgang Denk <wd@denx.de>
2009-10-03ppc: Enable full relocation to RAMPeter Tyser
The following changes allow U-Boot to fully relocate from flash to RAM: - Remove linker scripts' .fixup sections from the .text section - Add -mrelocatable to PLATFORM_RELFLAGS for all boards - Define CONFIG_RELOC_FIXUP_WORKS for all boards Previously, U-Boot would partially relocate, but statically initialized pointers needed to be manually relocated. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-09-28ppc4xx: Convert PPC4xx UIC defines from lower case to upper caseStefan Roese
The latest PPC4xx register cleanup patch missed the UIC defines. This patch now changes lower case UIC defines to upper case. Signed-off-by: Stefan Roese <sr@denx.de>
2009-07-28ppc4xx: Add some NAND-booting bootstrap entries to Kilauea chip_config cmdStefan Roese
This patch adds some I2C bootstrap setting for NAND booting to the Kilauea chip_config command ("533-nand" and "600-nand"). Additionally some incorrectly indented lines are fixed. Signed-off-by: Stefan Roese <sr@denx.de>
2009-07-24ppc4xx: Add chip_config command to AMCC Kilauea eval boardStefan Roese
This patch removes the "alterpll" command and replaces it with the now ppc4xx standard "chip_config" command to configure the I2C bootstrap EEPROM. Signed-off-by: Stefan Roese <sr@denx.de>
2009-06-12General help message cleanupWolfgang Denk
Many of the help messages were not really helpful; for example, many commands that take no arguments would not print a correct synopsis line, but "No additional help available." which is not exactly wrong, but not helpful either. Commit ``Make "usage" messages more helpful.'' changed this partially. But it also became clear that lots of "Usage" and "Help" messages (fields "usage" and "help" in struct cmd_tbl_s respective) were actually redundant. This patch cleans this up - for example: Before: => help dtt dtt - Digital Thermometer and Thermostat Usage: dtt - Read temperature from digital thermometer and thermostat. After: => help dtt dtt - Read temperature from Digital Thermometer and Thermostat Usage: dtt Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-01-28Standardize command usage messages with cmd_usage()Peter Tyser
2008-09-22Revert "ppc4xx: Fix DDR2 auto calibration on Kilauea 600MHz (200MHz PLB)"Stefan Roese
This reverts commit 3eec160a3a405b29ce9c06920f6427b9047dd8a8. Signed-off-by: Stefan Roese <sr@denx.de>
2008-09-16ppc4xx: Fix DDR2 auto calibration on Kilauea 600MHz (200MHz PLB)Victor Gallardo
Signed-off-by: Victor Gallardo <vgallardo@amcc.com> Signed-off-by: Adam Graham <agraham@amcc.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-07-11ppc4xx: Remove redundant ft_board_setup() functions from some 4xx boardsStefan Roese
This patch removes some ft_board_setup() functions from some 4xx boards. This can be done since we now have a default weak implementation for this in cpu/ppc4xx/fdt.c. Only board in need for a different/custom implementation like canyonlands need their own version. Signed-off-by: Stefan Roese <sr@denx.de>
2008-07-02Cleanup: remove redundant deleting on *~ filesWolfgang Denk
2008-06-03ppc4xx: Change Kilauea to use the common DDR2 init functionStefan Roese
This patch changes the kilauea and kilauea_nand (for NAND booting) board port to not use a board specific DDR2 init routine anymore. Now the common code from cpu/ppc4xx is used. Thanks to Grant Erickson for all his basic work on this 405EX early bootup. Signed-off-by: Stefan Roese <sr@denx.de>
2008-06-03ppc4xx: Enable Primordial Stack for 40x and Unify ECC HandlingGrant Erickson
This patch (Part 2 of 2): * Rolls up a suite of changes to enable correct primordial stack and global data handling when the data cache is used for such a purpose for PPC40x-variants (i.e. CFG_INIT_DCACHE_CS). * Related to the first, unifies DDR2 SDRAM and ECC initialization by eliminating redundant ECC initialization implementations and moving redundant SDRAM initialization out of board code into shared 4xx code. * Enables MCSR visibility on the 405EX(r). * Enables the use of the data cache for initial RAM on both AMCC's Kilauea and Makalu and removes a redundant CFG_POST_MEMORY flag from each board's CONFIG_POST value. - Removed, per Stefan Roese's request, defunct memory.c file for Makalu and rolled sdram_init from it into makalu.c. With respect to the 4xx DDR initialization and ECC unification, there is certainly more work that can and should be done (file renaming, etc.). However, that can be handled at a later date on a second or third pass. As it stands, this patch moves things forward in an incremental yet positive way for those platforms that utilize this code and the features associated with it. Signed-off-by: Grant Erickson <gerickson@nuovations.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-05-13ppc4xx: Add 405EX(r) revision C PVR definitions and detection codeStefan Roese
2008-03-15ppc4xx: Fix comment in 405EX DDR2 init codeStefan Roese
2008-01-17ppc4xx: Fix remaining CONFIG_COMMANDS in 4xx filesStefan Roese
2008-01-14ppc4xx: Update Kilauea CPLD configuration with USB PHY reset bitStefan Roese
Now that bit 29 is the USB PHY reset bit, update the Kilauea port to remove the USB PHY reset after powerup. The CPLD will keep the USB PHY in reset (active low) until the bit is set to 1 in board_early_init_f(). Signed-off-by: Stefan Roese <sr@denx.de>
2007-12-13ppc4xx: Bring 4xx fdt support up-to-dateStefan Roese
This patch update the 4xx fdt support. It enabled fdt booting on the AMCC Kilauea and Sequoia for now. More can follow later quite easily. Signed-off-by: Stefan Roese <sr@denx.de>
2007-12-08ppc4xx: 405EX: Correctly enable USB pinsStefan Roese
This patch selects the USB data pins in the 405EX GPIO and MFC (multi function control) registers. This is done for the AMCC Kilauea and Makalu eval boards. Signed-off-by: Stefan Roese <sr@denx.de>
2007-11-30ppc4xx: Kilauea: Add PCIe reset assertion upon power-upStefan Roese
This manual PCIe reset triggering solves the problem seen with the Intel EPRO/1000 card, which was not detected (link not established) upon power-up reset. Signed-off-by: Stefan Roese <sr@denx.de>
2007-11-15ppc4xx: Small AMCC Kilauea cleanupStefan Roese
Remove not needed pci_target_init() function. Signed-off-by: Stefan Roese <sr@denx.de>
2007-11-05ppc4xx: Make output a little shorter on PCIe detectionStefan Roese
Now not max 3 lines but 2 lines are printed per PCIe port. Signed-off-by: Stefan Roese <sr@denx.de>
