path: root/board/amcc/kilauea
2007-11-03ppc4xx: Add AMCC Kilauea/Haleakala NAND booting supportStefan Roese
This patch adds NAND booting support for the AMCC 405EX(r) eval boards. Again, only one image supports both targets. Signed-off-by: Stefan Roese <sr@denx.de>
2007-10-31ppc4xx: Add initial AMCC Haleakala PPC405EXr eval board supportStefan Roese
The Haleakala is nearly identical with the Kilauea eval board. The only difference is that the 405EXr only supports one EMAC and one PCIe interface. This patch adds support for the Haleakala board by using the identical image for Kilauea and Haleakala. The distinction is done by comparing the PVR. Signed-off-by: Stefan Roese <sr@denx.de>
2007-10-31ppc4xx: Fix size setup in Kilauea DDR2 init routineStefan Roese
The size was initilized wrong. Instead of 256MB, the DDR2 controller was setup to 512MB. Now the correct values is used. This patch also does a little cleanup and adds a comment here. Signed-off-by: Stefan Roese <sr@denx.de>
2007-10-31ppc4xx: Dynamic configuration of 4xx PCIe mode as root or endpoint modeStefan Roese
This patch adds support for dynamic configuration of PCIe ports for the AMCC PPC4xx boards equipped with PCIe interfaces. These are the PPC440SPe boards Yucca & Katmai and the 405EX board Kilauea. This dynamic configuration is done via the "pcie_mode" environement variable. This variable can be set to "EP" or "RP" for endpoint or rootpoint mode. Multiple values can be joined via the ":" delimiter. Here an example: pcie_mode=RP:EP:EP This way, PCIe port 0 will be configured as rootpoint, PCIe port 1 and 2 as endpoint. Per default Yucca will be configured as: pcie_mode=RP:EP:EP Per default Katmai will be configured as: pcie_mode=RP:RP:REP Per default Kilauea will be configured as: pcie_mode=RP:RP Signed-off-by: Tirumala R Marri <tmarri@amcc.com> Signed-off-by: Stefan Roese <sr@denx.de>
2007-10-31ppc4xx: Enable device tree support (fdt) on Kilauea per defaultStefan Roese
This patch enables the fdt support on the AMCC Kilauea eval board. Additionally now EBC ranges fdt fixup is included to support NOR FLASH mapping via the Linux physmap_of driver. This Kilauea port now support booting arch/ppc and arch/powerpc Linux kernels. The default environment "net_nfs" is for arch/ppc and "net_nfs_fdt" is for arch/powerpc. In the long run, arch/ppc support will be removed. Signed-off-by: Stefan Roese <sr@denx.de>
2007-10-31ppc4xx: Add initial AMCC Kilauea 405EX supportStefan Roese
