path: root/board/amcc/kilauea/kilauea.c
2011-05-12Fix incorrect use of getenv() before relocationWolfgang Denk
A large number of boards incorrectly used getenv() in their board init code running before relocation. In some cases this caused U-Boot to hang when certain environment variables grew too long. Fix the code to use getenv_r(). Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: The LEOX team <team@leox.org> Cc: Michael Schwingen <michael@schwingen.org> Cc: Georg Schardt <schardt@team-ctech.de> Cc: Werner Pfister <Pfister_Werner@intercontrol.de> Cc: Dirk Eibach <eibach@gdsys.de> Cc: Peter De Schrijver <p2@mind.be> Cc: John Zhan <zhanz@sinovee.com> Cc: Rishi Bhattacharya <rishi@ti.com> Cc: Peter Tyser <ptyser@xes-inc.com>
2010-09-23ppc4xx: Move ppc4xx headers to powerpc include directoryStefan Roese
This patch moves some ppc4xx related headers from the common include directory (include/) to the powerpc specific one (arch/powerpc/include/asm/). This way to common include directory is not so cluttered with files. Signed-off-by: Stefan Roese <sr@denx.de>
2010-01-23ppc4xx: Kilauea: Add CPLD version detection and EBC reconfigurationStefan Roese
A newer CPLD version on the 405EX evaluation board requires a different EBC controller setup for the CPLD register access. This patch adds a CPLD version detection for Kilauea and code to reconfigure the EBC controller (chip select 2) for the old CPLD if no new version is found. Additionally the CPLD version is printed upon bootup: Board: Kilauea - AMCC PPC405EX Evaluation Board (CPLD rev. 0) Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Wolfgang Denk <wd@denx.de> Cc: Zhang Bao Quan <bqzhang@udtech.com.cn>
2009-12-07POST: Remove duplicated post_hotkey_pressed() functionsStefan Roese
This patch introduces a weak default function for post_hotkey_pressed(), returning 0, for boards without hotkey support. The long-running tests won't be started on those boards. This default function was implemented in many board directories. By implementing this weak default we can remove all those duplicate versions. Boards with hotkey support, can override this weak default function by defining one in their board specific code. Signed-off-by: Stefan Roese <sr@denx.de>
2009-11-19ppc4xx: Consolidate pci_pre_init() functionStefan Roese
This patch removes the duplicted implementations of the pci_pre_init() function by introducing a weak default function for it. This weak default has a different implementation for some PPC variants. It can be overridden by a board specific version. Signed-off-by: Stefan Roese <sr@denx.de>
2009-11-09ppc4xx: Consolidate 4xx PCIe board specific configurationStefan Roese
This patch consolidates the PPC4xx board specific PCIe configuration code. This way the duplicated code is removed. Boards can implement a special, non standard behaviour (e.g. number of PCIe slots, etc) by overriding the weak default functions. Signed-off-by: Stefan Roese <sr@denx.de>
2009-10-07ppc4xx: Fix msg "initialization as root-complex failed" upon PCIe scanStefan Roese
This message is printed upon PCIe bus scan, not only upon error, but also if no PCIe device is detected at all. Since this is not an error, let's remove this message in this case. We already have the message "link is not up." if there is no PCIe device present. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Wolfgang Denk <wd@denx.de>
2009-09-28ppc4xx: Convert PPC4xx UIC defines from lower case to upper caseStefan Roese
The latest PPC4xx register cleanup patch missed the UIC defines. This patch now changes lower case UIC defines to upper case. Signed-off-by: Stefan Roese <sr@denx.de>
2008-09-22Revert "ppc4xx: Fix DDR2 auto calibration on Kilauea 600MHz (200MHz PLB)"Stefan Roese
This reverts commit 3eec160a3a405b29ce9c06920f6427b9047dd8a8. Signed-off-by: Stefan Roese <sr@denx.de>
2008-09-16ppc4xx: Fix DDR2 auto calibration on Kilauea 600MHz (200MHz PLB)Victor Gallardo
Signed-off-by: Victor Gallardo <vgallardo@amcc.com> Signed-off-by: Adam Graham <agraham@amcc.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-07-11ppc4xx: Remove redundant ft_board_setup() functions from some 4xx boardsStefan Roese
This patch removes some ft_board_setup() functions from some 4xx boards. This can be done since we now have a default weak implementation for this in cpu/ppc4xx/fdt.c. Only board in need for a different/custom implementation like canyonlands need their own version. Signed-off-by: Stefan Roese <sr@denx.de>
2008-05-13ppc4xx: Add 405EX(r) revision C PVR definitions and detection codeStefan Roese
2008-01-14ppc4xx: Update Kilauea CPLD configuration with USB PHY reset bitStefan Roese
Now that bit 29 is the USB PHY reset bit, update the Kilauea port to remove the USB PHY reset after powerup. The CPLD will keep the USB PHY in reset (active low) until the bit is set to 1 in board_early_init_f(). Signed-off-by: Stefan Roese <sr@denx.de>
2007-12-13ppc4xx: Bring 4xx fdt support up-to-dateStefan Roese
This patch update the 4xx fdt support. It enabled fdt booting on the AMCC Kilauea and Sequoia for now. More can follow later quite easily. Signed-off-by: Stefan Roese <sr@denx.de>
2007-12-08ppc4xx: 405EX: Correctly enable USB pinsStefan Roese
This patch selects the USB data pins in the 405EX GPIO and MFC (multi function control) registers. This is done for the AMCC Kilauea and Makalu eval boards. Signed-off-by: Stefan Roese <sr@denx.de>
2007-11-30ppc4xx: Kilauea: Add PCIe reset assertion upon power-upStefan Roese
This manual PCIe reset triggering solves the problem seen with the Intel EPRO/1000 card, which was not detected (link not established) upon power-up reset. Signed-off-by: Stefan Roese <sr@denx.de>
2007-11-15ppc4xx: Small AMCC Kilauea cleanupStefan Roese
Remove not needed pci_target_init() function. Signed-off-by: Stefan Roese <sr@denx.de>
2007-11-05ppc4xx: Make output a little shorter on PCIe detectionStefan Roese
Now not max 3 lines but 2 lines are printed per PCIe port. Signed-off-by: Stefan Roese <sr@denx.de>
2007-10-31ppc4xx: Add initial AMCC Haleakala PPC405EXr eval board supportStefan Roese
The Haleakala is nearly identical with the Kilauea eval board. The only difference is that the 405EXr only supports one EMAC and one PCIe interface. This patch adds support for the Haleakala board by using the identical image for Kilauea and Haleakala. The distinction is done by comparing the PVR. Signed-off-by: Stefan Roese <sr@denx.de>
2007-10-31ppc4xx: Dynamic configuration of 4xx PCIe mode as root or endpoint modeStefan Roese
This patch adds support for dynamic configuration of PCIe ports for the AMCC PPC4xx boards equipped with PCIe interfaces. These are the PPC440SPe boards Yucca & Katmai and the 405EX board Kilauea. This dynamic configuration is done via the "pcie_mode" environement variable. This variable can be set to "EP" or "RP" for endpoint or rootpoint mode. Multiple values can be joined via the ":" delimiter. Here an example: pcie_mode=RP:EP:EP This way, PCIe port 0 will be configured as rootpoint, PCIe port 1 and 2 as endpoint. Per default Yucca will be configured as: pcie_mode=RP:EP:EP Per default Katmai will be configured as: pcie_mode=RP:RP:REP Per default Kilauea will be configured as: pcie_mode=RP:RP Signed-off-by: Tirumala R Marri <tmarri@amcc.com> Signed-off-by: Stefan Roese <sr@denx.de>
2007-10-31ppc4xx: Enable device tree support (fdt) on Kilauea per defaultStefan Roese
This patch enables the fdt support on the AMCC Kilauea eval board. Additionally now EBC ranges fdt fixup is included to support NOR FLASH mapping via the Linux physmap_of driver. This Kilauea port now support booting arch/ppc and arch/powerpc Linux kernels. The default environment "net_nfs" is for arch/ppc and "net_nfs_fdt" is for arch/powerpc. In the long run, arch/ppc support will be removed. Signed-off-by: Stefan Roese <sr@denx.de>
2007-10-31ppc4xx: Add initial AMCC Kilauea 405EX supportStefan Roese
