path: root/board/amcc/canyonlands/u-boot-nand.lds
2011-03-27rename _end to __bss_end__Po-Yu Chuang
Currently, _end is used for end of BSS section. We want _end to mean end of u-boot image, so we rename _end to __bss_end__ first. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2010-11-27ppc4xx: Cleanup for partial linking and --gc-sectionsWolfgang Denk
This commit adapts 4xx boards for partial linking with --gc-sections. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Tirumala Marri <tmarri@apm.com> Cc: David Updegraff <dave@cray.com> Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Cc: Dirk Eibach <eibach@gdsys.de> Cc: Larry Johnson <lrj@acm.org> Cc: Peter De Schrijver <p2@mind.be> Cc: Niklaus Giger <niklaus.giger@netstal.com> Cc: Daniel Poirot <dan.poirot@windriver.com> Acked-by: Stefan Roese <sr@denx.de>
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2009-10-03ppc: Enable full relocation to RAMPeter Tyser
The following changes allow U-Boot to fully relocate from flash to RAM: - Remove linker scripts' .fixup sections from the .text section - Add -mrelocatable to PLATFORM_RELFLAGS for all boards - Define CONFIG_RELOC_FIXUP_WORKS for all boards Previously, U-Boot would partially relocate, but statically initialized pointers needed to be manually relocated. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-04-18ppc4xx: Change Canyonlands to support booting from 2k page NAND devicesStefan Roese
2008-03-15ppc4xx: Add Canyonlands NAND booting supportStefan Roese
460EX doesn't support a fixed bootstrap option to boot from 512 byte page NAND devices. The only bootstrap option for NAND booting is option F for 2k page devices. So to boot from a 512 bype page device, the I2C bootstrap EEPROM needs to be programmed accordingly. This patch adds basic NAND booting support for the AMCC Canyonlands aval board and also adds support to the "bootstrap" command, to enable NAND booting I2C setting. Tested with 512 byte page NAND device (32MByte) on Canyonlands. Signed-off-by: Stefan Roese <sr@denx.de>
