path: root/board/amcc/canyonlands/config.mk
2011-04-30Handle most LDSCRIPT setting centrallyScott Wood
Currently, some linker scripts are found by common code in config.mk. Some are found using CONFIG_SYS_LDSCRIPT, but the code for that is sometimes in arch config.mk and sometimes in board config.mk. Some are found using an arch-specific rule for looking in CPUDIR, etc. Further, the powerpc config.mk rule relied on CONFIG_NAND_SPL when it really wanted CONFIG_NAND_U_BOOT -- which covered up the fact that not all NAND_U_BOOT builds actually wanted CPUDIR/u-boot-nand.lds. Replace all of this -- except for a handful of boards that are actually selecting a linker script in a unique way -- with centralized ldscript finding. If board code specifies LDSCRIPT, that will be used. Otherwise, if CONFIG_SYS_LDSCRIPT is specified, that will be used. If neither of these are specified, then the central config.mk will check for the existence of the following, in order: $(TOPDIR)/board/$(BOARDDIR)/u-boot-nand.lds (only if CONFIG_NAND_U_BOOT) $(TOPDIR)/$(CPUDIR)/u-boot-nand.lds (only if CONFIG_NAND_U_BOOT) $(TOPDIR)/board/$(BOARDDIR)/u-boot.lds $(TOPDIR)/$(CPUDIR)/u-boot.lds Some boards (sc3, cm5200, munices) provided their own u-boot.lds that were dead code, because they were overridden by a CPUDIR u-boot.lds under the old powerpc rules. These boards' own u-boot.lds have bitrotted and no longer work -- these lds files have been removed. Signed-off-by: Scott Wood <scottwood@freescale.com> Tested-by: Graeme Russ <graeme.russ@gmail.com>
2010-09-194xx: adjust TEXT_BASE to increase U-Boot image sizeWolfgang Denk
On some boards (canyonlands, luan, sequoia) we need more room for the U-Boot image to allow for new features like the new environment code. Shift TEXT_BASE as needed. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2009-11-09ppc4xx: Fix NAND booting targets after 4xx linker script consolidationStefan Roese
Somehow I missed the NAND booting targets in the 4xx linker script consolidation patchset. This patch fixes this issue. Signed-off-by: Stefan Roese <sr@denx.de>
2008-05-14ppc4xx: Fix bogus Canyonlands config.mkStefan Roese
This patch fixes the canyonlands config.mk file to enable correct out-of-tree builds. Thanks to Wolfgang Denk for spotting this. Signed-off-by: Stefan Roese <sr@denx.de>
2008-03-15ppc4xx: Add AMCC Canyonlands support (460EX) (1/3)Stefan Roese
This patch adds support for the AMCC Canyonlands 460EX evaluation board. Signed-off-by: Stefan Roese <sr@denx.de>
