path: root/board/amcc/canyonlands/canyonlands.c
2013-10-20usb: rename board_usb_init_type to usb_init_typeTroy Kisky
This will be used by usb_lowlevel_init so it will no longer be used by only board specific functions. Move definition of enum usb_init_type higher in file so that it will be available for usb_low_level_init. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2013-10-20usb: new board-specific USB init interfaceMateusz Zalega
This commit unifies board-specific USB initialization implementations under one symbol (usb_board_init), declaration of which is available in usb.h. New API allows selective initialization of USB controllers whenever needed. Signed-off-by: Mateusz Zalega <m.zalega@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com> Cc: Marek Vasut <marex@denx.de> Cc: Lukasz Majewski <l.majewski@samsung.com>
2011-05-12Fix incorrect use of getenv() before relocationWolfgang Denk
A large number of boards incorrectly used getenv() in their board init code running before relocation. In some cases this caused U-Boot to hang when certain environment variables grew too long. Fix the code to use getenv_r(). Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: The LEOX team <team@leox.org> Cc: Michael Schwingen <michael@schwingen.org> Cc: Georg Schardt <schardt@team-ctech.de> Cc: Werner Pfister <Pfister_Werner@intercontrol.de> Cc: Dirk Eibach <eibach@gdsys.de> Cc: Peter De Schrijver <p2@mind.be> Cc: John Zhan <zhanz@sinovee.com> Cc: Rishi Bhattacharya <rishi@ti.com> Cc: Peter Tyser <ptyser@xes-inc.com>
2010-11-26ppc4xx: Fix build problems of IBM DDR2 NAND booting targetsStefan Roese
This change is needed to compile the PPC4xx NAND booting targets equipped with the IBM DDR2 SDRAM controller. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2010-10-04ppc44x: config GPIOs for USB on canyonlands boardRupjyoti Sarmah
The GPIO 16 and 19 reconfiguration should be done once USB is initialized. So moved the reconfiguration to the USB init function. Signed-off-by: Rupjyoti Sarmah <rsarmah@apm.com> Signed-off-by: Stefan Roese <sr@denx.de>
2010-10-04ppc4xx: Small whitespace cleanup in canyonlands.cStefan Roese
2010-09-23ppc4xx: Move gpio.h to ppc4xx-gpio.h since its ppc4xx specificStefan Roese
2010-09-23ppc4xx: Move ppc4xx headers to powerpc include directoryStefan Roese
This patch moves some ppc4xx related headers from the common include directory (include/) to the powerpc specific one (arch/powerpc/include/asm/). This way to common include directory is not so cluttered with files. Signed-off-by: Stefan Roese <sr@denx.de>
2010-07-23ppc4xx/Canyonlands added USB board callbacksRupjyoti Sarmah
Functions added to support board callbacks for USB init. This isolates USB manipulations such that it is only touched if USB is used by U-Boot. Signed-off-by: Dave Mitchell <dmitchell@appliedmicro.com> Signed-off-by: Rupjyoti Sarmah <rsarmah@appliedmicro.com> Signed-off-by: Stefan Roese <sr@denx.de>
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2009-11-19ppc4xx: Consolidate pci_target_init() functionStefan Roese
This patch removes the duplicted implementations of the pci_target_init() function by introducing a weak default function for it. This weak default has a different implementation for 440EP(x)/GR(x) PPC's. It can be overridden by a board specific version (e.g. PMC440, korat). Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu>
2009-11-09ppc4xx: Remove duplicated is_pci_host() functionsStefan Roese
This patch introduces a weak default function for is_pci_host(), returning 1. This is the default behaviour, since most boards only implement PCI host functionality. This weak default can be overridden by a board specific version if needed. Signed-off-by: Stefan Roese <sr@denx.de>
2009-11-09ppc4xx: Consolidate 4xx PCIe board specific configurationStefan Roese
This patch consolidates the PPC4xx board specific PCIe configuration code. This way the duplicated code is removed. Boards can implement a special, non standard behaviour (e.g. number of PCIe slots, etc) by overriding the weak default functions. Signed-off-by: Stefan Roese <sr@denx.de>
2009-10-07ppc_4xx: Apply new HW register namesNiklaus Giger
Modify all existing *.c files to use the new register names as seen in the AMCC manuals. Signed-off-by: Niklaus Giger <niklaus.giger@member.fsf.org> Signed-off-by: Stefan Roese <sr@denx.de>
2009-10-07ppc4xx: Fix msg "initialization as root-complex failed" upon PCIe scanStefan Roese
This message is printed upon PCIe bus scan, not only upon error, but also if no PCIe device is detected at all. Since this is not an error, let's remove this message in this case. We already have the message "link is not up." if there is no PCIe device present. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Wolfgang Denk <wd@denx.de>
2009-09-28ppc4xx: Convert PPC4xx UIC defines from lower case to upper caseStefan Roese
The latest PPC4xx register cleanup patch missed the UIC defines. This patch now changes lower case UIC defines to upper case. Signed-off-by: Stefan Roese <sr@denx.de>
2009-09-11ppc4xx: Big cleanup of PPC4xx definesStefan Roese
This patch cleans up multiple issues of the 4xx register (mostly DCR, SDR, CPR, etc) definitions: - Change lower case defines to upper case (plb4_acr -> PLB4_ACR) - Change the defines to better match the names from the user's manuals (e.g. cprpllc -> CPR0_PLLC) - Removal of some unused defines Please test this patch intensive on your PPC4xx platform. Even though I tried not to break anything and tested successfully on multiple 4xx AMCC platforms, testing on custom platforms is recommended. Signed-off-by: Stefan Roese <sr@denx.de>
2009-07-30ppc4xx: Add support for PPC460EX/460GT rev B chip to AMCC CanyonlandsStefan Roese
This patch is based on a diff created by Phong Vo from AMCC. Signed-off-by: Phong Vo <pvo@amcc.com> Signed-off-by: Stefan Roese <sr@denx.de>
2009-07-28ppc4xx: Fix problem with NOR range assignment in Canyonlands ft_board_setupStefan Roese
This patch fixes the problem, that the current fdt board fixup code only set's one range, the one for NOR. By this it's overwriting the already correctly configured values done in __ft_board_setup(). Just remove this now unneeded NOR fixup and all the ranges are correctly defined. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Dirk Eibach <eibach@gdsys.de> Cc: Felix Radensky <felix@embedded-sol.com>
2009-07-28ppc4xx: Fix Arches DDR2 initializationStefan Roese
Testing on AMCC Arches with the latest U-Boot version yielded that DDR2 initialization is currently broken. U-Boot hangs upon relocation to SDRAM or crashes with random traps. This patch fixes this problem. Arches now uses a different WRDTR and CLKTR default setting than Canyonlands/Glacier. Signed-off-by: Stefan Roese <sr@denx.de>
2009-07-08ppc4xx: Fix FDT EBC mappings on CanyonlandsFelix Radensky
This patch fixes 2 problems with FDT EBC mappings on Canyonlands. First, NAND EBC mapping was missing, making Linux NAND driver unusable on this board. Second, NOR remapping code assumed that NOR is always on CS0, however when booting from NAND NOR is on CS3. Signed-off-by: Felix Radensky <felix@embedded-sol.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-10-21ppc4xx: Add AMCC Arches board support (dual 460GT)Adam Graham
The Arches Evaluation board is based on the AMCC 460GT SoC chip. This board is a dual processor board with each processor providing independent resources for Rapid IO, Gigabit Ethernet, and serial communications. Each 460GT has it's own 512MB DDR2 memory, 32MB NOR FLASH, UART, EEPROM and temperature sensor, along with a shared debug port. The two 460GT's will communicate with each other via shared memory, Gigabit Ethernet and x1 PCI-Express. Signed-off-by: Adam Graham <agraham@amcc.com> Signed-off-by: Victor Gallardo <vgallardo@amcc.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-09-22ppc4xx: Canyonlands: Remove unnecessary FDT warning upon DTB fixupStefan Roese
Depending on the configuration jumper "SATA SELECT", U-Boot disabled either one PCIe node or the SATA node in the device tree blob. This patch removes the unnecessary and even confusing warning, when the node is not found at all. Signed-off-by: Stefan Roese <sr@denx.de>
2008-06-12ppc4xx: Canyonlands: Disable the RTC M41T62 square wave outputStefan Roese
This patch disables the square wave output of the M41T62 RTC used on Canyonlands & Glacier. Here the explanation: The serial real-time clock part used in the design is an STMicro M41T62. This part has a full-time 32KHz square wave output that is connected to the TmrClk input to the processor. The default state for this square wave output is enabled so the output runs continuously when the board is powered normally and also from the battery. The TmrClk input to the processor goes to ground when the power is removed from the board/processor, and therefore the running square wave output is driving ground which drains the battery quickly. Signed-off-by: Stefan Roese <sr@denx.de>
2008-06-03ppc4xx: Remove implementations of testdram()Stefan Roese
This patch removes the used testdram() implementations of the board that are maintained by myself. Signed-off-by: Stefan Roese <sr@denx.de>
2008-05-19ppc4xx: Canyonlands: Disable PCIe0/SATA in dev-tree depending on selectionStefan Roese
When SATA is selected (via jumper J6) we need to disable the first PCIe node in the device tree, so that Linux doesn't initialize it. Otherwise the Linux SATA driver will fail to detect the devices. The same goes the other way around too. So if PCIe is selected we need to disable the SATA node in the device tree. This is because PCIe port 0 and SATA on 460EX share the same pins (multiplexed) and we have to configure in U-Boot which peripheral is enabled. Signed-off-by: Stefan Roese <sr@denx.de>
2008-04-02ppc4xx: Canyonlands: Init SATA/PCIe port correctlyStefan Roese
Canyonlands (460EX) shares the first PCIe interface with the SoC SATA interface. This usage can be configured with the jumper J6. This patch correctly configures the SATA/PCIe PHY for SATA usage when this jumper is installed. Signed-off-by: Stefan Roese <sr@denx.de>
2008-03-28ppc4xx: Canyonlands: Print SATA/PCIe configuration and board revisionStefan Roese
Canyonlands (460EX) shares the first PCIe interface with the SoC SATA interface. This usage can be configured with the jumper J6. This patch displays the current configuration upon bootup and changes the PCIe init loop, to only initialize the availabel PCIe slots. Signed-off-by: Stefan Roese <sr@denx.de>
2008-03-27ppc4xx: Correctly pass phyiscal FLASH base address into dtbStefan Roese
The routine ft_board_setup() configures the EBC NOR mappings for the Linux physmap_of driver. Since on 460EX/GT we remap the FLASH from 0x4.fc00.0000 to 0x4.cc00.0000 because of the max. 16MByte boot-CS problem, we need to pass the corrected address here too. Signed-off-by: Stefan Roese <sr@denx.de>
2008-03-27ppc4xx: Add AMCC Glacier 406GT eval board supportStefan Roese
This patch adds support for the AMCC Glacier 460GT eval board. The main difference to the Canyonlands board are listed here: - 4 ethernet ports instead of 2 - no SATA port - no USB port Currently EMAC2+3 are not working. This will be fixed in a later release. Signed-off-by: Stefan Roese <sr@denx.de>
2008-03-15ppc4xx: Add USB OHCI support to AMCC Canyonlands 460EX eval boardStefan Roese
This patch adds USB OHCI support to the Canyonlands board port. It also enables EXT2 support. Signed-off-by: Stefan Roese <sr@denx.de>
2008-03-15ppc4xx: Add Canyonlands NAND booting supportStefan Roese
460EX doesn't support a fixed bootstrap option to boot from 512 byte page NAND devices. The only bootstrap option for NAND booting is option F for 2k page devices. So to boot from a 512 bype page device, the I2C bootstrap EEPROM needs to be programmed accordingly. This patch adds basic NAND booting support for the AMCC Canyonlands aval board and also adds support to the "bootstrap" command, to enable NAND booting I2C setting. Tested with 512 byte page NAND device (32MByte) on Canyonlands. Signed-off-by: Stefan Roese <sr@denx.de>
2008-03-15ppc4xx: Add AMCC Canyonlands support (460EX) (1/3)Stefan Roese
This patch adds support for the AMCC Canyonlands 460EX evaluation board. Signed-off-by: Stefan Roese <sr@denx.de>
