path: root/board/amcc/bubinga/bubinga.c
2011-05-12Fix incorrect use of getenv() before relocationWolfgang Denk
A large number of boards incorrectly used getenv() in their board init code running before relocation. In some cases this caused U-Boot to hang when certain environment variables grew too long. Fix the code to use getenv_r(). Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: The LEOX team <team@leox.org> Cc: Michael Schwingen <michael@schwingen.org> Cc: Georg Schardt <schardt@team-ctech.de> Cc: Werner Pfister <Pfister_Werner@intercontrol.de> Cc: Dirk Eibach <eibach@gdsys.de> Cc: Peter De Schrijver <p2@mind.be> Cc: John Zhan <zhanz@sinovee.com> Cc: Rishi Bhattacharya <rishi@ti.com> Cc: Peter Tyser <ptyser@xes-inc.com>
2009-09-28ppc4xx: Convert PPC4xx UIC defines from lower case to upper caseStefan Roese
The latest PPC4xx register cleanup patch missed the UIC defines. This patch now changes lower case UIC defines to upper case. Signed-off-by: Stefan Roese <sr@denx.de>
2009-09-11ppc4xx: Big cleanup of PPC4xx definesStefan Roese
This patch cleans up multiple issues of the 4xx register (mostly DCR, SDR, CPR, etc) definitions: - Change lower case defines to upper case (plb4_acr -> PLB4_ACR) - Change the defines to better match the names from the user's manuals (e.g. cprpllc -> CPR0_PLLC) - Removal of some unused defines Please test this patch intensive on your PPC4xx platform. Even though I tried not to break anything and tested successfully on multiple 4xx AMCC platforms, testing on custom platforms is recommended. Signed-off-by: Stefan Roese <sr@denx.de>
2008-06-03ppc4xx: Remove superfluous dram_init() call or replace it by initdram()Stefan Roese
Historically the 405 U-Boot port had a dram_init() call in early init stage. This function was still called from start.S and most of the time coded in assembler. This is not needed anymore (since a long time) and boards should implement the common initdram() function in C instead. This patch now removed the dram_init() call from start.S and removes the empty implementations that are scattered through most of the 405 board ports. Some older board ports really implement this dram_init() though. These are: csb272 csb472 ERIC EXBITGEN W7OLMC W7OLMG I changed those boards to call this assembler dram_init() function now from their board specific initdram() instead. This *should* work, but please test again on those platforms. And it is perhaps a good idea that those boards use some common 405 SDRAM initialization code from cpu/ppc4xx at some time. So further patches welcome here. Signed-off-by: Stefan Roese <sr@denx.de>
2007-08-14ppc4xx: Add initial Zeus (PPC405EP) board supportStefan Roese
2005-08-01Major cleanup for AMCC PPC4xx eval boards.Stefan Roese
Patch by Stefan Roese, 01 Aug 2005
