path: root/board/amcc/acadia/acadia.c
2011-05-12Fix incorrect use of getenv() before relocationWolfgang Denk
A large number of boards incorrectly used getenv() in their board init code running before relocation. In some cases this caused U-Boot to hang when certain environment variables grew too long. Fix the code to use getenv_r(). Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: The LEOX team <team@leox.org> Cc: Michael Schwingen <michael@schwingen.org> Cc: Georg Schardt <schardt@team-ctech.de> Cc: Werner Pfister <Pfister_Werner@intercontrol.de> Cc: Dirk Eibach <eibach@gdsys.de> Cc: Peter De Schrijver <p2@mind.be> Cc: John Zhan <zhanz@sinovee.com> Cc: Rishi Bhattacharya <rishi@ti.com> Cc: Peter Tyser <ptyser@xes-inc.com>
2009-09-28ppc4xx: Convert PPC4xx UIC defines from lower case to upper caseStefan Roese
The latest PPC4xx register cleanup patch missed the UIC defines. This patch now changes lower case UIC defines to upper case. Signed-off-by: Stefan Roese <sr@denx.de>
2009-09-11ppc4xx: Big cleanup of PPC4xx definesStefan Roese
This patch cleans up multiple issues of the 4xx register (mostly DCR, SDR, CPR, etc) definitions: - Change lower case defines to upper case (plb4_acr -> PLB4_ACR) - Change the defines to better match the names from the user's manuals (e.g. cprpllc -> CPR0_PLLC) - Removal of some unused defines Please test this patch intensive on your PPC4xx platform. Even though I tried not to break anything and tested successfully on multiple 4xx AMCC platforms, testing on custom platforms is recommended. Signed-off-by: Stefan Roese <sr@denx.de>
2007-06-22Coding stylke cleanup; rebuild CHANGELOGWolfgang Denk
2007-06-19[ppc4xx] Fix problem with NAND booting on AMCC AcadiaStefan Roese
The latest changes showed a problem with the location of the NAND-SPL image in the OCM and the init-data area (incl. cache). This patch fixes this problem. Signed-off-by: Stefan Roese <sr@denx.de>
2007-06-06ppc4xx: Add NAND booting support for AMCC Acadia (405EZ) eval boardStefan Roese
This patch adds NAND booting support for the AMCC Acadia eval board. Please make sure to configure jumper J7 to position 2-3 when booting from NOR, and to position 1-2 when booting for NAND. I also added a board command to configure the I2C bootstrap EEPROM values. Right now only 267MHz is support for booting either via NOR or NAND FLASH. Here the usage: => bootstrap 267 nor ;to configure the board for 267MHz NOR booting => bootstrap 267 nand ;to configure the board for 267MHz NNAND booting Signed-off-by: Stefan Roese <sr@denx.de>
2007-05-24ppc4xx: Update AMCC Acadia support for board revision 1.1Stefan Roese
This patch updates the Acadia (405EZ) support for the new 1.1 board revision. It also adds support for NAND FLASH via the 4xx NDFC. Please note that the jumper J7 must be in position 2-3 for this NAND support. Position 1-2 is for NAND booting only. NAND booting support will follow later. Signed-off-by: Stefan Roese <sr@denx.de>
2007-04-18ppc4xx: Update Acadia to not setup PLL when booting via bootstrap EEPROMStefan Roese
2007-03-24[PATCH] Clean up 40EZ/Acadia supportStefan Roese
This patch cleans up all the open issue of the preliminary Acadia support. Signed-off-by: Stefan Roese <sr@denx.de>
2007-03-21[PATCH] Add AMCC Acadia (405EZ) eval board supportStefan Roese
This patch adds support for the new AMCC Acadia eval board. Please note that this Acadia/405EZ support is still in a beta stage. Still lot's of cleanup needed but we need a preliminary release now. Signed-off-by: Stefan Roese <sr@denx.de>
