path: root/board/amcc/acadia/Makefile
2008-07-02Cleanup: remove redundant deleting on *~ filesWolfgang Denk
2007-06-19[ppc4xx] Fix problem with NAND booting on AMCC AcadiaStefan Roese
The latest changes showed a problem with the location of the NAND-SPL image in the OCM and the init-data area (incl. cache). This patch fixes this problem. Signed-off-by: Stefan Roese <sr@denx.de>
2007-06-06ppc4xx: Add NAND booting support for AMCC Acadia (405EZ) eval boardStefan Roese
This patch adds NAND booting support for the AMCC Acadia eval board. Please make sure to configure jumper J7 to position 2-3 when booting from NOR, and to position 1-2 when booting for NAND. I also added a board command to configure the I2C bootstrap EEPROM values. Right now only 267MHz is support for booting either via NOR or NAND FLASH. Here the usage: => bootstrap 267 nor ;to configure the board for 267MHz NOR booting => bootstrap 267 nand ;to configure the board for 267MHz NNAND booting Signed-off-by: Stefan Roese <sr@denx.de>
2007-03-31Merge with git://www.denx.de/git/u-boot.gitStefan Roese
2007-03-21[PATCH] Add AMCC Acadia (405EZ) eval board supportStefan Roese
This patch adds support for the new AMCC Acadia eval board. Please note that this Acadia/405EZ support is still in a beta stage. Still lot's of cleanup needed but we need a preliminary release now. Signed-off-by: Stefan Roese <sr@denx.de>
