Convert altera sysid to driver model with misc uclass.
Acked-by: Chin Liang See <clsee@altera.com>
Convert altera_pio to driver model.
As altera_pio_init() uses BSS, it should be moved to
board_early_init_r().
commit "arm: socfpga: rename socfpga_cyclone5 and socfpga_arria5 config files"
renames the configs files, so we should update the MAINTAINERS' entry. At
the same time, update the email for Dinh Nguyen.
Signed-off-by: Dinh Nguyen <dinguyen@opensource.altera.com>
Pull out the ArriaV SoCDK clock config from ancient Altera U-Boot
"rel_socfpga_v2013.01.01_15.05.01_pr" and implant those values into
mainline to get a booting ArriaV SoCDK.
Repair the maintainer entries so they match the current state of code.
Now that we're actually converting the QTS-generated header files,
we can even adjust their data types. A good candidate for this is
the pinmux table, where each entry can have value in the range of
0..3, but each element is declared as unsigned long. By changing
the type to u8, we can save over 600 Bytes from the SPL, so do it.
This patch also constifies the array.
Just remove the ArriaV specific parts from the CycloneV SoCDK board
and they are no longer needed now.
Just remove the CycloneV specific parts from the ArriaV SoCDK board
The board/altera/socfpga directory is not a generic SoCFPGA machine
anymore, but instead it represents the Altera SoCDK board. To make
matters more complicated, it represents both CycloneV and ArriaV
variant.
On the other hand, nowadays, the content of this board directory is
mostly comprised of QTS-generated header files, while all the generic
code is in arch/arm/mach-socfpga already.
Thus, this patch splits the board/altera/socfpga into a separate
board directory for ArriaV SoCDK and CycloneV SoCDK, so that each
can be populated with the correct QTS-generated header files for
that particular board.
Move the wrappers for QTS-generated files into platform directory
out of the board directory. The trick here is to add -I to CFLAGS
such that it points to the board directory in source tree and thus
the qts/ directory there is still reachable.
Fix build error for socfpga_cyclone5_defconfig:
board/altera/socfpga/wrap_sdram_config.c:245:26: error: ‘RW_MGR_MEM_NUMBER_OF_RANKS’ undeclared here (not in a function)
make[2]: *** [spl/board/altera/socfpga/wrap_sdram_config.o] Error 1
Introduce structure socfpga_sdram_misc_config to wrap the remaining
misc configuration values in board file. Again, introduce a function,
socfpga_get_sdram_misc_config(), which returns this the structure. This
is almost the final step toward wrapping the nasty QTS generated macros
in board files and reducing the pollution of the namespace.
Acked-by: Dinh Nguyen <dinguyen@opensource.altera.com>
Introduce structure socfpga_sdram_io_config to wrap the IO configuration
values in board file. Introduce socfpga_get_sdram_io_config() function,
which returns this the structure. This is another step toward wrapping
the nasty QTS generated macros in board files and reducing the pollution
of the namespace.
Introduce structure socfpga_sdram_rw_mgr_config to wrap the RW manager
configuration values in board file. Introduce a complementary function,
socfpga_get_sdram_rwmgr_config(), which returns this the structure.
This is another step toward wrapping the nasty QTS generated macros
Introduce two wrapper functions, socfpga_get_seq_ac_init() and
socfpga_get_seq_inst_init() to avoid direct inclusion of the
sequencer_auto_ac_init.h and sequencer_auto_inst_init.h QTS
generated files. This reduces namespace pollution again.
Move the files generated by QTS into the board directory, they should not
be part of the driver files at all.
Introduce socfpga_sdram_get_config() function implement in a board file,
which returns the socfpga_sdram_config structure. This is the last step
in cleaning up the socfpga_mmr_init_full(), but not the last step which
allows removing the inclusion of sdram.h from drivers/ddr/altera/sdram.c
thus far.
Implement new accessor, sysmgr_get_pinmux_table(), used to obtain pinmux
table and it's size from the QTS-generated pinmux_config.c. The target
here is again to get rid of poluting global namespace by including the
pinmux_config.h into it.
Furthermore, the pinmux_config.h declares some CONFIG_HPS_* macros,
which are explicitly useless to us in U-Boot. Instead, U-Boot does
use DT to detect exactly these configuration options. This patch
makes sure that while this QTS-generated file can stay in the tree,
these obscure macros do not ooze into the namespace anymore.
Introduce accessor iocsr_get_config_table() for retrieving IOCSR config
tables. This patch is again trimming down the namespace polution.
The IOCSR config tables are used only by scan manager, they are generated
by qts and are board specific. Before this patch, the approach to use
these tables in scan manager was to define an extern variable to silence
the compiler and compile board-specific iocsr_config.c into U-Boot which
defined those extern variables. Furthermore, since these are tables and
the scan manager needs to know the size of those tables, iocsr_config.h
is included build-wide.
This patch wraps all this into a single accessor which takes the scan
chain ID and returns pointer to the table and it's size. All this is
wrapped in wrap_iocsr_config.c board-specific file. The file includes
the iocsr_config.c (!) to access the original tables and transitively
iocsr_config.h . It is thus no longer necessary to include iocsr_config.h
build-wide and the namespace polution is trimmed some more.
Extract the clock configuration horribleness caused by pll_config.h in
the following manner.
First of all, introduce a few new accessors which return values of
various clocks used in clock_manager.c and use them in clock_manager.c .
These accessors replace those few macros which came from pll_config.h
originally. Also introduce an accessor which returns the struct cm_config
default configuration for the clock manager used in SPL.
The accessors are implemented in a board-specific wrap_pll_config.c
file, whose sole purpose is to include the qts-generated pll_config.h
and provide only the necessary values to the clock manager.
The purpose of this design is to limit the scope of inclusion for the
pll_config.h , which thus far was included build-wide and poluted the
namespace. With this change, the inclusion is limited to just the new
wrap_pll_config.c file, which in turn provides three simple functions
for the clock_manager.c to use.
This file is absolutelly positively board specific, so move it
into the correct place.
Move all the files generated by Quartus into the qts/ subdir of the
board/altera/socfpga dir to make them explicitly separate from the
generic U-Boot code.
Cc: Dinh Nguyen <dinguyen@opensource.altera.com>
Switch to a more standard way of board select; put the SoC select
into arch/arm/Kconfig and move the board select menu under
arch/arm/mach-socfpga/Kconfig.
Also, consolidate SYS_BOARD, SYS_VENDOR, SYS_SOC, SYS_CONFIG_NAME.
The compiler option "-Iboard/$(VENDOR)/$(BOARD)" just exists here
for iocsr_config.c to be able to include iocsr_config.h.
Use "..." instead of <...> to include a header in the same directory.
"commit 0d13a0051b2c arm: socfpga: Sync Cyclone V DK PLL configuration"
mistakenly changed CONFIG_HPS_MAINPLLGRP_VCO_NUMER to 39, the correct
value should be 79.
Add a stub s_init function in the board file. The reason why the stub function
is needed is that most of the work is now being done in board_init_f(), there
is no need for the SPL to do anything s_init(). However, since lowlevel_init()
is still branching to s_init(), we need stub function for now, until
lowlevel_init() morphs into s_init().
commit "07d30b6c3129 arm: socfpga: Sync Cyclone V DK pinmux configuration"
incorrectly set the muxing for UART0 on the Cyclone V DK.
This fixes it up so UART0 is working again.
Add support for the Altera Arria V development kit.
Cc: Chin Liang See <clsee@opensource.altera.com>
Cc: Pavel Machek <pavel@denx.de>
Cc: Stefan Roese <sr@denx.de>
Cc: Vince Bridgers <vbridger@opensource.altera.com>
Zap this unused empty function, no point in having it.
Acked-by: Pavel Machek <pavel@denx.de>
Since all boards now have a DT, instead of hard-coding the board
name into the U-Boot binary, read the board name from DT "model"
property.
Drop the _cyclone5 suffix from socfpga_cyclone5.c since this file
will contain Arria 5 support as well.
Sync SoCFPGA Cyclone V development kit pinmux configuration with
Rocketboard U-Boot v2013.01.01-114-g9381569 (ACDS14.1_REL_GSRD_PR).
NOTE: This change is useless until we get proper SPL support, at
which point this will likely need further rework.
Replace multiple spaces with a single tab.
Add proper error checking into the PHY tuning patch. Make the PHY tunning only
happen in case the KSZ9021 PHY is enabled in config. Call the config callback
after the tuning finished.
Cc: Tom Rini <trini@ti.com>
Set the PHY skew settings for the ethernet phy on the SOCFPGA Cyclone5
hardware.
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Cc: Chin Liang See <clsee@altera.com>
Cc: Dinh Nguyen <dinguyen@altera.com>
Cc: Vince Bridgers <vbridger@altera.com>
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
Add example of an USB UDC configuration with DFU and UMS.
Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
This commit introduces a Kconfig symbol for each ARM CPU:
CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136,
CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100.
Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected
for CPU_ARM1176 and CPU_V7.
For each target, the corresponding CPU is selected and the definition of
SYS_CPU in the corresponding Kconfig file is removed.
Also, it removes redundant "string" type in some Kconfig files.
Signed-off-by: Georges Savoundararadj <savoundg@gmail.com>
Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
Move icache_enable() and dcache_enable() function calls from
board code into the CPU code and into the enable_caches()
function. This is how the cache enabling code was designed
to work.
The code is now fixed to the point where we can safely enable
the L1 data cache. Enable the D-Cache and set it as write-alloc.
Cosmetic change to the checkboard() function output. Align the
output with the rest of initial output produced by U-Boot.
The bi_boot_params must point to offset 0x100 in DRAM. Make it so.
Signed-off-by: Pavel Machek <pavel@denx.de>
Add some stub defines, which are used by the clock code, but are
missing from the auto-generated header file for the SoCFPGA family.
Now the types of CONFIG_SYS_{ARCH, CPU, SOC, VENDOR, BOARD, CONFIG_NAME}
are specified in arch/Kconfig.
We can delete the ones in arch and board Kconfig files.
This commit can be easily reproduced by the following command:
find . -name Kconfig -a ! -path ./arch/Kconfig | xargs sed -i -e '
/config[[:space:]]SYS_\(ARCH\|CPU\|SOC\|\VENDOR\|BOARD\|CONFIG_NAME\)/ {
N
s/\n[[:space:]]*string//
Enable initialization fo designware ethernet controller. With this
patch, ethernet works in my configuration, provided I set ethernet
address in the environment.
Though nios2-generic board meant to be a template, it is helpful
to be able to test on a real hardware. As the nios2 linux is
developed and tested on a 3c120 FPGA based Golden Hardware Reference
Design, it makes sense to rebase nios2-generic on this FPGA design.
