path: root/board/altera
2014-06-19Remove nios-32 arch remnantsVasili Galka
nios-32 arch was removed back in 2010 (1117cbf). Code depending on its headers (nios.h, nios-io.h) can't possibly compile since then. As it wasn't fixed till now it is safe to remove. Signed-off-by: Vasili Galka <vvv444@gmail.com>
2014-04-17board: altera: delete unused source filesMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Scott McNutt <smcnutt@psyent.com>
2014-04-07socfpga: Adding Clock Manager driverChin Liang See
Clock Manager driver will be called to reconfigure all the clocks setting based on user input. The input are passed to Preloader through handoff files Signed-off-by: Chin Liang See <clsee@altera.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denk <wd@denx.de> CC: Pavel Machek <pavel@denx.de> Cc: Dinh Nguyen <dinguyen@altera.com> Acked-by: Pavel Machek <pavel@denx.de>
2014-02-19Move #ifdef(CONFIG_DISPLAY_CPUINFO) from caller to calleeMasahiro Yamada
- When CONFIG_DISPLAY_CPUINFO is not enabled, print_cpuinfo() should be defined as an empty function in a header, include/common.h - Remove #ifdef CONFIG_DISPLAY_CPUINFO .. #endif from caller, common/board_f.c and arch/arm/lib/board.c - Remove redundant prototypes in arch/arm/lib/board.c, arch/arm/include/asm/arch-am33x/sys_proto.h and board/nokia/rx51/rx51.h, keeping the one in include/common.h - Add #ifdef CONFIG_DISPLAY_CPUINFO to the func definition where it is missing Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-01-29board: nios2: Check if flash is configured before calling ↵Ezequiel Garcia
early_flash_cmd_reset() If CONFIG_CFI_FLASH_MTD is not defined, then we shouldn't perform the flash early reset. This commit fixes the following build error: nios2-generic.c: In function `__early_flash_cmd_reset': nios2-generic.c:23: error: `AMD_CMD_RESET' undeclared (first use in this function) nios2-generic.c:23: error: (Each undeclared identifier is reported only once nios2-generic.c:23: error: for each function it appears in.) nios2-generic.c:24: error: `FLASH_CMD_RESET' undeclared (first use in this function) which was introduced by: commit a113fb39df43546c704aa8eba55720da9a9dfedd Author: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Date: Fri Dec 20 18:34:53 2013 -0300 board: nios2: Add CONFIG_CFI_FLASH_MTD guard to flash.h header include Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Cc: Thomas Chou <thomas@wytron.com.tw> Reported-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
2014-01-14board: nios2: Add CONFIG_CFI_FLASH_MTD guard to flash.h header includeEzequiel Garcia
2013-11-17Makefile: make directories by Makefile.buildMasahiro Yamada
2013-11-15nios2: remove unnecessary header include pathMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Thomas Chou <thomas@wytron.com.tw>
2013-11-01nios2: convert makefiles to Kbuild styleMasahiro Yamada
2013-10-14Coding Style cleanup: replace leading SPACEs by TABsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> [trini: Drop changes for PEP 4 following python tools] Signed-off-by: Tom Rini <trini@ti.com>
2013-10-07socfpga: Adding pin mux handoff filesChin Liang See
Adding the generated pin mux configuration by Preloader Generator tool Signed-off-by: Chin Liang See <clsee@altera.com> Reviewed-by: Pavel Machek <pavel@denx.de> Acked-by: Dinh Nguyen <dinguyen@altera.com> Cc: Wolfgang Denk <wd@denx.de> CC: Pavel Machek <pavel@denx.de> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Tom Rini <trini@ti.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net>
2013-10-07socfpga: Adding System Manager driverChin Liang See
Adding System Manager driver which will configure the pin mux for real hardware Cyclone V development kit (not Virtual Platform) Signed-off-by: Chin Liang See <clsee@altera.com> Reviewed-by: Pavel Machek <pavel@denx.de> Acked-by: Dinh Nguyen <dinguyen@altera.com> Cc: Wolfgang Denk <wd@denx.de> CC: Pavel Machek <pavel@denx.de> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Tom Rini <trini@ti.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net>
2013-07-25Merge branch 'u-boot/master' into u-boot-arm/masterAlbert ARIBAUD
2013-07-25socfpga: Move board/socfpga_cyclone5 to board/socfpgaDinh Nguyen
Because the SOCFPGA platform will include support for Cyclone V and Arria V FPGA parts, renaming socfpga_cyclone5 folder to socfpga to be more generic. Signed-off-by: Dinh Nguyen <dinguyen@altera.com> Reviewed-by: Pavel Machek <pavel@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Wolfgang Denk <wd@denx.de> CC: Pavel Machek <pavel@denx.de> Cc: Tom Rini <trini@ti.com> v2: - Add Reviewed-by: Pavel Machek - Cc: Tom Rini
2013-03-18Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Albert's rework of the linker scripts conflicted with Simon's making everyone use __bss_end. We also had a minor conflict over README.scrapyard being added to in mainline and enhanced in u-boot-arm/master with proper formatting. Conflicts: arch/arm/cpu/ixp/u-boot.lds arch/arm/cpu/u-boot.lds arch/arm/lib/Makefile board/actux1/u-boot.lds board/actux2/u-boot.lds board/actux3/u-boot.lds board/dvlhost/u-boot.lds board/freescale/mx31ads/u-boot.lds doc/README.scrapyard include/configs/tegra-common.h Build tested for all of ARM and run-time tested on am335x_evm. Signed-off-by: Tom Rini <trini@ti.com>
2013-03-15Replace __bss_end__ with __bss_endSimon Glass
Note this is a tree-wide change affecting multiple architectures. At present we use __bss_start, but mostly __bss_end__. This seems inconsistent and in a number of places __bss_end is used instead. Change to use __bss_end for the BSS end symbol throughout U-Boot. This makes it possible to use the asm-generic/sections.h file on all archs. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-12Refactor linker-generated arraysAlbert ARIBAUD
Refactor linker-generated array code so that symbols which were previously linker-generated are now compiler- generated. This causes relocation records of type R_ARM_ABS32 to become R_ARM_RELATIVE, which makes code which uses LGA able to run before relocation as well as after. Note: this affects more than ARM targets, as linker- lists span possibly all target architectures, notably PowerPC. Conflicts: arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds arch/arm/cpu/armv7/omap-common/u-boot-spl.lds board/ait/cam_enc_4xx/u-boot-spl.lds board/davinci/da8xxevm/u-boot-spl-da850evm.lds board/davinci/da8xxevm/u-boot-spl-hawk.lds board/vpac270/u-boot-spl.lds Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2012-10-22common: Discard the __u_boot_cmd sectionMarek Vasut
The command declaration now uses the new LG-array method to generate list of commands. Thus the __u_boot_cmd section is now superseded and redundant and therefore can be removed. Also, remove externed symbols associated with this section from include/command.h . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-10-22common: Add .u_boot_list into all linker filesMarek Vasut
Add section for the linker-generated lists into all possible linker files, so that everyone can easily use these lists. This is mostly a mechanical adjustment. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-10-04ARM: Add Altera SOCFPGA Cyclone5Dinh Nguyen
Add minimal support for Altera's SOCFPGA Cyclone 5 hardware. Signed-off-by: Dinh Nguyen <dinguyen@altera.com> Signed-off-by: Chin Liang See <clsee@altera.com> Signed-off-by: Pavel Machek <pavel@denx.de> Reviewed-by: Marek Vasut <marex@denx.de> Acked-by: Tom Trini <trini@ti.com> Cc: Wolfgang Denx <wd@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Stefan Roese <sr@denx.de> ---- v8: Remove no_return attribute for reset_cpu Based on v2012.10-rc2
2011-10-28board/nios2-generic: Use altera_pio driver and remove board specific driverJoachim Foerster
Signed-off-by: Joachim Foerster <joachim.foerster@missinglinkelectronics.com> Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2011-10-28gpio: Add driver for Altera's PIO coreJoachim Foerster
This driver may handle multiple PIO cores and thus needs to be setup by calling the altera_pio_init() function within the early board setup routine. The driver comes with some extras, see below the copyleft header. Signed-off-by: Joachim Foerster <joachim.foerster@missinglinkelectronics.com> Tested-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2011-10-26altera_tse: Add support for dedicated descriptor memoryJoachim Foerster
2011-04-30Handle most LDSCRIPT setting centrallyScott Wood
Currently, some linker scripts are found by common code in config.mk. Some are found using CONFIG_SYS_LDSCRIPT, but the code for that is sometimes in arch config.mk and sometimes in board config.mk. Some are found using an arch-specific rule for looking in CPUDIR, etc. Further, the powerpc config.mk rule relied on CONFIG_NAND_SPL when it really wanted CONFIG_NAND_U_BOOT -- which covered up the fact that not all NAND_U_BOOT builds actually wanted CPUDIR/u-boot-nand.lds. Replace all of this -- except for a handful of boards that are actually selecting a linker script in a unique way -- with centralized ldscript finding. If board code specifies LDSCRIPT, that will be used. Otherwise, if CONFIG_SYS_LDSCRIPT is specified, that will be used. If neither of these are specified, then the central config.mk will check for the existence of the following, in order: $(TOPDIR)/board/$(BOARDDIR)/u-boot-nand.lds (only if CONFIG_NAND_U_BOOT) $(TOPDIR)/$(CPUDIR)/u-boot-nand.lds (only if CONFIG_NAND_U_BOOT) $(TOPDIR)/board/$(BOARDDIR)/u-boot.lds $(TOPDIR)/$(CPUDIR)/u-boot.lds Some boards (sc3, cm5200, munices) provided their own u-boot.lds that were dead code, because they were overridden by a CPUDIR u-boot.lds under the old powerpc rules. These boards' own u-boot.lds have bitrotted and no longer work -- these lds files have been removed. Signed-off-by: Scott Wood <scottwood@freescale.com> Tested-by: Graeme Russ <graeme.russ@gmail.com>
2011-04-08nios2: reset cfi flash before reading envThomas Chou
Flash might be in unknown state when u-boot is started with jtag. And got wrong env data. So reset it in board early init. We cannot use generic cfi flash routines, because flash_init() is not run yet. Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2011-03-27rename _end to __bss_end__Po-Yu Chuang
Currently, _end is used for end of BSS section. We want _end to mean end of u-boot image, so we rename _end to __bss_end__ first. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2011-02-08nios2: add gpio_is_validThomas Chou
Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Scott McNutt <smcnutt@psyent.com>
2011-02-08nios2: add gpio_freeThomas Chou
2010-07-12nios2: remove EP1C20, EP1S10, EP1S40 boardsThomas Chou
The example configuration files of nios2-generic board can generated binary to run on the EP1C20, EP1S10, and EP1S40 boards. So the three boards can be removed. With nios2-generic approach, the fpga parameter header file can be generated from hardware designs using tools. Porting u-boot for nios2 boards is simplified. Vendors can supply their fpga parameter file or patches to add a new nios2-generic board instance. There is no need to include other boards support for nios2 in the u-boot mainline. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Scott McNutt <smcnutt@psyent.com>
2010-07-12nios2: add spi flash support to nios2-generic boardThomas Chou
This patch enables the altera_spi and spi_flash drivers for the nios2-generic board. It allows access to the EPCS/SPI flash on the Altera EP1C20 board. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Tested-by: Ian Abbott <abbotti@mev.co.uk> Signed-off-by: Scott McNutt <smcnutt@psyent.com>
2010-07-12nios2: add gpio_requestThomas Chou
This will be used by nand_plat. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Scott McNutt <smcnutt@psyent.com>
2010-05-28nios: remove nios-32 archThomas Chou
The nios-32 arch is obsolete and broken. So it is removed. Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2010-05-28nios2: add gpio support to nios2-generic boardThomas Chou
This patch adds gpio support of Altera PIO component to the nios2-generic board. Though it drives only gpio_led at the moment, it supports bidirectional port to control bit-banging I2C, NAND flash busy status or button switches, etc. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Tested-by: Ian Abbott <abbotti@mev.co.uk> Signed-off-by: Scott McNutt <smcnutt@psyent.com>
2010-04-24nios2: add nios2-generic boardThomas Chou
This is a generic approach to port u-boot for nios2 boards. You may find the usage of this approach on the nioswiki, http://nioswiki.com/DasUBoot A fpga parameter file, which contains base address information and drivers declaration, is generated from Altera's hardware system description sopc file using tools. The example fpga parameter file is compatible with EP1C20, EP1S10 and EP1S40 boards. So these boards can be removed after this commit. Though epcs controller is removed to cut the dependency of altera_spi driver. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Scott McNutt <smcnutt@psyent.com>
2010-04-24nios2: add altera cf resetThomas Chou
This patch toggles power to reset the cf card. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Scott McNutt <smcnutt@psyent.com>
2010-04-16nios2: Move individual board linker scripts to common script in cpu tree.Scott McNutt
2010-04-13nios: Move cpu/nios/* to arch/nios/cpu/*Peter Tyser
2010-04-02nios2: Fix AMDLV065D flash write bug in altera board common tree.Scott McNutt
2010-04-02nios2: Fix outx/writex parameter order in io.hScott McNutt
The outx/writex macros were using writex(addr, val) rather than the standard writex(val, addr), resulting in incompatibilty with architecture independent components. This change set uses standard parameter order. Signed-off-by: Scott McNutt <smcnutt@psyent.com>
2009-10-04Convert SMC91111 Ethernet driver to CONFIG_NET_MULTI APIBen Warren
All in-tree boards that use this controller have CONFIG_NET_MULTI added Also: - changed CONFIG_DRIVER_SMC91111 to CONFIG_SMC91111 - cleaned up line lengths - modified all boards that override weak function in this driver - modified all eeprom standalone apps to work with new driver - updated blackfin standalone EEPROM app after testing Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-08-25Convert CS8900 Ethernet driver to CONFIG_NET_MULTI APIBen Warren
All in-tree boards that use this controller have CONFIG_NET_MULTI added Also: - changed CONFIG_DRIVER_CS8900 to CONFIG_CS8900 - changed CS8900_BASE to CONFIG_CS8900_BASE - changed CS8900_BUS?? to CONFIG_CS8900_BUS?? - cleaned up line lengths - modified VCMA9 command function that accesses the device - removed MAC address initialization from lib_arm/board.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Tested-by: Wolfgang Denk <wd@denx.de> Acked-by: Wolfgang Denk <wd@denx.de>
