path: root/board/altera/nios2-generic
2010-07-12nios2: add spi flash support to nios2-generic boardThomas Chou
This patch enables the altera_spi and spi_flash drivers for the nios2-generic board. It allows access to the EPCS/SPI flash on the Altera EP1C20 board. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Tested-by: Ian Abbott <abbotti@mev.co.uk> Signed-off-by: Scott McNutt <smcnutt@psyent.com>
2010-07-12nios2: add gpio_requestThomas Chou
This will be used by nand_plat. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Scott McNutt <smcnutt@psyent.com>
2010-05-28nios2: add gpio support to nios2-generic boardThomas Chou
This patch adds gpio support of Altera PIO component to the nios2-generic board. Though it drives only gpio_led at the moment, it supports bidirectional port to control bit-banging I2C, NAND flash busy status or button switches, etc. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Tested-by: Ian Abbott <abbotti@mev.co.uk> Signed-off-by: Scott McNutt <smcnutt@psyent.com>
2010-04-24nios2: add nios2-generic boardThomas Chou
This is a generic approach to port u-boot for nios2 boards. You may find the usage of this approach on the nioswiki, http://nioswiki.com/DasUBoot A fpga parameter file, which contains base address information and drivers declaration, is generated from Altera's hardware system description sopc file using tools. The example fpga parameter file is compatible with EP1C20, EP1S10 and EP1S40 boards. So these boards can be removed after this commit. Though epcs controller is removed to cut the dependency of altera_spi driver. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Scott McNutt <smcnutt@psyent.com>
