path: root/board/altera/ep1s10
2010-07-12nios2: remove EP1C20, EP1S10, EP1S40 boardsThomas Chou
The example configuration files of nios2-generic board can generated binary to run on the EP1C20, EP1S10, and EP1S40 boards. So the three boards can be removed. With nios2-generic approach, the fpga parameter header file can be generated from hardware designs using tools. Porting u-boot for nios2 boards is simplified. Vendors can supply their fpga parameter file or patches to add a new nios2-generic board instance. There is no need to include other boards support for nios2 in the u-boot mainline. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Scott McNutt <smcnutt@psyent.com>
2010-04-16nios2: Move individual board linker scripts to common script in cpu tree.Scott McNutt
2010-04-13nios: Move cpu/nios/* to arch/nios/cpu/*Peter Tyser
2009-10-04Convert SMC91111 Ethernet driver to CONFIG_NET_MULTI APIBen Warren
All in-tree boards that use this controller have CONFIG_NET_MULTI added Also: - changed CONFIG_DRIVER_SMC91111 to CONFIG_SMC91111 - cleaned up line lengths - modified all boards that override weak function in this driver - modified all eeprom standalone apps to work with new driver - updated blackfin standalone EEPROM app after testing Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2006-06-08Nios II - Add Altera EP1C20, EP1S10 and EP1S40 boardsScott McNutt
Patch by Scott McNutt, 08 Jun 2006
