path: root/board/alphaproject
2013-10-31sh: convert makefiles to Kbuild styleMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2012-10-05sh: ap_sh4a_4a: Fixed initialization value of DDR memoryNobuhiro Iwamatsu
The wrong value was set as value of column of DDR memory for ap_sh4a_4a. 10 is the right value. This fixed this problem. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-06-28sh: ap_sh4a_4a: Fix wrong register initialization valueNobuhiro Iwamatsu
The value of ET0_ERXD6 and GPSR1_INIT was wrong. This fixes them. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-05-28sh/ap_sh4a_4a: Fix typo of operator in ET0_ETXD4Nobuhiro Iwamatsu
2012-05-28sh: Add support for AP-SH4A-4A boardNobuhiro Iwamatsu
The AP-SH4A-4A board has SH7734, 64MB DDR2-SDRAM, USB, Ethernet, and more. This patch supports the following functions: - 64MB DDR2-SDRAM - 16MB NOR Flash memory - Serial console (SCIF) - Ethernet (SH-Ether with Gigabit) - I2C Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
